Question about Sub-Zero Refrigerators
How do I replace refrigerator light switch on Sub Zero 590? Does it just pop out or do I need to remove the panel?
  • 828 Answers
Http://store.4appliancerepairparts.com/servlet/-strse-6795/16009-621038-751228-7516450/Detail
These switches snap into place. Carefully remove them by releasing one side so the panel is not damaged. The above URL will have a picture of a similar switch to the one in question.
Posted on Jul 29, 2008
My sub zero 600 series has no light in fridge nor on control panel
There will be two switches per compartment, one is the fan switch, the other is for the lights... Remove the top compartment vent panel, the switches will be accessed from above... remove the wires and push them down into the fridge... you can test them by setting a meter to "continuity" test and pressing the paddle of the switch to see if it lets current through.
SUB-ZERO machines are more serial number dependent when ordering parts... http://www.midwestdistributing.com/Store/OpenPages/ManualPage.aspx?PageTitle=MANUALS
Aug 20, 2016 | Sub-Zero 632 / S
Sub zero leaks water
You need to replace that water line, except it's not on top on a 632. And those weren't available in 1994. Do you maybe have a 590?
Jun 26, 2014 | Sub-Zero 632 / S
What is causing my sub zero moled 590 , made in feb 93 to gradually warm up?
yeah vacuuming behind the fridge is a good start this will help the fridge preform better as when dust builds up on the condenser it will cause the discharge to be hotter than it should be making the cooling in the case not as efficient. i would start by removing the pannel in the fridge and seeing if any ice is on the evaporator
May 22, 2014 | Sub-Zero Bottom Freezer Refrigerator
SUb-Zero 650 fridge lighting issue
Just a bad door switch. Turn the unit off, remove the upper grill, then remove the cover over the switches. there are 2. 1 with a black backside, and one that is all white. you want to replace the all white one with a new all white one. it just has 2 wires, doesn't matter what order they go in. pull em off and pop that thing out, then snap the new one into place. all of this should be done with the power off and the door open. Good Luck!
Jan 03, 2014 | Sub-Zero 650 / O Bottom Freezer...
Sub zero light out
Make sure all the bulbs aren't bad. (it happens more than you'd think) If not try wiggling the light switch at the top of the unit. You can usually get the lights to at least flash. Take the top grill off and either unplug the unit or shut it off at the breaker. Take off the switch cover, remove the wires from the light switch. The light switch is all white, the fan switch has one black side. pop the switch down through the frame and then pop the new one up into the hole. Reattach wires and reinstall cover.
Oct 28, 2013 | Sub-Zero Refrigerators
Side by side Sub Zero light switch works intermittently.
I had the same problem with my sub-zero and finally resolved it (much to my wife's delight) by just replacing it. R&R was a lot simpler than having to work on it every time my wife had a problem.
Dec 14, 2011 | Sub-Zero 690 Side by Side Refrigerator
I have a Sub Zero 690 (June 1999 model). The frig size light switch went out. We popped it out to test to see if it had continuity (it didn't). We put it back in and planned to call service guy to...
remove the top light cover,hold in the other switch that's next to the light switch,the fan should turn on,it sounds like the fan isn't working,go back up top,remove the metal cover that's above the switches and see if you knocked the wire off of the fan switch.why can't you see the control panel?did it go out when you touched the light switch?
Sep 04, 2011 | Sub-Zero 690 Side by Side Refrigerator
SUB-ZERO MODEL 590 Need to replace a plastic water line. How to open the panel (with temp. adjustments) on left side to access the line???
The side panel can be removed by holding the bootom of the side panel and rearward and the pulling out as shown in the pic below
Aug 21, 2010 | Refrigerators
How can i find stainless steel panels for the front of my sub zero model 590
We are factory authorized Sub Zero parts and service. Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 Am until 9 PM CST for all your Sub Zero parts and supplies.
We look forward to hearing from you. Thanks, Ella
Nov 13, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Ice maker will not stop!
You are going to have to replace the dispensor module. Go to http://www.subzero.com/locator/locator.aspx?type=0&zip= for your local parts distributor or service agent. The factory number is 800-222-7820 and they are very helpful.
Dec 18, 2008 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Refrigerators Logo
161 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
