Question about SanDisk Sansa Clip MP3 Player
No kiddin.... this Sansa is less that 2 wks old....and it won't hold a charge. Is there a solution...besides throwing it away?
  • KATHYB0204 Jul 30, 2008
    I'm not hearing a solution to the problem (Sansa battery won't recharge)......from anyone.......only answer is to return the flawed product.
    Master:
  • 623 Answers
Why would you throw it away?take it to where you bought it and have it replaced,if its 2 weeks old it should be covered by a warranty
Posted on Jul 29, 2008
  • ritchie dempacco
    ritchie dempacco Jul 31, 2008
    your battery won't charge because it's dead you need the shop where you bought it change it for a new one or you could by a new battery to solve the problem
Misfire with smell
What kind of Spark Plugs did you put in? If your answer is BOSCH Platinum? THROW THEM AWAY.
Put in AC DELCO.... that is your first thing to do..
Apr 15, 2013 | 2000 Buick LeSabre
My mp3 player wont charge but will turn on when pouted in
connect the Sansa (via the player's USB cord) to different USB ports on the computer until the Sansa starts to charge. A weak or non-working USB port won't charge the Sansa.
  • Reset the Sansa MP3 player. Slide the player's "Power" switch all the way up to the "On" position. Hold the switch in that position for 20 seconds. The Sansa resets. Try to charge the player.
  • Install the latest firmware onto the Sansa MP3 player. Download the Sansa Firmware Updated (link in References), and then click the link in Resources for the specific model of Sansa you own to learn how to update the player's firmware.
  • May 01, 2012 | Kitchen Appliances - Others
    Lenovo battery won't charge
    Battery not charging usually means its dying! If your battery under one year old, you can get replacement from Lenovo. If its older than three year old, its time to find a new battery!
    Is the battery not holding the charge at all? that means is the computer shutting off as soon as taken from power outlet or battery lasting less than expected...
    Sep 27, 2011 | Computers & Internet
    2 wks old on a eco wash and after 2 hours still running. is this right?
    Hi!
    Yes, it is OK, eco wash means less heating energy and less water, but in order to do the dishes clean, it requires more time.
    Regards,
    Bogdan
    Aug 21, 2011 | Bosch Dishwashers
    I have a X52 pro. Throttle works fine, but the lights on the stick are constanly flashing and the stick doesn't work
    if your X52 is less than 2 years old and you have the receipt, it's under warranty. Call Saitek and they will take it back and fix it (no charge). Mine is more than 2 years old so I am out of luck.
    Jun 14, 2011 | Saitek X52 Flight Control System
    I believe the mp3 player's charge to last for 15 hours. It is only holding a charge for about 5 hours
    Ifthe recharageable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
    May 26, 2011 | SanDisk Sansa Clip MP3 Player
    My sandisk sansa clip 1gb wont turn on
    Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
    NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
    To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
    If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
    Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
    Sansa clip mp3 player has problem with recharging. now dead.
    I've had the same problem as you. It probably just doesn't work on that computer. Try plugging it into another one, see if it charges.
    Mar 15, 2009 | SanDisk Sansa Clip MP3 Player
    Sansa Driver problem
    No need to reinstall XP. Sandisk's website suggests doing the firmware upgrade instead. If the firmware upgrade won't take, then try to force recognition:
    Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
    Try this helpful link:
    http://forums.sandisk.com/sansa/search?submitted=true&type=message&sort_by=score&q=driver+c200&page_size=10
    Jun 22, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
    Phones not charging
    you should definately throw the batteries away. They are probably close to dying and have very little battery life every charge. everytime you charge your battery it has less life in it so if it is old it might be time to replace the batteries.
    May 07, 2008 | Motorola Mobility E51 MD7161-3 Quad...
    SanDisk Sansa Clip MP3 Player Logo
    87 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Computer Repairing
    Computer Repairing
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
