Question about Apple iPhone 3G
Iphone 3g My iphone dials someone else when I am already on the phone, and goes on hold or speaker when I am talking. How can I stop this??
  • 52 Answers
You can restore your iPhone 3G back to factory settings.
Thank You, Apple care Technical Support Nick M.
Posted on Jul 29, 2008
Since this morning, when making a phonecall, others are unable to hear me and I am able to hear them. I have the IPhone 3g. Is this a known problem? What can I do? I'd appreciate any help.
I have about 65 iPhones in my organization that I manage. I have had a few of them have this problem. It seems that the microphone at the bottom of the phone goes out/goes bad. Usually the sound through a bluetooth headset or the/a wired headset still works. The only permanent solution is to replace the phone. If you are eligible for an upgrade, I hear that the 3GS's are going down to $49 from $99 this month.
Hope this helps.
Jan 11, 2011 | Apple iPhone 3G
IPhone 3G: I cannot turn on the phone...
Restoration of iPhone to original factory defaults will likely to fix all problem, with the downside that all data and information stored on your phone will be lost. Normally iTunes will make a backup automatically when you connect and sync the iPhone with the program, however, it’s still a good recommendation to copy out and backup everything that you may need on the phone before proceed to restore the iPhone.
To restore iPhone and reset the phone to default factory settings, follow these steps:
Turn off iPhone – Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider. Ignore this step if your iPhone is already off.
Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears.
Plug the iPhone into Mac or Windows PC. Release the button if you haven’t.
Run and open iTunes if it’s not already opened yet.
iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK.
You will be taken to the iPhone pane. Then, click on Restore.
Wait for the full restoration process to complete, and the iPhone will be back to the original settings state as when it left the manufacturing factory, typically a working phone again if you face any problem, unless it’s hardware related.
May 16, 2010 | Apple iPhone 3G
Iphone not starting
Hello!I have a problem with my iPhone 3g battery life, it lasts for no more than 5 hours or so and it doesnt matter what I do with the phone, if I listen to music, talking to someone or even if the iPhone on standby, at night I have to put it to charge because the iPhone just wont last the entire night (on standby) and will turn off.does someone have the same problem or know what to do to fix it?I have the iPhone for like a year and a half and the version is 3.0
Mar 05, 2010 | Apple iPhone 3G Black Smartphone
Iphone 3G speakerphone and headset volume is too low
Whilst on a call in bluetooth mode change the volume. It needs to be for each different "speaker" you use
Feb 25, 2010 | Apple iPhone 3G
Iphone stuck on silent already tried powering
Try holding down the power button and the home button. The phone should restart. If that does not work try restoring the phone with itunes
Dec 12, 2009 | Apple iPhone 3G
Numbers won't stay that i dial
did you by chance update to the iPhone 3.0 Beta?
if so your issue is a bug in the software.
if you didn;t update yet,
press and hold the home and the sleep button until the iPhone reboots.
then give it a try.
Jun 05, 2009 | Apple iPhone 3G Black Smartphone
My iphone 3g is frozen on the apple sighn how can i fix? it i already tried to reset it on itunes but it sais there is an eror pleas help me....
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 04, 2009 | Apple iPhone 3G
IPhone 3G Bluetooth microphone volume to low
This is a Normal problem, remeber the echo is for the mircrophone is in the same place like the speakers, & dont have a noice cancelation system, I recomended to use a bluetooth earphone
Nov 14, 2008 | Apple iPhone 3G
Spore iPhone 3G Problem
No, not for a few months, and yes...there will probably be a few issues at first. Your running an iphone version of the Gameboy version of the PC version of Spore. Even if it is just that the application features are severely limited.
We are talking about a "port" of a "port" here.
Sep 08, 2008 | Apple iPhone 3G
Non stop booting
1st- Press and hold the Home button and the Sleep/Wake button at the same time.
2nd- As soon as the screen goes black release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery
Dec 27, 2007 | Apple iPhone Smartphone
Apple iPhone 3G Logo
59 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
