Question about Maytag Neptune MAH6500A Front Load Washer
Will not spin to rinse and makes a churning noise/clogged drain for softener?
I have a Neptune Maytage Frontloader MAH-3, it has decided it does not want to spin the water out of the clothes, and when it tries to spin it makes an awful churning noise. Second problem: the area I put my softener has apparently become clogged. I have taken the tub out and cleaned it, but I think it is further in the machine where I cannot see. Too many problems for a machine only in use 3 years. - Thank you
Washing machine model wa 95 f3 cannot rinse and spin
Posted on Dec 12, 2008
    Problem Solver:
  • 8 Answers
When my washer did that, they came out and put in a new pump etc, and it did it again within a few months. What fixes mine, at least for the 2 years I had only that problem, was to unplug and replug the wires that go into the motor board (that'sthe one under the wash tub, not the one behind the dials. Then it would be fixed for a month or two. The wire harness (and I never pinpointed exactly which one, just did them all) would come a little lose. I took the front part off the washer so that I have constant access to that part. This last time when it did it, tho, this did not fix the problem. Instead, it seems that my wax motor for the door lock had failed, and I cooked R11. As a temporary fix, I cut the R11 out of the control board (the one behind the dials), and inserted a popsicle stick into the microswitch further from the wax motor, so the door thinks it is locked and it will spin. This results in the washer not shutting down at the end of the cycle on its own (thinks the door is still locked) so you have to manually turn it off. Since I already had the front off the machine, I just had to undo the screws to the left and right at the top to raise the top of the machine to insert my popsicle stick. It is a lovely machine, isn't it? I have the MAH3000 also.
Posted on Oct 23, 2008
Model MAH 7800 drain pump will not run, door locks, tub spins, water drains by gravity
Well your drain pump needs attention for sure. There could be an object lodged against propellers or it may need to be relaced. Try unplugging the connector that goes to the pump and plugging back in. Also try tapping the the motor part of the drain assembly while in spin cycle before replacing. Good luck.
Dec 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
My frontloader washing machine I(Neptune MAH
unfortuetly that is a common problem with that unit. it will continue to have wate in it afte the cycle has ended. i hate to say it but there is no solution for this proplem. I would recommend that you contact Maytag and let them know your disappointment. sorry for that news.
Oct 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer won't drain maytag neptune washer MAH-3
Check the drain line for kinks or obstructions. You can take a flashlight, remove the hose from the pump and look into the suction port of the pump. Check for anything clogging the pump. (like the occasional stray sock). Also check the pump impellers for broken or missing blades and ensure that the pump impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective and will need replaced. Hopefully it is just a clogged pump or drain line. Hope this helped and best wishes.
Sep 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
My machine make too much noise
does it sound like a 747 about to crash in your house? if so you might as well through your washer away because you have a bad bearing and the cost to repair that is about the same for a new one. let me know if this helps
May 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
I do not get the door lock indication on my maytage neptune frontloader washer, which prevents the high speed spin.
what model is it if its the 3000 or 4000 u have to replace lock latch and top board not worth fixing if its thee 5500 model just the locklatch and its worth fixing
May 20, 2009 | Maytag Neptune Washer
Maytag washer MAH 5500bww seems to run OK, but it does not pump out all the water(pumps out some) at the end of the cycles, churns remaining water during spin
Open the rear panel and remove the drain pump and clean it.
If there is nothing in the pump, check the drain motor for 18 ohms with a volt/ohm meter.
Not 18 ohms, replace the motor.
May 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
We have a Maytag front load washer Model MAH 4000 AWW
tHE PROBLEM IS YOU NEED TO CLEAN YOUR SOAP, SOFTENER AND BLEACH DISPENSER, REMOVE THE BLEACH AND SOFTENER DISPENSER TRAY, AND YOU WILL FIND THAT IF YOU HAVE BEEN USING LIQUID SOFTENER, THAT IT HAS GUMMED UP AND CLOG THAT AREA AND IS CAUSING SPILL OVER. WHEN THE WATER IS POURED INTO THE TRAYS TO DISPENSE THE BLEACH AND OR SOFTENER.
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code ''oe'',
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual, it may not be there, they want a tech to come by to make more $). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum) Of course some direct the hose into sink, fine. Snaking out your standpipe would be good too.
Rate me nice or not at all. Happy spinning! Nice to watch the machine spin, not your head!
Mar 04, 2009 | Washing Machines
Maytag Neptune MAH6500A Front Load Washer Logo
147 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
