Question about Whirlpool 19.8 cu. ft. Side-by-Side Refrigerator ED20TQXF
Thermostat control Dear Experts, I have this Whirlpool side by side refrigerator model EP20PKXWN00. This has a thermostat controller - control knobs for the freezer (A B and C) and refrigerator (1 2 3 4 5). I had turned the freezer to B and the ref between 3 and 4. I was surprised that it defrost by itself after running the unit for 5 hours and the water lid pan almost filled up with water. I had it drained and adjusted the control to lower. Freezer to A and Ref to 2. Again, it auto defrost after an hour and I have to drain the water again from the lid. Every day, I have to drain the water from the lid! I just bought the unit from a couple who left to Canada for good. I had it running this only for 3 days and it's a bother that I have to watch the lid to keep it always dry. Is this normal? Or somethin wrong with the control? Please help. :(
  • 1 more comment
  • joso2003 Jul 29, 2008
    It's just a bother that draining the water from the lid happens to be everyday. This unit has 3 controls ( the freezer, refrigerator and also the moisture control). I happened to lower the thermostat to warmer for the freezer and at knob turned to 2 for the refrigerator. I observed that it defrost every an hour and water drains after 8 hours. And now, I put it back to B for the freezer and between 3-4 for the refrigerator. The current is okay now but need to wait for sure after 5 hours it will auto defrost and will drain water again and has to dry the lid to avoid overflow or will mess the floor under. Dear expert, is there any other way to lessen my time watchin and dryin the pan everyday? Or I have to anticipate the time for it? Please reply.
    Thank you 22ooper for your information. I really appreciate it! More power to you. Big thanks!
  • joso2003 Aug 06, 2008
    I just had my unit fixed with your helpful information. Thank you so much!
  • 828 Answers
Your system most likely has an automatic defrost system. The auto defrost system should actuate every 8 or 12 hours. Under normal conditions the water from the drain pan will evaporate between defrost periods. The defrost is controlled by a timer and NOT by the temperature controls.
Posted on Jul 29, 2008
  • James Helmer
    James Helmer Jul 29, 2008
    If you are truly getting excess water from each defrost you must look elsewhere for the source of the water. All items stored in the refrigerator and freezer should be stored in covered containers. Door gaskets should seal. Door gaskets can be checked by closing the door on a paper and feeling for resistance as you withdraw or slide the paper such as a dollar bill.
  • James Helmer
    James Helmer Aug 06, 2008
    You are welcome, it is the reason we are here.
Refrigerator is not getting cold
There is a small fan, behind an inlet panel, somewhere in the freezer. This fan is electrically inline with the refrig side thermostat. The refrig gets its cold from the freezer as needed via this fan. It is likely that the little fan motor has gone out. Usually when the freezer is working ok (although it can be "spotty" because its not getting proper circulation either with some models), but the frige is not getting cold -- it is because either this little fan motor has gone bad, or the thermostat it is inline with.
If you have a multimeter, you can check to see if 115 volts AC is being applied to the fan motor. If it is and the fan is not spinning then the motor is bad. If there is a lack of voltage, then the thermostat is bad. The thermostat sits behind the control knob for the refrig.
Good luck with it. If this has helped you, please take a sec to rate me. Thanks!
Don
Mar 18, 2012 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Motor is not turning on, I have to turn the knob back and forth
You will need to replace the thermostat in the unit.
Nov 18, 2011 | Refrigerators
Have a Whirlpool Gold fridge. Model #GB2SHDXTQ00. This week the fridge stopped working but the bottom freezer works fine. Is this just a thermostatic control issue? What part might be causing the problem? ...
Check the back wall of the freezer for frost . If there is then it is either the defrost heater, timer or thermostat. If there is no frost check to see if the fan in the freezer is running.
Oct 28, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Compressor on refrig/freezer not working, fan next to compressor stopped working also.
Sounds like you need to replace the thermostat which is located behind the refrig control knob . Tap on the knob and if the refrig starts , replace the control behind the knob .
Oct 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frezzer stuck in defrost cycle
You have a bad thermostat . The piece the refrig temp knob is on ( not the freezer knob , it works off an adjusting rod ) .
Nov 12, 2009 | Kenmore Refrigerators
I had a problem getting the ice bin back into my 1990 model side-by-side Sears/Whirlpool refrigerator. Several hours later I notice that everything was getting warm and the ice was defrosting. The...
Perhaps I was mistaken, but I thought your website was a source of information about my problem. I have received no input. Please delete my request.
Jun 24, 2009 | Whirlpool Refrigerators
Fridge is freezing
there is a way to adjust it but its very difficult..best to just replace it. the thermostat that is.
Jun 09, 2009 | Whirlpool ED2FHGX Side by Side...
We have an older model whirlpool and cannot find the freezer control dial. But, we easily found the fridge control dial. Could you help me with this? the model is ET8W/TK/ET/8WTM
if it is not in the center of the back of the freezer then it may not have a control for the freezer. the control for the freezer is just a flap that allows more or less air into the refrigerator side. so the only thermostat in a refrigerator is the one in the refrigerator side.
Jun 28, 2008 | Whirlpool Refrigerators
Kenmore refrigerator 26' side-by-side Model 596.52673200
on the amana rifg pull both knobs off
on the right side of control panel remove a 1/4 in screw
remove plastic panel now u can get too the part
Jun 10, 2008 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
134 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
