Question about Acer Aspire 5600 Series 5630-6951 Laptop
Aspire Drivers Hello! How are you? I mis place my Laptop Drivers CD. Now i have No idea how to instal drivers in my laptop.
  • Daniellex08 May 11, 2010
    i dont understand what you are asking..
There on the acer website, just download them, i had same problem
Posted on Aug 04, 2008
Just had new harddrive installed on laptop, now the wireless and blue tooth buttons on the front wont come on. any ideas please
the problem could be in not turning on bluetooth nor wireless. As you have installed new hardrive, you have probably changed the system, so you need the drivers for your laptop.
Does everyting else work fine like before? In case not, you need the drivers(check this link)
In case yes, just try to activate either bluetooth or wireless like you have done it with old harddrive, and let me know.
Lucas
Jul 08, 2011 | Acer Aspire 3000 Notebook
How to reomve a faulty CD/DVD drive from the Acer Aspire 5510 to enable replacement.
Hello
With a number of software manufacturers using DVDs to distribute their software releases, having a Acer Aspire 5510 DVD-ROM Drive is not only convenient but is practically essential to keep up with software releases. Unfortunately, if your laptop doesn't have a DVD drive, installing one isn't quite as simple as it would be if you were installing the drive into a desktop computer. This doesn't mean that installing a laptop DVD drive is difficult, provided you purchase one that is compatible with your laptop. 1. Check to ensure compatibility between your laptop and the Acer Aspire 5510 CD-RW Drive you purchase. The best ways to do this are to purchase your DVD drive directly from your laptop manufacturer, look for compatibility information on the drive's packaging or ask a knowledgeable sales associate. If buying online, make sure to read all of the drive's profile to check for compatibility information. 2. Remove the Acer Aspire 5510 DVD-ROM CD-RW Combo Drive that your laptop currently has. Flip the laptop over, setting it on a sturdy surface with the side that the existing drive is on facing you. Depending on how the laptop is designed, you should find 1-to-3 screws holding the drive in place; these screws may be on the bottom of the laptop or on the side next to the drive. Unscrew the screws and set them aside for later use. 3. Flip the laptop back over. Carefully remove the old drive, pulling gently yet firmly if you encounter resistance/ This will be the drive unplugging from the laptop's drive interface, so a small amount of resistance is not unusual. Once the drive is free of the laptop, set it aside. 4. Slide the new Acer Aspire 5510 Combo Drive into the empty drive port. Make sure that you press it all the way in so that the drive will plug in to the drive interface. Once the drive is in completely, replace the screws to secure the drive. 5. Boot up your laptop. Your operating system will detect new hardware and will load temporary drivers for the DVD drive; insert the driver disc that came with the drive to install the manufacturer's drivers in order to get optimal use out of your new Acer Aspire 5510 DVD-ROM CD-RW Combo Drive.
Hope this helps, if so do rate the solution Good Luck
Jan 10, 2011 | Acer Computers & Internet
I have aspire 4520 acer laptop.after formatting c drive and installing xp sp-2 ,audio device is missing,kindly advice the solution?
You need to install the support programs for your laptop motherboard. These are also called your "laptop driver software" which is usually shipped or packaged with your laptop. In this CD or DVD Installer, all hardware devices must be well supported by their compatible software drivers.
Now look for the CD/DVD Installer and install the drivers.
Jun 09, 2010 | Acer Aspire 4520-5141 Notebook
I have a aspire 5735 and i can't get it to see any cd on the desk top
Unless you have created a shortcut on the desktop for the cd-rom drive, you will have to go into "My Computer" and unless you are having drive issues, you should see the icon for your drive there. If you would like to create a shortcut on your desktop, right-click on your drive icon and select "create shortcut". It may tell you that "it cannot create an icon there would you like to place it on the desktop", click yes.
Oct 30, 2009 | Acer Aspire 5500 5570-2609 Laptop
I had laptop model acer aspire 4930 and i install
go to www.acer .com, download/support, model of your laptop and download the driver for its lancard.
Aug 14, 2009 | Computers & Internet
Acer aspire one won't see my olympus SD MASD-1 micro SD attachmen
You may need the card reader drivers installed. What is the exact model (110, 150, D150?) and operating system of your laptop?
Drivers can be found at the following link given the model of laptop, I can help you find it further if you provide the requested info above.
http://support.acer-euro.com/drivers/downloads.html
Mar 12, 2009 | Acer Aspire 4315 Notebook
Motherboard Acer Aspire 3680
hello,
after installing the operating system, download and install the system and device drivers from Acer Europe .
here's the link:
http://support.acer-euro.com/drivers/notebook/as_3680.html
or
ftp://ftp.work.acer-euro.com/notebook/aspire_3680/driver/
or
if your laptop cames with a Driver CD with windows xp drivers in it, insert it on your CD/DVD ROM Driver and follow the instructions on the screen...
hope this post can help you...
Aug 07, 2008 | Intel Motherboard
Mis place Drivers CD
You can go to acers website and download the drivers you need.
Jul 29, 2008 | Acer Aspire 3680 Laptop
Acer laptop motherboard cd missing
go to acer.com select your products model, then see for any support links for the product, go to the product support page, on this page you will have the necessary drivers for your acer laptop, download all the necessary drivers to a safe place, Now you can format your laptop.
Feb 08, 2008 | Acer Aspire 5610-4648 Notebook
Sound Driver Is Not Supporting
Dear Abdul Raheem
These Server Operating systems have compatibility issues with some hardware. I would do the following:
Get updates from the 2003 Server site; it checks for drivers also and updates them.
Write Acer Tech Support, tell them you want updated drivers for XXXXX soundcard.
Put your CD with sound drivers in drive. Go to hardware install in C-Panel and ask it to search for updated drivers on the CD. Or Right Click My Computer> Properties> hardware and select the yellowed gizmos. One of them will be your sound. Right click and select UPDATE DRIVER with the CD already on drive. Follow instructions. If you don;t have such a CD for your soundcard, find the drivers from Acer tech Support.
Barabara?
Nov 22, 2007 | Acer AOpen AW 200 Sound Card
Acer Aspire 5600 Series 5630-6951 Laptop Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
