Question about Bosch 24 in. SHU43 Built-in Dishwasher
Won't stop pumping
We inherited this dishwasher when we moved into a house two years ago. It's been fine but on Christmas Eve (brilliant timing...) it stopped working. Basically the hole in the bottom of the machine where the filter is has water pumping through it but it doesn't reach the spinning arms. More worrying is the fact that when you open the door it normally stops the machine. It didn't. The pumps keeps working and doesn't stop at all. If you left it it would still be going 24 hours later. We left it for a few days whilst looking at new dishwashers and then I thought I'd try it again, and hey presto it was fine three days later. Anyway, six months later it's started to do the same thing but doesn't look like it's going to right itself this time. Any ideas as to what it might be? I've tried reseting it by holding the reset button for three seconds. It flashes END, I turn it off, but when I turn it back to a cycle number it carries on working before I've even pushed the START button, just pumping away....
  • Daniel Mairani
    Daniel Mairani Aug 11, 2008
    dishwasher shu5313cu/12 bosch. the pump won't stop pumping and no other cycles work. only on/off. ???solution??
  • android1968 Sep 16, 2008
    Many thanks for your advice.
    I had actually found that this was the problem after trawling through the site. Annoyingly I'd paid for a one to one chat with one of the experts who just told me that the control board had gone and that I needed to call a Bosch engineer... mmmm, I think I could have done that off my own bat anyway! Anyway I was advised to remove the machine from under the kitchen unit and tilt it through 45º which I did, got very wet feet, and hey presto, it worked. They have since refunded the money for the nothingness advice they gave....
    Thanks again
  • 39 Answers
H android1968 and danimaldds
The reason it keeps running is because there is water in the pan under the dishwasher. firs this to do is shut the power off, then take the kick plate off, remove all the water that you can. this should fix it , if it happens again there might be a leak from a seal or from suds. hope this helps
Posted on Sep 16, 2008
Store costco opening time in quebec
M-F 10:00am - 8:30pm
Sat. 9:00am - 6:00pm
Sun. 10:00am - 5:00pm Christmas Eve
9:00am - 5:00pm
Christmas Day
Boxing Day
1:00pm - 6:00pm
New Year's Eve
9:00am - 5:00pm
Dec 17, 2016 | Office Equipment & Supplies
LG Dishwasher LDF6810 - does not operate. Stopped
now now ..check float valve to see that it is not sticking also I am sure you have heard this before Is it still under warranty if so call them and get them to deal with it saves you the head ache and a very Merry christmas and a happy new year to you and yours ..from the snowy north way up Canada Way
Dec 25, 2009 | LG LDF6810 Built-in Dishwasher
Water will not drain out of dishwasher
I would remove the drainhose from sink and try draining in to a pale.if it does not then you will need to remove drain hose and clean out.Also you may need to clean out all screens in pump just remove with torx screwdriver easy when you get into it
Mar 12, 2009 | Maytag MDB9600A Jetclean II Built-in...
Dishwasher not pumping water
anti flood mechanism activated in base pan you have a leak once the anti flood is activated in puts the machine into permanent drain thats why it runs even with the door open but only runs the drain pump not the wash pump.
Mar 01, 2017 | Bosch 24 in. SGI43E05GB Built-in...
My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Jan 29, 2008 | Smeg 24 in. DWF612WH Free-standing...
Neff dishwasher continuously attempting to pump out water
I have just encountered the same problem on my S5433 XO GB/13. Did you manage to get a solution.
Jan 17, 2007 | Neff 24 in. S5443X2 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
185 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
