Question about Hotpoint Ultima WF860 Front Load Washer
Wf860 Error Code: F10
Intermittantly my machine, WF860, stops, empties and displays F10, can anyone help?
    Scholar:
  • 97 Answers
Hiya
this could be caused by a faulty pressure switch (controls water levels). but due to the machine sharing the same electrical components as indesit it could be a fault on the main pcb.
hope this helps
please dont forget to rate the helpfuness of this reply, thanks kj
Posted on Aug 01, 2008
What is f4 and f7 error code
F04 Error code is "Pressure switch jammed on empty"
F07 Error code is "Heater relay stuck"
Both would require you to dis-assemble the washer to get to each part for checking / replacing.
http://www.hotpointservice.co.uk/help-and-advice/error-codes/
Sep 03, 2014 | Hotpoint Ultima WF860 Front Load Washer
F-10 fault code
F10 is indicating pressure switch not sensing correctly.
Check connections from pressure switch to module.
Please rate my solution.
Thanks.
Nov 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hi I have a hotpoint washing machine model wt761 and it has stopped working, it will not drain. The display is showing an error code F-05. Can you help me please.
You have a blockage not allowing the drum to empty.
Check for blockages via the pump filter and the hoses
F05 means blocked pressure switch
If it still won't work come back to me
Oct 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF860 Washing Machine displaying error F-65
there is no F65, perhaps it's F05 which means it will not empty water (not oumping out). Should av gone to specsavers !
Apr 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error F10
There is a topic alryde about the F10 error
You will get your answer here
http://www.fixya.com/support/t1461650-wf840_f10_error_code_get_worse
Good luck to you!
Please take a moment and rate my answer
Nic
Feb 06, 2009 | Hotpoint Ultima WF860 Front Load Washer
Wf840 f10 error code get worse
F10 is indicating 2 possible probs with your m/c.
1-interrmittent cold water supply, check pressure and hose.
2-water level switch not sensing correctly, possibly sticking or partially blocked.
Hotpoint recommend calling an engineer for a pressure switch prob. but there callout is £90.00!!!!!.
Plz rate my solution.
.Thanks
Dec 31, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ctd 80
The error code F10 is common of heater open circuit or one shot thermostat open circuit.
F8 is indicating static heater relay contact welded closed.
You need to call an engineer.
Oct 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint washing machine WF860 F-08 error, does anyone know how to fix this
F08 error code: for hot point washing machine indicates Heater control or NTC (Thermistor) temperature sensor problem.
hope this helps
Sep 29, 2008 | Hotpoint Washing Machines
Hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
755 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
