Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Ice maker The ice maker stalls during harvest. It will complete cycle sometimes if given enough time. I believe there is a heater under the tray. I don't feel any heat when tring to harvest. Could this be the problem. Is it more likely the heater or the controls?
    Scholar:
  • 67 Answers
This should fill up automatically. It takes 24 hours to have that basket full of ice cubes it might take longer depends on conditions. The arm inside is what controls the ice maker, make sure it's facing downward. Give it a change. You can take out the basket also to inspect problems. If you don't see what you any ice cubes in 24 hours then have that service. Or you can do it yourself if you want.
Posted on Jul 30, 2008
Have replaced everything and ice maker still doesnt work model ed5shaxmb10
An ice maker has 3 basic tasks:
1. Call for water.
2. Freeze.
3. Harvest.
Then the cycle repeats. There will always be some sensors that determine timing of those tasks. Home units usually have a bin level sensor (often an arm that's lifted as the bin fills) that can be locked in the up position to disable the ice maker.
If it's calling for water but not freezing, make sure the condenser is clean. (Sometimes they look clean but are plugged in the middle.) It has to get down to nearly 0 degrees to efficiently make ice, if it's not getting cold enough you may need a tech to figure out why.
If there's ice in the tray but it's not harvesting, clean the tray, hard water deposits can make the cubes stick in the tray.
May 26, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
My ice maker has ice in the tray but not dropping in Ben,it is a kfil27cxmso there is a lite that sends a beam across ben ,how do I check to see if the bulb is blown or working, gk
Hello George;
My name is Peter. I am a retired field service technician.
I live in Baltimore, Maryland, USA.
All ice makers work in the same way.
Your fill cycle is working fine. You have a thermostat in your ice maker which tells your ice maker control module (Computer) that the ice cubes are frozen and ready for harvest. Then, then control module tells the cube tray heater to turn on for so many seconds, followed by the control module to activate the harvesting motor.
So, your ice maker either has a bad thermostat, heater or motor.
The beam across your freezer section is a safety device. On the right hand side is the transmitter. On the left hand side is the receiver with a plastic flapper. When you close the door the flapper closes and completes the signal to discharge ice. When you open the door the flapper pops out blocking the signal.
Dec 02, 2014 | Refrigerators
WHY scotsman iec machine shuts down on the refridgeration light ON CM3 CONT
Is the machine producing ice thick enough to come off the evaporator plate? the machine will try to harvest 3 times before it locks out on long harvest. Harvest cycle: The compressor and hot gas valve are both powered during the harvest cycle. The fan and pump are off at this time. The machine stays in the harvest cycle until the evaporator thermistor senses 52 DEG F. If the bin is not full, the unit goes into another freeze cycle. I would check the Thermistor
May 28, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman ice maker cme 506 makes ice and turns off and blinks refrigeration
First check to make sure condenser fan is running during freeze cycle. Now check to make sure condenser coil is clean. Her is all the specks on the machine.
1. Ice production ( 500 at 70/50
2. BTUs per hour ( 7000)
3. Maximum times in Minutes. ( 50 freeze, 14 harvest.
4. Refrigerant charge ( R-404A ) ( A-D series: AC 32oz, WC 20 oz. E series AC 23 oz, WC 14 oz, F series AC 23 oz, WC 13 oz
5. Suction pressure ( PSIG ) 35-37 - end of freeze, 120-125-Peak in harvest.
6. Discharge pressure ( PSIG ) 240-260- 5 min in freeze.
165-175- minimum in harvest.
7. Metering device.( TXV plus distributor, E series and higher have two TXVs. superheat 3 to 15 deg F.
8. Average comp.amps. 10-11 during freeze, 11-12 during harvest.
9. Batch Weight. 6.5-7 lb
10. cycle time, 23 minutes @ 90/70. 19 minutes @ 70/50
Feb 24, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
The ice stripper on my icemaker has warped. Its
when ice maker goes into harvest the unit stall on the ice /the heater comes on and when tray is warm the ice moves out on the stripper . . i would think the tray is loosing its coating and the ice does't release and the heater stayes on too long . may have to replace the mold or ice maker .. ****
Jan 18, 2010 | Refrigerators
Water leaks from ice maker
Good day,
When the ice maker harvests, near the very end of the harvest cycle, contacts in the ice maker send power to the water valve in the bottom back of the machine, for a period of 7 seconds, after which, the water valve must shut off smartly.
Appears the valve doesn't close fast enough, or completely.
The solution, is to replace the water valve. No repairs to it are possible.
Before doing that, make sure the fill tube is lined up properly going into the back of the ice maker.
Thank you for using FixYa
WHIRLPOOL MODEL ED5NHA NOT MAKING ICE, IN DOOR WATER DISPENSER WORKING FINE, ICE CUBES ARE IN THE MOLDING TRAY, BUT WILL NOT GET EJECTED. FILL TUBE DOES NOT APPEAR TO BE FROZEN?
Most likely the thermostat # 27 in photo below is defective. It tells the ice maker to begin its cycle by sensing the water is frozen. It is a replacale part.
e301f6a.gif Photo of thermostat 627985
aebc09a.jpg You can see or order the thermostat Here 627985
Or you can order the complete Ice Maker Here 2198597
If you need more help feel free to let me know, Thanks Sea Breeze
Oct 25, 2009 | Frigidaire FRS26H5AS Side by Side...
Ice maker quit working
check the teperature of the freezer compartment . the ice harvest actuates on teperature. and refill with water at the end of harvest cycle.. a lot of times the condensor under your fridge can become plugged with dust and the freezer teperature never achives low enough to harvest ice..good luck
Oct 06, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice Maker water keeps running
Bad I/M, won't shut off after harvest and continues to restart cycle. Heater in I/M should warm up thermostat after first harvest and stop unit from recycling.
Jul 13, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Scotsman dc33pa ice maker
Make sure the curtain is not torn and there are no leaks from the resivoir. If ok check to make sure you have enough water pressure to the machine. Make sure you have enough water passing through the valve during harvest cycle. To check... turn the timer cam to harvest cycle. Water should come in quickly behind the curtain on the right side and the timer should advance three minutes to freeze portion of cycle and stop running. Water should spray and form ice for approximately 25min. Then the timer advances for 5 minutes into harvest cycle and it refills with water again.
Nov 21, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
93 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
