Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
The WD mybook gone from my network
I ve been running the drive for some time know with no issues, however last week it stoped appearing on my network and I cant access the web interface as well. I connected it to my iMac but still couldnt locate it. Please tell me what to do all my files are in there...
    Sergeant:
  • 300 Answers
Oh boy , you need to tell me everything you can about what kind of network you have
what kind of computers are connected to said network
I need router names
I need all the data you can give me
I need more information before I can begin to help you on this.
shalom
Posted on Sep 11, 2008
My Western Diagnostic My Book is not showing up in
That happened to me but with windows. I ended up having to burn a Knoppix Linux boot disc and when i booted up with Linux it was able to access the drive and i tediously backed up my files to another drive and formatted the broken drive and that fixed it. It was a while back so i may have forgotten something but having a Knoppix disc has gotten me into a lot of broken drives. Good luck.
Nov 13, 2012 | Western Digital WD My Book Live 1 TB...
My fridge has stoped cooling frezzer stoped last week dumped the ice out move frome wall started working agin for a week than stoped working yesterday WTF is was made in 06 is the compressure out or what...
you moved the fridge out from the wall and it started running again?try opening the fridge door and tap on the fridge control and see if it starts up.i,ve gone into houses and then the woman tells me when the fridge shuts down she hits the side and it runs again.it's the control,this could be your problem also,when you moved the fridge the control could have kicked back on.let me know what you find
Jan 13, 2011 | Frigidaire FRS-26DR7D Side by Side...
WD mybook 1TB is gone from the network
Have you tried different cables or a different port on your router. Is there any way to get into the Hard Drive by connecting it directly to a PC and checking the network settings or anything..? If not, then you may have to connect it directly to a PC and share it to your other PC's.
Sep 15, 2009 | Western Digital My Book World Edition 1TB...
WD My Book 1TB Ethernet seems to hang my USB ports on my notebook
Update your firmware, i had the same problem, i updated the firmware and everything works fine now.
Jul 04, 2009 | Western Digital Computers & Internet
Computer suddenly not recognizing relatively new WD MyBook 640GB
Just a shot in the dark, but ..., shut down your computer and unplug the drive. Turn the hard drive off, then back on. Plug it back into the computer and restart. If it doesn't pop up, restart your computer this time with it plugged in.
Is there any noise coming from the drive? Is the green light on the front?
The same thing happened to me and the same drive, but 500gb. I did the above and it fired right back up again. You may have to delete the trial version from the drive if it on there, or from your computer if you had originally installed it.
Jan 07, 2009 | Western Digital 320GB MyBook External USB...
Only showing as a network device on 2 of the 3 pcs on the network
Did u added the new network devices, or did u wait till thy popped up?
If u didn't added them manually, then go to networklocations, add network location, press next, and again next, then type in \\mybookworld\"here the name of the folder of your mybook, ex. Movies or music,.." (without " ")
Do it for every folder.
Oct 07, 2008 | Western Digital 500GB My Book World...
Trying to connect a Mybook 1Tb network drive to N1 Vision
Hi! I have an N1 Vision with similar problems. I have done some research and found that we are not alone with this issue! Two solutions are possible: 1) If yours is version 1 (1000) of the machine, Belkin recommends that it be swapped out for version 2, which apparently has firmware/hardware changes that fix this (unverified; it would seem to me that this would require a whole new DHCP approach) and 2) I've found that if you go through the process of unplugging the device for 2 minutes, replugging it and then refreshing the DHCP table, after between 1 and 5 iterations, the device should appear. I'd also advise you to shut down (for troubleshooting) the software firewall in the router (you'll still have the NAT firewall), that might eliminate a problem/conflict somewhere in your network!
Good luck and let me know if this helps!
Bob
Sep 23, 2008 | Belkin N1 Vision Router
I just drop my WD external hard disk (Please help)
When you drop your hard drive for more than a few inches, you just have to face the fact that the HD is dead, period. If for some miracle the drive still works, then it's the work of Jesus/Shiva/whatever deity of your choice. I'm sorry I can't offer anything more constructive. See Myth 24 on this page:
http://www.techarp.com/showarticle.aspx?artno=84&pgno=5
Sep 15, 2008 | Western Digital My Book Essential Edition...
How do you set up multiple WD Anywhere users on the network to share the same MyBook World Edition
hey,
-No WD Anywhere allows 5 users I think.
This could only be the solution, if you installed WD Anywhere on other PCs before
Check out the MioNet site, think they give options for new users.
if this is not the problem, I don't have a solution by now.
bye
Feb 08, 2008 | Western Digital 500GB My Book World...
My WD 500GB My book (world edition) keeps going offline
Is your drive warm/hot like mine was/is ?
Mine dropped offline 2 or 3 times a week.
Put a small fan blowing on it.... been up for two weeks now.
Sep 30, 2007 | Western Digital 500GB My Book World...
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
102 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
