Question about Quinny Buzz Jogger
Front wheel getting stuck
When I have my front wheel in the swivel position it is getting stuck sideways. This especially happens indoors on more slippery floors (such as supermarkets.
  • Anonymous Aug 07, 2008
    The front wheel has been getting stuck, making it difficult or sometimes impossible to continue pushing the stroller. The store where I bought it suggested removing the wheel, cleaning out the attachment piece, and putting Vaseline inside. I'm stuck on the first step - removing the wheel! I will check the manual to see what I'm doing wrong.
  • Anonymous Apr 17, 2009
    Indeed, how do you remove the front wheel?
  • 3 Answers
I have the same problem, was wondering if you can buy the double one for the front. Have used wd40 on wheel and this has helped a little.
Posted on Aug 06, 2008
Jane Rider front wheel swivel problem....they get stuck.
We have had exactly the same problem. We took the pram back to where we purchased it from and got the pram fully serviced, the back tyres were changed for a better quality all terrain one, and the front tyres were also changed with new bearings fitted. It works as good as new now, however I still think this is only a temporary solution... Interestingly we have only used the pram (from new) for just four months before the tyres completely deteriorated and we found the manoeuvrability a major problem.
Jun 28, 2012 | Jane Rider Pushchair in Buganvila
My Phil & Teds Vibe shakes in the front wheel uncontrollably. Do I need a new front wheel?
Hi!
Assuming your tyres have the correct pressure, uncontrollable shaking in 3-wheeld swiveling strollers is usually caused by bearing slack.
Please check the front wheel bearing. It should allow the wheel to rotate freely but it should not be loose on the axle. (ie. It should not slide sideways on the axle.)
In this case you would need a new front fork/wheel assembly.
Please let a dealer have a look at it. As the Vibe has not been around for very long, you may still have warranty.
I hope this helps.
Erwin de Raad
www.babycare.nl
Oct 13, 2010 | phil & teds Vibe Stroller
Front wheel wont swivel
check for missing bearings in the swivel section
loose or worn shaft
replace the front wheel swivel unit
May 07, 2017 | Phil & Teds E3 Twin Seat Jogger
Baby trend double jogger stroller pulls to the left when front wheel is in locked position AND front wheel wobbles (cannot push through it)when on swivel.
Hey! I just fixed my shaking wheel! There is a red lever above the swivel wheel. I pushed it up. And guess what... I can jog with my stroller!
Jul 03, 2010 | Baby Trend Expedition Double Jogger
My front wheel is sticking on my buzz. It gets
yes give it a good sqwert of WD40 and spin it round by hand till its free again it sounds like it may also be a bent shaft have you hit any big bumps? or has the baby put on a lot of wate?
Oct 24, 2009 | Quinny Buzz Three Wheel Stroller
Front wheels keep getting stuck in swivel postion
There is a company called Buggy Pit stop which valets as well as repairs pushchairs. I used them when i gave my old dusty broken pushchair to my sister. I had it repaired and valetted by them. They did a great job and they were not that expensive either.Hope this helps. Their number is 020 8861 0038.
Feb 15, 2009 | Valco Runabout Tri Mode Jogger
My quinny buzz front wheel keeps getting stuck half way and i end up trying to push the chair with the front wheel sideways which is impossible. i have been advised to clean the front wheel out as it gets...
First remove the front wheel assembly from the pushchair by pressing in the two buttons on the sides and pulling it out.
Now look more closely at the assembly - on one side, just where it bends at an angle you will find a small hole, a couple of millimetres across. Take a small screwdriver or some other thin object and push it into the hole a little way, which presses a metal catch inwards, releasing the swivel assembly. While continuing to push this in pull the swivel assembly apart - grasp the wheels in one hand and the L-shaped plastic housing in the other and pull them apart.
Now clean all the surfaces with a piece of strong cloth.
When all the surfaces are very clean, take a can of TEFLON SPRAY and spray it onto all surfaces that rub against each other, before reassembling the wheel unit. Silicon grease is a cheaper alternative, but the teflon spray is supposed to be the best for lubricating all moving parts on the Buzz. Whatever you do, don't use WD40.
Hope this helps! Dan.
Nov 11, 2008 | Quinny Buzz Jogger
Hauk infinity reversible pushchair, swivel wheels won't swivel
Removed the wheels and gave a little spray of WD40 lubricant, the wheels swivel perfectly now - very easy!
Aug 29, 2008 | Hauck I'coo Pico 4 Standard Stroller
Front wheels swivel and get stuck on each other
This is happening to my stroller and it turns out that the frame is bent. I have been unable to find a certified technician who is willing to fix it. I guess I can offer it for parts to someone.
Sep 24, 2007 | Valco Twin Runabout ATS Jogger
Front wheel problem with Peg Perego Aria single stroller
You need to regularly lubricate the wheels...Just get some WD-40 with the little straw attachment & spray into where the wheel meets the frame...Make sure you lubricate the wheels regularly...I had the same problem & call Peg toll free - that was the answer & it fixed my problem too!!
Feb 12, 2007 | Peg Perego Aria MT Rubino Standard...
Quinny Buzz Jogger Logo
303 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
