I have a GO Video DVD recorder/player. It will pay recorded DVD's but when I want to record on a blank DVD+R it indicats NO DISK. I have tried using a disk reader cleaner that did not fix the problem.
Did you finalize the DVD before you removed it from the VCR/DVD recorder? Until a disc is finalized, it won't work on another device. If you left some space, try to finalize it now. Does the disc play when in that Sylvania unit? It is possible that the unit is faulty and didn't focus the laser properly for writing to the DVD. (If you actually tried to burn to a CD and not a DVD-R, then no data was written to the disc. There are slight differences to the laser settings for CDs and DVDs.)
If you can't find someone with the same recorder you could try putting the DVD into a computer DVD drive. It might be possible to get the video files off the DVD. DVD files are called VOB. You can get free software that will play them. It might even rip the files from the disc for you. You can then transfer them to a DVD disc using the computer.
After recording a DVD in a DVD recorder you will need to finalize the disk. You should be able to put it in the original recorder and at least be able to watch the video.
If you are able to watch the video while you are recording then you should be able to record what you are watching. If you cannot see the video when it is sourced through the DVD recorder, then you need to adjust the input.
I hope this information allows you to resolve this issue. If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
The unit is saying that its an "Un-format disc" problem. Is this the only error code you are getting? Also, what types of DVDs are being used? As in, DVD-R DVD-RW DVD+R DVD-RW and what speeds? 1x 2x 4x 8x 16x?
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Failing to Finalize and thus making the DVD 'playable' on other DVD Players is most often caused by the media (your blank disk), not the Recorder. Trying another disk, from the same 'stack' or manufacturer will often have the same result. But, it is a 'hit and miss' situation. As you have the recording on the hard drive it can be worth your while connecting another basic DVD Recorder to input the material to a disk in that recorder. Sounds silly perhaps, but I have actually done this - and had the disk finalized in the second unit.
