Question about Arris DSR922
Cannot change/move satellite
Using the remote, when I choose a satellite to move to, the onscreen display indicates it moved, but the dish position counter does not move nor does the satellite. If I use the tuning buttons, the dish does move, but the counter on the display does not. This is a new problem - worked fine a couple of days ago.
  • wiley18 Jul 29, 2008
    Yes, this is a C band dish system. If I use the remote tuner (fine tuning once tuned to a satellite) the dish does physically turn. It's the display from the reciever that doesn't move (dish position numbers do not advance) and if I use the remote to change satellites - the display indicates I've 'moved' but the dish does not physically move. Only if I use the fine tuning arrows does the dish actually move.
  • 518 Answers
I assume this is an outdoor satellite dish system, like a c-band system? It sounds like the motor drive outside has a stripped gear on the main shaft. The motor is probably running and the sensor wheel is turning (making the unit in the house think the dish is moving) but the screw shaft is not turning.
Hope that helped
Posted on Jul 29, 2008
  • Gene Wells Jul 31, 2008
    That's very odd. "Usually" for the display to indicate the dish is moving, the sensor on the motor must be sending pulses back to the main unit, if not the unit "should" error out. Sometimes it takes a second for the unit to error, especially when fine tuning.
I have a Pfaff Creative 1473 and am having problems with needle position.
Hello Eelee
As long as the display indicates the change, the needle will move. The needle is not moving with pressing the needle position button because the needle is too close to the fabric .... if the needle is raise up by turning the fly wheel, it will then move according to the number indicated on the display for needle position.
Please let me know how it goes.
Happy Stitching.
Mar 11, 2017 | PfaFF Sewing Machines
Can't get the wireless to come on
Exterior Wireless Switch
Step 1
Position the laptop so that you're facing the screen and the keyboard is in front of you.
Step 2
Check the front edge of the laptop's casing.
Step 3
Identify the wireless indicator light labeled with a wireless antenna icon. The "On/Off" switch to the left of the indicator light is the wireless switch.
Step 4
Move the switch to the "Off" position to deactivate the wireless adapter or move it to the "On" position if you want to power on the wireless adapter.
On-Screen Wireless Switch
Step 1
Press and hold down the "Fn" function key on the computer's keyboard to display the laptop's hotkey card icons on the screen.
Step 2
Click the "Wireless" icon on the screen or press the corresponding hotkey button on the keyboard, typically the "F8" key on a Toshiba laptop.
Step 3
Click the "Wireless On" or "Wireless Off" icon in the options list below the hotkey card icon to activate or deactivate all wireless connections. If your laptop has Wi-Fi and Bluetooth connections, you can also choose to activate or deactivate these services separately.
if have drives problem you can download using this link
Sep 13, 2013 | Toshiba Satellite L505DS5983 Notebook
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Dec 29, 2010 | Televison & Video
After programming my NEW Harmony One Logitech remote I can't get it to change channels on the Dish HDTV DVR along with a bunch of other problems.
To control a Dish Network PVR/Satellite, it needs to be set to respond to the default Remote Address (1).
To reset your Dish Network PVR/Satellite to the default Remote Address:
1. Press SYSTEM INFO on the receiver's front panel. The System Information screen displays on the nearby TV and shows the Remote Address.
2. Using the original Dish Network remote, press and hold SAT on your remote control for about three seconds, until all of the mode buttons light up, and then release SAT.
3. Using the NUMBER PAD, press the 1 button
4. Press POUND (#). If you entered the address correctly, SAT will flash three times.
5. Press RECORD. Make sure the Remote Address you see on the System Information screen is 1.
6. Press the SELECT button on the front panel to close the System Information screen.
7. Your Harmony remote should now control your Dish Network PVR/Satellite box
NOTE: Dish Network PVR/Satellite receivers sometimes have two tuners, allowing them to be used in more than one room on different TVs. Harmony remotes can only control a Dish Network receiver's main tuner while still in the same room with direct line of sight to the device.
What other issues are you having with the remote?
Dec 25, 2009 | Logitech Harmony One Advanced Universal...
Can't find sat 129. Had to move dish to replace roof.
If you area aligning your dish yourself go to point dish screen ( menu 6-1-1) then highlight satellite and choose 129, use the signal meter and dish adjustments to locate 129 by getting a green siganl bar, (note: be sure you are standing behind your dish when aligning and not in front of it)
Oct 01, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Dish IR Remote 20.0 has problems after sunset.
The problem for me was the TV giving off IR signals that interfered with DISH's poorly designed remote. When the TV's room ambient light sensor was turned on and it became dusk outside the DISH remote would stop working. Moving the receiver away from the TV helps but the problem is not eliminated until the light sensor is turned off.
Until DISH corrects this poor design there may be no other viable solution.
Jul 09, 2009 | DISH Network IR Remote Control
Harmony 880 remote will not turn on my dish 622 satellite receiv
Have you tried contacting your dish people, maybe they can reset.
Mar 07, 2009 | Logitech Harmony 880 LCD Remote Control
Satellite won't pick up a signal
just keep moving the satellite dish untill its in a perfect position.
Dec 20, 2008 | RCA DIRECTV Satellite Remote Control
Sure you can, if you have Dish Network go to the receiver and turn the TV and receiver on. Then press menu-6-1-1. This takes you to the point dish screen. You will come out with better results using a compass to find the azimuth the dish should be pointed toward and bore sighting the dish by pointing it in that direction. You then will need to move the dish in very minute increments pausing for 15 to 20 seconds after each move to ensure the satellite signal can be found. If you have ran a check switch prior to this and have lost all satellites you more than likely will not receive a signal until you run another check switch and have found the signal of at least one of the orbitals. If this proves to be to tedious and many times it will you can usually find an inexpensive signal pointing device at a store like Radio Shack. Hope this is some assistance to you. Let me know if I can be of additional assistance and thank you for using Fix Ya.
Oct 07, 2008 | Televison & Video
Televison & Video Logo
259 people viewed this question
Top Arris Televison & Video Experts
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
