Question about Frigidaire Kitchen Ranges
Frigidaire Range model FEFL79DSJ has electronic clock/timer
My range was doing just fine the other day and suddenly it stopped working. The clock was black and all the eyes were not working. Strange thing however, when you turn on one of the eyes, the oven beeps and the clock lights up and the oven controls seems to work, but they don't.
Your help would be appreciated.
Thanks,
  • 3 more comments
  • letsroll Jul 29, 2008
    This is a oven/range not a refrigerator.
    Thanks,
    If it is the electronic timer, could it affect the cooking surface also?
    How would i know if it is the clock/timer? Based on my description, does that seem probable?
    See Comments
    Yes it was.
    Thanks,
    Genius:
  • 1,011 Answers
Dear Sir/madam,
Connect an ohmmeter across the terminals and advance the timer to see if the switches
are opening and closing OK. If not or the motor doesn't run - replace the
timer. Since the burner is
inside the oven, you cannot immediately see if it has ignited. Different manufacturers have designed
different methods of keeping the
gas safety valve closed, until ignition is guaranteed. The oven
thermostat valve is set by hand to control the oven temperature. In some types of systems, the
thermostat is not a valve at all, but an
electrical switch that opens and closes by oven temperature.
The
gas safety valve prevents gas from flowing to the burner until ignition is assured. If it has an
electrical thermostat, it cycles the safety valve. On and off as long as there is ignition.
Thanks
Good luck
Don't forget to rate the solution
Posted on Jul 29, 2008
  • Asfiya Ahamed
    Asfiya Ahamed Jul 29, 2008
    Dear sir/madam,
    Try to remove the power from the oven for a few minutes and then turn it back on. If it would not help,I think this is a bad clock ERC and also a Bad sensor Probe. This can be fix by a service centre only. So call the authorised service for more help.
    Thanks
    Good luck
    "Don't forget to rate the solution"
  • 3,037 Answers
If it is the clock timer/control panel, it would affect the cooking top, they are interconnected
  • Benjamin Patri
    Benjamin Patri Jul 29, 2008
    If the oven controls aren't working, then replacing the control panel is the answer. They wouldn't be lighting up if they didn't have power. As long as nothing is working then everything points to the controls of the oven. Many ovens have their control panels go out over time at least the newer systems as nothing is made as it used to be.
    Genius:
  • 1,665 Answers
Type in your model number at link to see for any parts available
  • 2,071 Answers
WHAT IS WRONG WITH YOUR RANGE / STOVE / OVEN?
Frigidaire Range model FEFL79DSJ has electronic cl - small_13_33.jpg For a detailed Range/Stove/Oven illustration, click below.
redarrow.gif Gas Free Standing
redarrow.gif Electric Free Standing
Gas Cooktop
Electric Cooktop
redarrow.gif Gas Walloven
redarrow.gif Electric Walloven
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It's stopped completely
It won't bake
It bakes poorly
It won't broil
A burner doesn't work
A burner works only intermittently
I can't adjust the burner temperature
It won't bake or broil
The clock stopped
The temperature is wrong
The oven light doesn't work
There's a self-cleaning problem
The oven door won't close
An indicator light doesn't work correctly
The oven is hot on the outside
I see sparks!
The drip pans need replacing
    Guru:
  • 1,894 Answers
Microwave door switches are simple on/off devices that keep the microwave from running when the door is open. Microwave door switches are usually black and are about an inch long. They have metal terminals on the end that make contact with the door hook or latch. This completes the circuit which allows the microwave oven to run. Without this contact, the microwave will not operate. Check the door hooks and the door-release. If one of these is faulty, the door switch won't activate, and the oven won’t work. If you suspect that the thermal fuse has blown, call a professional appliance repair person. Even an unplugged microwave oven can kill or seriously injure someone. This is because there is a high energy capacitor inside the microwave oven case. If it is not discharged properly, you could be electrocuted.
  • Frigidaire Master
  • 19,396 Answers
Try firs disconnectting fridge power plug for five minutes, possibly defrost overnight
  • 2 more comments
  • Ginko
    Ginko Jul 29, 2008
    Sorry I posted in wrong place, in your case disconnec oven power plug to see if it reset, check if the ignitors start, at a glance your problem looks like a faulty control panel.
  • Ginko
    Ginko Jul 29, 2008
    The oven panel seems to be faulty, it should be tested using a multimeter and eventually replaced. You can find replacement for your appliance here.just insert model number (not model name) in website search box.
    You have model number printed on a plate at the back or at the side of the oven.
    Many oven also have a door switch that prevent burner and ignitor from burning when door is open, also check that ithis is not stuck.
  • Ginko
    Ginko Jul 29, 2008
    Yes, if the timer is shorting for example, none of the ignitors will start.
  • Ginko
    Ginko Jul 29, 2008
    Let us know if you need further help.
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
I have a ceramic top slide in range. The clock will light up when the clock button is pressed but will not stay lit. Timer works and all oven controls work as well as the cook top and oven. Any...
Hi Friend, this is Z. Thank you for your post!
Based on the symptoms you are describing, it appears your Frigidaire range is possibly experiencing a potential wiring failure or a communication problem with the EOC (Electronic Oven Control). Try unplugging your range or flipping the household circuit breaker off first. It is good to wait approximately ten minutes and then turn on your range. If the issue continues, then I recommend contacting a professional to make a precise diagnosis.
May 21, 2014 | Frigidaire 30" Self-Cleaning Slide-In...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Frigidaire Gallery Professional Series Stove and Oven unit. The oven temperature indicator light has been fading for years and is now barely visible. Everything else on the control panel (timer,...
Hello arab125 - I understand that the timer and clock works fine, however from what you have described it sounds like the range could possibly have a wiring failure, faulty sensor, or an issue with the EOC. I would suggest contacting a professional to move forward accurately.
Oct 08, 2012 | Frigidaire FGEF3031KB Gallery 30"...
F1 fault when oven is just sitting.
There are several sufix numbers after your model number so I just picked one, They are often the same as they usually keep the same wiring harness and circuitry through out many.Here's what I've found, Electronic control has detected a fault
condition. Press CLEAR/OFF to clear the display and stop the
beeping. Reprogram oven. If fault remains, record fault number.
Press CLEAR/OFF and contact a Service Professional. See:
https://www.searspartsdirect.com/partsdirect/user-manuals/GLEF396ABA-Frigidaire-Parts-Range-Parts-manual#
or choose from your complete model number:
https://www.searspartsdirect.com/model/search.html?q=GLEF396
Good luck
Oct 30, 2017 | Frigidaire GLEF396 Electric Kitchen Range
Electrical panel went blank. Hence can't operate the oven. Stove works fine.
Hi. Interesting. My Figidaire Gallery Professional gas stainless went blank 2 days ago. Model FGF379WECS. So I'm googling...
Your Service Manual is located at (document #2 in link):
http://www.retrevo.com/support/Frigidaire-GLEFM397D-Ranges-manual/id/2367bh351/t/2/
Part Number
316418704
Description :
Clock/Timer, electronic, w/mini oven, ES510
Rick
May 15, 2010 | Frigidaire Gallery GLEFM397DS Electric...
My stove works but my oven wont, and the light of the oven wont turn off
Without a model number, my guess would be a stuck relay in the electronic clock/timer. Replace the Electronic clock/timer.
Jan 29, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire electric range fef336 heating elements not heating
Range does not heat (lights and timer do not operate).
This would indicate the range is not receiving the required 220 volts. Check house hold breakers or fuses, open wiring between the terminal block and the components, and the power cord.
Please leave a rating!
Jan 31, 2009 | Frigidaire FEF376 Electric Kitchen Range
No display - oven/timer/clock inop.
Most likely control / clock has gone bad and needs replacing
Nov 11, 2017 | Frigidaire GLEF396 Electric Kitchen Range
Kitchen Ranges Logo
362 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
