Problem with printhead please consult user guide
  • 656 Answers
Use the printer's utility program to self-clean the printer. This process may need to be repeated as many as 5 to 10 times. Often this will resolve the problem.
Turn the printer off, preferably overnight, if the self-cleaning utility has not worked. The ink may need to soften before the self-cleaning utility will be successful. Turn the printer on and try the self-cleaning utility again several times.
Determine from the owner's manual where the print head is located. Epson printers, for example, are usually in the printer. Many other brands place the print head in the cartridge.
Remove the cartridge. For models where the print head is in the printer, drop seven to 10 drops of isopropyl alcohol (rubbing alcohol) down the ink receptacle area. This is the hole where the ink flows into the head from the cartridge. Run a few self-cleaning utilities. If necessary, allow to sit a few hours or overnight and repeat the self-cleaning utility.
Soak the cartridge print head in hot water if the print head is in the cartridge. Allow to soak overnight. Dry the print head area with a paper towel. Repeat the self-cleaning utility.
Place the cartridge print head in isopropyl alcohol if the hot water soak did not unclog the print head. Leave the print head covered in alcohol overnight. Use a damp paper towel to wipe off the print head area. Dry carefully. Try the self-cleaning utility again.
Purchase a new cartridge if the alcohol soak did not unclog the print head in the cartridge. This will provide new print heads that won't be clogged. Contact a service technician for repair of print heads in the printer if the alcohol did not unclog the print head.
Posted on Mar 01, 2011
SOURCE:
SOURCE: my Lexmark is X6100 Series - Cartridge Error 50C consult user guide
The cartridge has a short in it and needs to be exchanged for a non-defective one.
Posted on Feb 02, 2008
57 varieties
  • 1653 Answers
SOURCE: Cartridge Error 50C consult user guide. I
Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Posted on Nov 10, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: Message:" There is a problem with the printhead.
    Make sure your printer is updated. The firmware update, available in the Lexmark website, will help fix printhead-related problems. Follow these steps: 1. Remove the printhead from the printer.
    2. Reset the printer by unplugging the power adapter from the printer (should be the whole black box on the back of the printer), leave it unplugged for about a minute then plug it back in.
    3. Once the printer is back on, it will ask for the printhead. Just disregard the message by pressing or CANCEL button on your printer screen. Do not install the printhead yet.
    4. Then, please use this link: http://bit.ly/p705fw to download and run the firmware on your computer. Please make sure that the USB cable is attached from the printer to the computer while you do this.
    5. Once the firmware update is complete, you may reinstall the printhead.
    Posted on May 04, 2011
    printmastert
    • 3344 Answers
      Verified Fixya Pro
      SOURCE: I have a lexmark prospect
      Updating the firmware for your Lexmark Pro200 series will help fix this problem. You will need to get rid of the error first before you can successfully update your printer. Follow these steps: 1. Open the cover of the printer > Remove the printhead. If the printhead will not go to the center, turn off the printer and pull the printhead to the center. 2. Once you have the printhead removed, close the cover of the printer and turn on the printer. 3. It will ask you to "Open Cover to Install the Printhead". Press the Cancel (Red X) button. 4. It should take you back to the "Copy" menu. 5. Proceed with the firmware update. Just go to http://bit.ly/p205fw. There'll be more than one download for your model, try the top download first. 6. Once the firmware update is successful, reinsert the printhead by following the steps on your printer screen.
      Source: There is a Problem with the Printhead
      Posted on May 24, 2011
      SOURCE: printhead problem for dell v715w printer It reads
      You can download the guide from the Dell site... but don't waste your time. The printhead has a burned-up jet, and Dell charges as much for a printhead as for a whole new printer; just called them with the same problem. Cleaning it will most likely NOT help. The printheads are available on Amazon for around $55US. The printer is an awful ink-hog, and has terrible reviews on Amazon. Basically: open the top (below the scanner lid) and the printhead will center itself in the access hole. Pop the two ink cartridges out. There is a tab on the frame that carries the ink cartridges, towards the front of the printer; pull this (or push?) a little and lift the arm up (pivots at the rear.) The printhead will lift out (do so from the rear, where the ink latches are... it comes out easier this way.) Invert the printhead... you'll probably see four shiny gold "ribbons," one of which will be blackened. You can try wiping a lint-free cloth across this (coffee filters work well), but don't be surprised if this fails to help. I'm already shopping for it's replacement; last Dell product I'll ever own. They are an awful company to deal with.
      Posted on Oct 01, 2011
      Printhead replacement
      If all of your cartridges are good and full of ink and you have done all to clean and still cannot get printer to print a test page then your print head is fubar and in need of replacement. Not cheap and often better to get new printer than replace the print head.
      Sep 08, 2017 | Dell V313w AllInOne InkJet Printer
      My lexmark intuition s505 has a printhead error
      It sounds like a problem with the printhead. If your printer is still under warranty, please contact our technical support team to have the printhead replaced. You can find the contact details at support.lexmark.com.
      If it's already out of warranty, you can purchase a printhead here: http://bit.ly/IZYhWo
      Dec 02, 2012 | Lexmark Intuition S505 - multifunction ...
      Printhead problem
      It keeps saying that there is a problem with the printerhead. please consult users guide
      The error could be due to an outdated firmware version or a poor connection between the printhead and carrier contacts. Follow the steps below to fix the problem:
      1. From the printer control panel, press the Setup button > Maintenance > Replace Printhead, or for touchscreen panels, touch Ink Levels > More Options > Replace Printhead. 2. Open the printer cover. Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center. 3. Press the tab, and lift the latch. Pull up to remove the printhead. Close the printer cover then turn off the printer/unplug the printer from the power source. 4. Turn the printer back on. It will ask you to "Open Cover to Install the Printhead". Press the Cancel (Red X) button or the Home icon for the touchscreen panels. It should take you back to the "Copy" menu. 5. Proceed with the firmware update. Just go to http://bit.ly/p205fw. 6. Once the firmware update is successful, firmly re-insert the printhead.
      If error continues to display on the screen even after successfully updating your printer, it could be due a faulty printhead. Please contact Lexmark Technical Support Center or visit Lexmark's website for additional assistance.
      Jun 21, 2011 | Lexmark Prospect Pro205 Wireless...
      I have a lexmark prospect pro 200 series printer and there is an error message that reads "There is a problem with the printhead. Please consult User's Guide."
      May 21, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
      Apr 29, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
      Print Unable 36 LCD Screen on printer reads: Print Unable 36. See troubleshooting and routine maintenance chapter in User's Guide But i cannot find my User Guide can you please e-mail me what is in the...
      That error is a carriage travel error, the printhead is not moving freely. Most often paper scraps either on the extreme right side where the printhead parks, or on the extreme left side where it's hard to see.
      Feb 19, 2010 | Brother DCP 165C Compact Color Inkjet...
      671 people viewed this question
      k24674
      Marvin
      Marvin
