Plug the tip of the USB charging cable into the power charger port and plug the other end into the USB Power Adapter. Plug the USB Power Adapter into an electrical outlet. You will know that it is completely charged when the orange light on the charge indicator turns green.
Try resetting your Kindle. Turn off first then hold power button down for about fifteen seconds and it does a reset. This should correct the problem. Make sure you have a charger made for Kindle and not a generic one.
if you are new to this, then the green light should be charging and that was because your tablet ran out of batteries somehow (it happens) I hope I helped! :D
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device.
Make sure that the kindle is fully charged. When charging the kindle 3 will have a yellow light indicating that it is charging. When this turns green, your kindle is fully charged. Make sure your kindle is fully charged and then try turning it back on.
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
