Question about Sharp AR-M160 Laser Printer
Can't disable / remove "Print Status Window" on Sharp Ar-M160/M200
All I want is how to get rid of the showing Print Status Window. When I click on Option Tab, nothing appears enabled, I mean everything can't be changed or to have the possibility to choose another setting.
Thanks a lot
P.s. I have administrator rights on Windows
    Guru:
  • 1,049 Answers
Remove the printer software and use a generic Windows driver. That is the only way, since the status window is part of the driver software. If the printer is postscript enabled you can almost always use the HP laserjet 4 driver which is basically generic postscript.
Posted on Jul 29, 2008
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
My Sharp AR-M160 will print but not copy. No problem buttons are lit up but just dont work.
have you got the machine on print mode
if you find the button that says print copy fax on it press it until the light is on copy...
hope this helps
Jun 18, 2010 | Sharp AR-M160 Black and White Copier
Sharp AR-M160 A3 Printing
You need to contact Sharp ! !
They are the ones who developed the new Windows 7 drivers and now they are defective! Call them back (Sharp), and tell them they need to give you a new driver that will fix the A3 issue of your printer.
Mar 06, 2010 | Sharp Office Equipment & Supplies
How do I print (not copy) a test page from my sharp arm160 copier to see that I dont have a scratch on my glass?
Perform the following procedure to enter the simulation mode.
"#" key, Interrupt key, "C" key, Interrupt key
enter 64 press [START] key
enter 02 and select a cassette with the cassette select key and press
the [START] key
The optical system status is ignored and a self print is made.
Nov 30, 2009 | Sharp AR-M160 Black and White Copier
Where to get driver for Sharp AR-M160 for Windows 7
http://www.bioticaindia.com/ar-m160.html
Here is a link to a driver you can try. It is very possible that there is not a driver available that is compatible.
Thank you,
lee
Nov 10, 2009 | Sharp AR-M160 Laser Printer
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
Scanner problem
Here is a list of drivers.. Since I do NOT know your OS, this page has MANY OS options...
http://www.businessneedz.com/Sharp-AR-M160-AR-M205-Downloads.htm
Good Luck
May 30, 2008 | Sharp AR-M160 Laser Printer
Sharp AR-M160 , printing problem with OS: Windows 2000
Is the cable and the computer the same? sounds to me as if your not using a bidirectional cable
Apr 18, 2008 | Sharp AR-M160 Laser Printer
Sharp AR-M160 Laser Printer Logo
351 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
