Question about Admiral Refrigerators
Signature 2000 Refigerator by Admiral - Model HMG19294DB Freezer is not freezing and frost is building up in the freezer.
    Guru:
  • 1,894 Answers
Have you checked you evaporator coils?
Posted on Jul 29, 2008
  • dewan nafees ahmed Jul 29, 2008
    This is a common occurrence, and doesn’t always have
    a clear-cut solution. You’ll want to check the internal freezer
    temperature. The operating temperature range of most residential
    freezers is between -10F and +10F. The optimum temperature of the
    freezer is between 0F and 5F. Proper refrigerator operating
    temperatures should be between 36 and 45 degrees Fahrenheit. If the
    refrigerator temperature is very close to the 35 degree mark, you can
    try turning the temperature up a little bit.
    Sometimes, rearranging how you put your foods in the
    refrigerator
    can make a difference. The temperatures vary from compartment to
    compartment. Another common cause is a leaky gasket. Try putting a
    dollar bill between the gasket and the frame of the freezer as you
    close the door. If the dollar comes out without resistance, then you
    need a new door gasket.
    When installing a refrigerator door gasket, you should allow
    the
    gasket to adjust to room temperature before removing it from the
    carton. When carrying or handling the gasket, you want to carry it by
    the corners. This will help to prevent breakage of the flexible magnet.
    Should the magnet be found to be broken, it will NOT impair its
    effectiveness. If the gasket is deformed or twisted from long storage,
    you can heat the deformed section with an electric heater, hair dryer,
    or a 150-300 watt light bulb. Holding the heat source about 1 inch to 3
    or 4 inches from the gasket, move the heat source back and forth to
    maintain even warming. Apply heat until gasket has resumed its original
    shape. This can also correct an already installed, deformed gasket.
    Make sure you use caution so as not to damage the inner door panel.
Freezer fan makes noise
Noisy fan = new fan motor.
May 13, 2017 | Admiral Refrigerators
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
Freezer is freezing fridge is warmer than usual does the dial indicating coldness from 1 to 2 apply to the freezer, refrigerator or both? have cleaned condenser on back of refrigerator - it was not really...
Usually, the freezer knob just adjusts the airflow from the freezer to the freshfood section. The refigerator control turns the unit on and controls temperature. When unit is running, do you hear the fan running in the freezer? The fan forces air to the refigerator section. If not, probably bad fan motor. If it is, do you see frost build up on the back wall of freezer section? If so this would indicate a defrost problem, ice build up on evaperator blocking airflow to refrigerator section. You cleaned the condenser, Was the condenser fan running? Defrost causes. Defrost thermostat, heater,defrost timer. Good luck.
Mar 31, 2011 | Whirlpool Refrigerators
Area around freezer door is very hot to the touch. ice maker works, but after awhile the ice will melt. freezer is freezing.
HI, That area being hot is a sign the refigerator is not cooling properly. We need to pin point the cooling problem.
First, are you noticing any frost build up inside the rear freezer panel?
Are the fans and the compressor running?
Please let me know so I can assist you through this.
Vic
May 27, 2009 | Refrigerators
Moisture/Ice build-up in Refrigerator
ok first of all. the refrige is in the basement. do you know what the relative humidity in the basement is?
you can check this with a humidity gauge.
May 26, 2009 | Maytag Admiral Top-Freezer Refrigerator
Side by side Admiral freezer that has frost
Check condensation drain line for a blockage.
May 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Fridge part of product is not working
i have a admiral serial # 1142843us, model # hmg211771. freezer at top freezes. hot at bottom. motor sound like it roars. frost inside frrezer at top.
Apr 09, 2009 | Refrigerators
Whirlpool top freezer problem
Check for frost build-up behind back wall in freezer. If there is a heavy frost build-up, it's not defrosting. This will restrict airflow to refigerator section and can stop fan. If fan is stuck again and it's not because of frost, replace evaporator fan motor.
Nov 12, 2007 | Whirlpool ET1FHTXM Top Freezer...
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore Refigerator
Is your fan in the freezer blowing, condenser need cleaning, condenser fan working, any frost build up in freezer? controls set in the middle?
Aug 26, 2007 | Refrigerators
Refrigerators Logo
639 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
