2004 Jeep Grand Cherokee Logo
Posted on Mar 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My passenger side front and rear windows,locks and mirror controls dont work
Pierre Laplante
Level 3:
  • Jeep Master 2,061 Answers
  • Posted on Mar 01, 2011
Pierre Laplante
Jeep Master
Level 3:
Answers
2061
Questions
Helped
789264
Points
21147
The window control and mirror those wire goes truth the driver door if you open the rubber in the middle of the door wire always get damaged there its when the door is open many time wire move and snap inside that black flexible rubber you have to open that rubber and repair those wire thank for using fixya
1helpful
2answers
1997 Buick Park Ave, passenger side and rear windows stopped working.
You say the driver window works? wouldn't be a main fuse or fusible link then -driver door locks and window wouldn't work either. Each door has a module inside (computer) . The driver door has a circuit breaker power feed an a fuse DDM fuse 10amp located in rear junction block circuit breaker is located in under hood maxi fuse block. The circuit breaker also feeds battery voltage to the other door modules too. PDM - passenger door module fuse 10amp located in the instrument panel fuse box and the RDM - rear door module RDM fuse 10amp located in the rear fuse box - under the back seat.
Each power window is connected to a permanent magnet motor. The motor raises or lowers the glass when the door module applies voltage to the motor. The direction the motor turns depends on the polarity of the supply voltage provided by the associated door module. The 2 front doors have their own separate modules. The rear seat contains a single module, which controls both of the rear power windows.
A serial digital communications link, called the simple bus interface, is used for communications between door modules and the driver's door power window switches. The use of serial digital communications allows the use of a single wire to convey switching information between the power door lock switch and the driver's door module (DDM). The serial communication is also used in order to transmit switching information from the DDM to the other 2 door modules.
The door modules apply battery voltage of the correct polarity to the respective window motor when any local, or power door lock switch, UP switch is operated, driving the window up. Battery voltage is applied to the respective window motor in the opposite polarity when any local, or power window switch, DOWN switch is operated, driving the window down.
Driver Door Module (DDM)
The driver's door module (DDM) directly controls the driver's door window motor and the express down window feature. The DDM sends window UP/DOWN messages received from the power door lock switch to the passenger door module (PDM) and to the rear door module (RDM) over the simple bus interface (SBI) line. The DDM also contains a class 2 data link which communicates with the other vehicle system modules. The left front power door locks and the outside power mirror are also controlled through the DDM.
Passenger Door Module (PDM)
The passenger door module (PDM) controls the passenger's door window motor. The PDM controls the passenger's door window directly from the right front power window switch or from instructions over the simple bus interface (SBI). The right front power door locks and the outside power mirror are also controlled through this module.
Rear Door Module (RDM)
The rear door module (RDM) controls both of the rear door window motors. The RDM controls the rear windows directly from the rear door window switches or from instructions over the simple bus interface (SBI).
2helpful
3answers
Hi, I'm trying to diagnose a non-working front passenger side power window switch on a 2008 Escalade. Only the lock/unlock function works. The window, mirror and mirror turn signal don't.
Yes they run a wire loom that has wires that are not used in some models. One thing you need to check is the wire loom because it flexes every time the door opens and closes and wires can break .Also you may want to go to autozone website and make a free account, you can put in the year make and model and look for the free repair guides for wire diagrams.
Power window
sounds like driverside button cluster
How to replace passenger door side mirror 2012 ford flex
The related help links are mentioned below.Click the link below:---
---------How to remove rear view mirror metal foot?
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-rear-view-mirror-metal.html
power locks, power window and power mirror on the passenger side not working on Ford Windstar
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
----How to Remove Outside Mirrors on Acura Integra?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-outside-mirrors-on-acura.html
-------Passenger side Folding Mirror is not operating? http://schematicsdiagram.blogspot.com/2011/12/passenger-side-folding-mirror-is-not.html
These will help.
Thanks.
2008 Buick Enclave; front passenger, no power to window and lock controls, and no power to passenger side mirror. Additionally, passenger heated seats do not operate. From driver seat control, I cannot...
Do you know anything about automotive electronic's ? Serial data Communication network ? Electronic module's inside the vehicle doors , communicate commands ! No relay ,no fuse .
If the passenger mirror is selected and a direction switch is activated, the DDM sends a serial data message to the PDS indicating that the passenger mirror was selected and the direction to be commanded. The PDS will then supply battery voltage and ground to the appropriate control circuits for the direction selected.
DDM - driver's door module
Door Lock System Components
The power door lock system consists of the following components:
• Driver door module (DDM)
• Passenger door module (PDM)
• Door lock relay--Located in the instrument panel (I/P) fuse block and controls the locking of the rear doors.
• Door unlock relay--Located in the I/P fuse block and controls the unlocking of the rear doors
• Body control module (BCM)
• IP BEC
• Reversible door lock actuators in each door
Power Window System Components
The power window system consists of the following components:
• Rear door power window switches
• Power window motors in each of the doors (circuit breaker protected)
Your best bet , take it to a qualified repair shop that has a diagnostic scanner that can pull code's an view input data form these systems . There is one circuit breaker for the window's an fuse's for the lock's . I would think a data network problem . But that would be a guess , without testing anything is possible on these .
1helpful
Similar electrical issues with driver's side door controls. Power locks, power window, and power mirror on driver's side are not functioning. I can manually unlock the door, but the buttons on...
CHECK FUSES FOR POWER WINDOW,CHECK FUSE FOR POWER MIRROR AND CHECK FUSE FOR POWER DOOR LOCK.IF FUSE OKAY DOOR CONTROL MODULE FAULTY ITSELF.
1998 Jeep Grand Cherokee Laredo TSI, Passenger side windows do not work from master switch on drivers door. Both driver side windows work from master switch on drivers side. Passenger side windows do work...
It has to be the switch or the wiring, right? So pull out the switch and probe the back with a volt meter to see if power is coming out of the switch. If yes, trace the wires to the doors.
2answers
Doorlocks dont work except from passenger side. mirrors dont work. windows dont work from anywhere
First, check all fuses to make sure that none are blown.
If the door lock switch works on the passenger side, then the drivers side door lock switch is probably faulty. Use a multi-meter to test the Drivers Side Door Lock Switch (Black and Pink/Light Green wires unlock the vehicle, and the Black and Pink/Yellow wires lock the vehicle)
If the switch is tested and found to be operating properly, you may have a faulty Body Security Module or Drivers Side Door Lock Actuator.
If neither of your Power Mirrors are working, you probably have a faulty Exterior Rear View Mirror Switch, Power Mirror Module, or blown Central Junction Box Fuse.
If none of your Power Windows are working, you probably have a faulty Accessory Delay Relay or a blown fuse in your Central Junction Box or a faulty Master Window Adjust Switch (all of the Power Window Switches feed through this Master Window Switch). If the Power Windows didn't stop working at the same time, you may have faulty Window Adjust Switches, or faulty Power Window Motors, this is very unlikely though. It would also be a good idea to inspect the wiring for any obvious damage.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
I NEEDED THE 2001DODEGE CARAVAN SPECIFICATION
2001 Dodge Caravan Performance Features -3,301 cc 3.3 liters 6 V engine with 93 mm bore, 81 mm stroke, 9.3 compression ratio, overhead valve and two valves per cylinder
-Unleaded fuel
-Fuel economy EPA highway (l/100km): 9.8
-Multi-point injection fuel system
-Main 76 liter unleaded fuel tank
-Power: SAE and 134 kW , 180 HP @ 5,000 rpm; 210 ft lb , 285 Nm @ 4,000 rpm
2001 Dodge Caravan Handling & Driving Features -ABS
-Two disc brakes including two ventilated discs
-Spacesaver steel rim under body spare wheel
-Strut front suspension with stabilizer bar independent with coil springs , beam rear suspension with stabilizer bar rigid with leaf springs
2001 Dodge Caravan Exterior Features -Body side molding
-Front and rear body color bumpers
-Driver and passenger power heated black door mirrors
-External dimensions: overall length (mm): 4,803, overall width (mm): 1,996, overall height (mm): 1,750, wheelbase (mm): 2,878, front track (mm): 1,600, rear track (mm): 1,626 and curb to curb turning circle (mm): 11,460
-Complex surface lens halogen bulb headlights
-Double sliding minivan side door
-Remote control operation opening rear ¼ windows
-Metallic paint , gloss paint , pearl paint
-Fixed rear window
-Tinted glass on cabin, rear and side
-Weights: curb weight (kg) 1,842, gross trailer weight braked (kg) 907 and max legal load (kg) 772
-Windshield wipers with variable intermittent wipe
2001 Dodge Caravan Interior Features -Air conditioning with rear outlet
-Fixed mast antenna
-Manufacturer's own audio system
-Automatic drive indicator on dashboard
-Below seat storage under passenger seat
-Cargo capacity: all seats in place (liters): 433, all seats removed (liters): 4,154 and third row seats removed (liters): 1,291
-Clock
-Dashboard full console with open storage box
-Delayed/fade courtesy lights
-Cruise control
-Front seats, rear seats and 3rd row seats cup holders
-Door ajar warning
-Door pockets/bins for driver seat and passenger seat
-Floor covering: carpet in load area
-Driver and passenger front airbag
-Bucket seat
-3-point reel height adjustable front seat belts on driver seat and passenger seat
-Front seat center armrest
-Glove compartment
-Height adjustable two head restraints on front seats, rear seats and 3rd row seats
-Internal dimensions: front headroom (mm): 1,011, rear headroom (mm): 998, front hip room (mm): 1,440, rear hip room (mm): 1,722, front leg room (mm): 1,031, rear leg room (mm): 930, front shoulder room (mm): 1,588 and rear shoulder room (mm): 1,643
-Low fuel level warning
-Low washer fluid level warning
-Internal button power locks
-Power steering
-Front power windows with one one-touch
-Front reading lights
-3-point reel height adjustable rear seat belts on driver side and passenger side
-Bench one-piece two rear seats
-Rear view mirror
-Upgraded cloth/velour seat upholstery
-Seating: seven seats
-Six speakers
-Plastic steering wheel
-Tachometer
-3-point reel third row seat belts on driver side , 3-point reel third row seat belts on passenger side , lap static third row seat belts on center side
-Front facing bench removable one-piece third row seats with capacity three
-Driver and passenger vanity mirror
-Ventilation system with recirculation setting
Thanks.
12helpful
4answers
2004 Jeep Grand Cherokee driver side power windows do not work
I had the same problem with now power to windows, mirrors and seat. The common soulution is the orange and or black wire in the boot have broken between the door and post.
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
