There is no front panel to be removed on this machine. Where the top meets the cabinet there are two clips that hold the top down. Take a putty knife and insert it between the top and cabinet on the left and right side. Push in on the clips when you find them and lift the top. You can now start the washer and see where the leak is coming from. Don't hold the lid up to high or the water will shoot straight out at you while it is filling. (I had this happen to me). You can see all along the sides of the machine. Once you do see a leak you can slide the machine out from the wall and tip it back and have full access to the bottom. Make sure it is tipped back far enough that it doesn't fall on you. I hope this helps.
