Question about Nokia e65 Cellular Phone
Head set i would like to know if u have overcome the problem with the headset mode.... if yes please help me......i tried connecting and unplugging headset and datacable.. but its not working.
This just sorted itself out! Sorry, I just turned it on one morning and the problem had gone. I couldn't find anything anywhere on the internet that gives you a fix for this problem. It lasted about 1 week before resolving itself. Sorry I'm not more helpful.
Posted on Jul 29, 2008
RAPOO h6060 led is always red
Hi Bando
Just want to ask, have you accidentally dropped this head set? if not then lets make it this way.
Now the time that this headset still working or responding normally..
- the time that you use this headset what was the color of the led? is it red,green or blue?
- normally led red light indicates standby mode,
- how would you know that your headset is in fullcharge? is there an indicator?
Jan 27, 2014 | Rapoo BLUETOOTH STEREO HEADSET H6060 WHITE
How to pair to the phone
Please follow this procedure:
  1. In the headset press and hold the call control botton until the indicator turns red and then turns off, press and hold the call control botton until the indicator light continues to flash red and blue, the headset is now in pairng mode.
  2. In your phone, go to bluetooth conectivity and select scan for devices, select de Plantronics bluetooth headset from the list, enter 0000 for the passkey and OK/accept to bond them.
Mar 01, 2011 | Plantronics Explorer 240 Bluetooth Headset
How to pair Motorolla 550
Please allow me to help you with you Blue tooth head set.
Step 1
First power on the headset you do this by sliding the call button towards the microphone.
After a few moments, the indicator meaning the "light" will be steadily lit in blue to indicate the headset is good to go in pairing mode.
Step 2
1. On your phone press the menu button then locate connection or device "phones are diffrent" at this point you need to turn on the blue tooth on your phone.
2. The phone should find the Motorola H550
3. Select OK or YES to pair you headset with your phone.
4. Enter the pass key: 0000
5. Press ok
Hint: Once the phone is paired with the headset the indicator will flash blue.
Now if the unit does not pair then you might be using another unit with this phone so please make sure you disconnect all blue tooth units and try the steps again.
If you have any questions WE can help please get back with me.
Thanks for using Fixya.com "We have a solutions for everything"
I hope this solution was VERY HELPFUL!
Have a Great day
Oct 29, 2010 | Motorola Mobility H550 - Bluetooth Headset...
How do i link my head set to my ps3?
We've just received some new information you may like to review.
You may want to review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
Nov 19, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
LOST MY PIN NUMBER FOR MY HEAD SET
You may need to reset your Bluetooth devices. Please follow the steps below:
- Delete BT8040 from cell your phone. (if listed)
- Turn your cell phone off completely, and remove battery for 10 seconds. Please consult your phone provider prior to removing battery.
- Connect the BT8040 headset to the charger for 10 seconds then unplug.
- Place the battery back into your phone and power your phone on.
- Remove the headset from the AC cord.
- Turn off the headset by pressing the answer/end button until the light flashes rapidly then release.
- Press the answer/end button until you receive a solid blue light. This may take up to 10 seconds.
- Go into the Bluetooth menu on your cell phone and follow the cell phone’s instruction guide for pairing a Bluetooth headset. This generally involves going into a “devices” or “hands free” menu and adding a new device. Your phone may ask if you want to pair with the headset, accept by pressing “yes” or “OK” and confirm with the passkey or PIN 0000 (4 zeros).
Oct 20, 2009 | Jabra BT250 Consumer Headset
Headset Microphone doesn't work
Plugged in? Is it a stereo plug? does your computer allow speaker and mic on the same wire? Does the outlet say Mic or Headset of Both? Had it worked in the past.
Some computers have a place for a mic - some for headset - some might have both. On a desktop, I would expect to find separate connections. Laptop, Id have to look.
A 'stereo' plug will have a tip, ring and barrel connection.
A 'mono' plug will have a tip and barrel connection only.
A stereo plug would allow a mic and head phone connection ujsing a 'common' for the return.
A mono plug would allow either a mic or a headset, not both.
If you could peer into the jack inside your computer, you could tell if it privides for three wire (stereo) or two wire (mono) operation.
I hope this helps ... If I missed your question, please reask.
We are "paid" here by positive comments where we earn "bragging rights" If you are satisfied, please post positive comments
thanks
a
Oct 12, 2009 | Computers & Internet
Connecting bluetooth head set
>Paraphrasing from the manual:
>1. Turn off headset.
>2. Press & hold the Multi-function button for 8 seconds, until >the lower half is lit up blue (not flashing).***THIS IS >IMPORTANT! KEEP HOLDING IT IN UNTIL IT STOPS >FLASHING! The whole thing will be lit up blue, but the lower >half will be brighter.
>3. Set your 'phone to discover bluetooth devices.
>4. Your 'phone will find the "Samsung WEP410" headset, & >ask if you want to pair with it. Confirm by pressing "Yes" or >"OK".
>5. Enter passkey or PIN "0000" (4 zeros), then "Yes" or "OK".
Mar 11, 2009 | Samsung WEP410 Bluetooth Headset Wireless...
CAN'T GETHE HEAD SET CONNECTED TO MY RAZOR
Hey Sadie,
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Explorer 3XX device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya
Chris (ziraffa)
Dec 19, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Nokia 6070
what you need to do is just for you to change your ear piece
Jan 07, 2008 | Nokia 6070 Cellular Phone
Pairing problem
Before you use your Jabra BT130, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT130 Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT130 Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 23, 2007 | Radio Communications
Nokia e65 Cellular Phone Logo
41 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
