Question about Panasonic Televison & Video
NV-FJ710 will not eject, tape keeps playing - Panasonic Televison & Video
ilragatzzo78
  • 241 Answers
SOURCE: cassette player
the tape is very tight
get a pen and try to loosen up the tape
100 % is the tape not the radio
Posted on May 16, 2008
SOURCE: SONY VCR: Keeps ejecting video tape
may be machnical stuck in playback mode. remove the cover and see the loading arms are near the video head , if not try to release the arm rotating caption wheel smmothly . don't push more force to rotate the wheel.
Posted on Jan 15, 2009
Grubhead
  • 5309 Answers
SOURCE: Panasonic NV HD620 Error F06
You appear to have a model that uses the K Deck Chassis.
F06 in that case stands for: "Mechanism locks after unload". The cause being either the loading motor or the carriage alignment.
Posted on Jun 21, 2009
Grubhead
  • 5309 Answers
SOURCE: panasonic NV-SD236B VCR Error code
You appear to have a model that uses the K-Deck Chassis. If you enter "Panasonic K-Deck Chassis" into google you will find loads of service information on it.
However back to your problem F06 means the mechanism is locking up after unloading. The cause of which could be either the Load Motor or a problem with the Carriage (where the tape goes) and it's alignment.
Posted on May 28, 2010
Grubhead
  • 5309 Answers
SOURCE: the deck ejects the tape once inserted into
VCR's have a thing called a mode switch. This tells the electronics of the machine what position the mechanical section is in. If it gets wrong signals then the VCR electronics will take action to correct the problem. In this case ejecting any tape you put in. These wrong signals are caused by the damage to the VCR mechanical section, which might account for the tape getting stuck. Even though you have removed it, doing so repositioned various parts. Perhaps in this case something to do with the carriage unit, being in the wrong position. In any case the whole mechanical system will need to be reset. This is not an easy thing to do and unless you have set up the VCR before a service manual will be needed. This is because everything will have to be set right or different problems will happen. For example it is common practice in Panasonic VCR's to have the carriage in the loaded position when setting it up. And you will also need to know the correct position of various items - including the mode switch!
Before doing so I would look around to see if any plastic parts are damaged.
Panasonic use the same mechanical systems in different models. They tend to be called after a letter of the alphabet, such as K-Deck etc. I don't know which one your model uses but finding it out well make life easy for you repairing the machine.
Posted on Jan 24, 2011
I have a NV-DX110B about 11 years old. I'm getting
Your camera appears slightly older than mine so I will do my best for you. Have you tried ejecting the tape with the power off? If I have problems I slide the eject button when the camera is off but plugged in and the tape can be ejected. I suspect the tape mechanism is in trouble. When a tape stuck in mine I had to literally force the cover open. But this is a last resort.
Give my suggestion a try and apologies if you have already tried that...
Sep 11, 2011 | Panasonic Video Cameras
VCR does not play.. It keeps ejecting the tape
Does it eject right when you put a tape in? Or when you press play? Does it fast forward or rewind? if not a belt may need to be replaced or an idler tire is worn.
Jun 16, 2010 | Panasonic NV-HD680 VCR
Vcr will not play tapes,it ejects the tape after a few seconds
This may be caused by the mode switch.
By the way it uses a K-Deck Mechanism.
Sep 11, 2009 | Televison & Video
How to time loading arm cogs on VCR?
Most Panasonic VCR use a mechanisms with a letter. For example the NV-HS900 uses a K Deck. What you need to do is type the model number into google and search for which deck it uses. Then with luck you might also find the instructions for setting the deck up correctly. I got the K-Deck one free.
Jan 03, 2009 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
My Panasonic NV-SD270 video player wont play or release a video cassette and shows the error message "F05". Does anyone know what this means? thanks Chris
when the loading mechanism have a trouble and did not thread the tape properly , the eject mode commands primarily coz the tape in sensor activated properly
Apr 29, 2008 | Televison & Video
Need help FAST!! Panasonic NV
remove battery for a while .put it again and try .if not works...remove battery agin then put it again by keeping power switch off. eject and remove cassette .take several eject operations. now try again.
Nov 04, 2007 | Panasonic NV-GS50 Mini DV Digital...
Tape wont play then ejects
I am this problem... please download service manual *pdf... jedlicka.j@gmail.com
Thanks
Oct 14, 2007 | Panasonic NV-HS1000 S-VHS VCR
Tape Ejects Immediately
There are normally 2 causes. One is some obstruction in the tape path. Please open the cover of the VCR and shake and see for foriegn objects. Nothing??? Then there is one more possibility - Belts are loose.. Check the Tape Loading motor belt.Is it slack? This can happen over time.Change the belt.
Feb 04, 2007 | Panasonic NV-HD680 VCR
Televison & Video Logo
60 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
