Question about Cell Phones
LG VX5400 cell phone power problem
My phone powers down on its own, even when fully charged. I have been having this problem for a few days. For awhile it was turning itself off almost instantly. Last night I recharged it and it stayed on for a couple of hours before I went to bed, but by the time I got up this morning it had turned itself off again. (It is still showing the battery as fully charged.)
  • 3 more comments
  • okibilir Nov 30, 2008
    how do I replace the battery?
  • Anonymous Dec 11, 2008
    This happened to me too. I took it back to Verizon, they gave me a new 5400, and it started doing the same thing after a couple months.
  • Anonymous Jan 05, 2009
    Same here. I bought mine in Feb 08. It's now Jan 08 and it's been doing this for maybe a month now.
  • AAA32604 May 03, 2009
    My phone will power down in my pocket or in loud areas....Go figure.
  • Anonymous Mar 12, 2014
    phone working ok this morning, went to use I after dinner and it had witched itself off. put it on charge but it won't power on, tried soft and hard boot up, phone still ded
    Master:
  • 623 Answers
Try replacing your battery
Posted on Jul 29, 2008
LG VX5400 only shows No ID
Phone settings then Display you should find caller ID on or off.
Jun 01, 2010 | Motorola Mobility RAZR V3
LG neon battery dies within minutes!
The same thing happened to me you have to take it back to LG and tell them to replace your battery or buy it from Radioshack. At&T gives cheap batterys.
Apr 19, 2010 | LG Neon GT365 Cell Phone
MY SON GOT HIS LG VX5400 WET AND NOW IT WILL TURN ON BUT THEN IMMEDIATLY POWERS DOWN. BATTERY IS CHARGED,
OH MY GOD!  WHY ARE WE YELLING!?!!  THE BATTERY IS CHARGED!?  AHH, RUN FOR THE HILLS! THERE ARE CHARGING BATTERIES HERE!
Secondly, you didn't even pose a question.  I can assume you meant to add 'WHY, LORD, IS THE HAPPENING TO ME, WHY!!?!", to which I say, "When phones get wet they get broke."
Stop procreating, please.
Apr 01, 2010 | LG VX5400 Cellular Phone
Phone will not turn on
If you haven't done it already, try unplugging it and removing the battery for 10 seconds and reinsert it, if that doesn't fix the problem there's not too much you can do about it anyway. With most cell phones, you can easily take the casing off but everything's integrated, so it's cheaper to buy a new phone than to try to fix a current one.
Sep 24, 2009 | LG VX5400 Cellular Phone
LG ENV2 shutting off
I just got mine a few weeks ago and it does the same exact thing (I didn't drop it, there is no water damage, I didn't understand the cause of it). I took it back to the Verizon store and I was told that the random shutting off like that is caused by having the phone outside being exposed to heat. He reset my phone back to factory settings and that did the trick for awhile (its hard for me to go to the pool and not have my phone exposed to the heat). There is no charge for them to reset the phone. Mine has started the random shutting off again back up
Jun 03, 2009 | LG enV VX9900 Cellular Phone
HOW DO I PAIR A MOTOROLA n136 TO A LG VX5400
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Dec 21, 2008 | Motorola Mobility HS850 Consumer Headset
About the bluetooth...
cool, the issue ont he phone can possibly go to a faulty battery or a battery terminal; worst case will go to the whole power supply of the phone (Battery, terminal and charging capacitor;usually called the power IO)
you may try leaving the battery to drain out, leave it like that for at least over night, while it is off, charge it for about 4 hours max, then turn it back on. if this did not work, remove the battery check if it is swollen. and check the terminal if it is dirty, if so, just clean it with ethyl alcohol on a Qtip.
Nov 08, 2008 | Cell Phones
Power
if your phone is new charge in for a day then try turning it on. take out the sim and clean it then put it back in. do the same with the battery otherwise take it into the shop you bought it in and get them to have a look
Aug 21, 2008 | LG Shine KE970 Cellular Phone
VX5400 turns itself off.
I had the same problem and brought the phone to a Verizonwireless store. They replaced it under warranty and did not give us much of a hassle. My guess is that it is a common problem. (On a side note, if you take the battery off the sticker shows a field called H/W Rev. The old phone was 1.0 and the new one is 1.1 which further suggests that they have made hardware changes to solve this problem.)
Aug 11, 2008 | LG VX5300 Cellular Phone
Cell Phones Logo
303 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
