Question about Lands Phones
Re Phone Problem
Hi, Thanks. I do most of the programming on the system and I have assigned access to that line for the phone through Line Data and also gave access for the extension through Line Access, it just seems like there is something I’m missing :( The phone is a private to line and it does ring but you can’t answer it but the line data config and line access config are in place as they were before the power cut. I didn’t set up the system originally but do maintain it. Do you have any other ideas? Thanks Heather McDonald
    Scholar:
  • 108 Answers
Hi Hearher,
Usually a private line rings in as a target line to a specific port and is assigned as Ring and Appear on that port. Do you have regular CO lines or a T-1 ? You might also check the programming you have in place and verify the line is set to " ring and Appear ' on the phone. If you have a T-1 you also have to make sure the " Received " digits are programmed. I'll be out most of today but will check back this afternoon and see if you have responded. Good Luck, ....Mike
Posted on Jul 30, 2008
I can not access my main line
If a system defaults programming it assigns only lines 1 and 2 to each set.
You either had this issue or somebody removed line 3.
Call a tech in to program.
Aug 01, 2012 | NorStar Meridian M7310 Phone
Hi , i have a problem with my KX-T7730 : in brief , when i press the line access code which is the " 9 key" , it gives me wrong CO . so i want to change the program and set it to my desire CO...
So many options. Why are you dialing "9" for an outside line? You can just press a button assigned to the line you want.
Since a 7730 works on up to 18 different Pana systems, there's no telling what you have, but you can assign a specific line to a button, a group to a button, program the system to not pick vacant lines, or dial the direct line 8x or 8xx access code. There's an outside chance that ARS (automatic route selection) is enabled and the "9" doesn't even give you an outside line in the first place.
Which is yours?
Carl
Aug 28, 2011 | Panasonic KX-T7730 Corded Phone
I have a Kx-t7420 panasonic phone system. I have three of my phones that go directly to line 2. no idea why. Can I change this? Also there is so much noise on line 2 that I cannot hear. Is this something...
Actually, you have a Panasonic TD phone system and a 7420 phone, but no matter. The feature you have is probably "idle line preference" or "preferred Line Assignment-Outgoing". In TD systems by default, you select lines from highest to lowest. If you only have 2 lines and PLA is set, you get line 2 then line 1. You can change it to get line 1 first, or chage the trunk access order. The first is something you can do from each phone, the second requires access to system programming. The bad thing about the first solution is if line 1 is busy, you won't get any line. The second will give you the entire trunk group.
Anyway, from each phone without picking up the handset, press PROGRAM 99 and dial 1301 STORE. That will give you line 1 when you pick up the handset. Just so you know or can change it, 11 is none, 12 is idle line, 13xx is specific line and 1+the intercom is intercom. Pick up the handset and drop it back down to exit programming.
As far as the noisy line, it's probably a central office issue. It's hard to test as that line is the outer pair of the jack that plugs into the phone sytsem (RJ-14 pair 2), but you can probably take a regular phone and test it at the demarc point.
Carl
Jul 14, 2010 | Panasonic KX-T7420 Corded Phone
I HAVE A TELEPHONE SYSTEM WITH ONE PHONE NUMBER, BUT 25 EXTENSIONS. 23 OF THEM GETS A DIAL TONE, BUT TWO OF THEM DON'T. I DID TRY TO REPLACE THE PHONE JACK WITH A NEW PHONE JACK THAT I BOUGHT FROM...
A lot of questions need to be answered. But for starters, the other two phones probably do not have the line programmed into them. If these two phones light up...have any other working features then it's not the phones or jacks it's the programming. All phone systems have "line assignment"/ "line access" programming.
What make and model of system do you have?
P.S. On a separate topic, you should definitely have more than one line in your system for that many telephones.
Jan 30, 2010 | NEC DS1000 66-Block with AMP connector...
AVAYA PARTNER ACS PHONE SYSTEM - Separate Greeting
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#206"
the display should say Group Call Distrib Group:
Press 7 It will then ask for a line number
enter in 05
the display will say 1 assigned
press 3 VMS Line Cover
Do the same procedure (from #206 on) for line 6
Then enter #208
The display will say Line Coverage Ext Line:
Enter 05 The display will then say Data --
Enter in the extension you want the voice mail to pick up the lines on
Lastly if its not done allready, enter #301
The display will say Automatic VMS Cover Extension:
Enter in the extension number of the phone thats getting the voice mails
The display should say 1 Assigned
press feature "00" to logout
Oct 06, 2009 | Lands Phones
We have an AT&T system with 4 lines and several MLS-12D phones. Two of our 4 lines are not working. If someone is on the main line, additional incoming calls do not roll over to the other lines. This...
Changing programming2.gif on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
enter in "#301"
the display should say line assignment and station:
enter in the station you want to program the line on.
the display will then ask for the line number to program
enter the line number you wish to program in 2 digit format i.e. line 1 is 01 and so forth
the display should say Lxx and 2 not assigned
enter 1 on the dialpad (assigned)
repeat procedure for remaining sets
enter feature "00" when finished
Sep 01, 2009 | AT&T Lucent MLS-12D Phone
I want all incoming calls to come through my extension only.
What it sounds like you want to do is restrict the automatic system answering to certain extensions. This is done via feature code 204.
To identify the lines on which outside calls should be answered by the system:
  1. Press feature +(00)+(system program)+(system program)+#204
  2. Enter the two-digit system line number of the desired line.
  3. To assign or unassign the line, press (Next Data) until the appropriate value appears.
    1 = Assigned
    2 = Not Assigned (the factory setting)
  4. To identify another line, press (next item)or (prev. item) until the line number appears on the display. Then repeat Step 3.
  5. Repeat Steps 3 and 4 for all the lines that you want to identify.
  6. Select another procedure, or exit programming mode.
Aug 31, 2009 | Lucent PARTNER18 Corded Phone
Need to change the phone number assigned to a line
Hi Amy,
Ok ~ first to change the incoming line to a phone, goto the phone and do a:
-> FEATURE * 0,
-> Press the line that rings on that phone... (this will be the target line number ~ maybe somewhere in the 145-256 range)
-> now get into the system programming
-> go to LINE and type in the number you've seen on the display
-> enter and find TRUNK/LINE DATA
-> enter and hit next till you see PRIMESET and change that number to where you want that number to ring to. Hit next, after changing number and hit REL to get out of programming.
Now call the number to ensure it is calling to the correct extension.
Mar 17, 2009 | NorStar Meridian M7310 Phone
Automated Attendant not on everyone line
The below texts should help you.
**Found on page 9-8 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
Use Line Assignment (#301) to assign all the lines that you want the auto attendant to cover
to extension X.
**Found on page 4-47 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
To assign lines to a specific extension:
1. Press [Feature] [0] [0] [System Program] [System Program] [#] [3] [0] [1] at extension 10 or 11.
2. Enter the extension number to be programmed. For example, to program extension 15, press [1] [5]. The red light next to each button that has a line assigned is on steady; the red light next
to each button that has a pool assigned flashes.
3. To remove all existing line assignments, press [Remove] before selecting a line.
4. Enter the line number to be assigned. For example, to select line 1, press [0] [1].
5. Do one of the following:
■ If you want to assign the line to the first available button with lights, press [Next Data] until the
display reads:
Line Assignment 15 L01
1 Assigned
1 Assigned is the factory setting.
■ If you want to remove a line assignment, press [Next Data] until a display like the following
appears:
2 Not Assigned
■ If you want to assign the line to a specific button, press 3. A display like the following
appears:
3 Select a Button
Then press a button with lights to assign the line to that button. If you use option 3 after a
line already has been assigned, the line moves from the old button to the new button you
select.
6. Do one of the following:
■ To program another line for this extension, press [Next Item] or [Prev Item] until the line number
appears on the display. Then repeat Step 5.
■ To program another extension, press N P and begin at Step 2.
7. Select another procedure, or exit programming mode.
Feb 05, 2009 | Avaya Corded Phone avaparp18d
No ring and appear on my Norstar M7310
This should work on M7310, M7324 & T7316
Feature ** 266344 - password 266344 - configuration - line data - line access - show ext (yours) - line assignment ( which lines you have, usually 1 & 2) - show line - appear only/ring/apprear and ring
Hope this helps
Oct 02, 2008 | NorStar Meridian M7310 Phone
Lands Phones Logo
65 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
