I can get no sound from my hitachi AX-M80 CD system
  • 2,071 Answers
Loose connection or cold solder and cleaning problem this is the main caused of no sound..Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....
Good luck:
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Jul 29, 2008
Hitachi ax-m71 cd door won't stay closed. Unable
if it opens back up when you close it the drawer mechanism is probably out of alignment. Most players have a slot on the bottom of the drawer that a pin must slide in. Look under the drawer and see if there is a pin sticking up that maybe should be in that slot.
Jul 09, 2013 | Audio Players & Recorders
Hitachi AX-M71 connecting control cable
Hello Alan, I have the cable from a u/s AX-M71 system. the cost is £8.00 including P & P . Regards, Malcolm
Aug 05, 2009 | Audio Players & Recorders
Re Hitachi AX-M80 - cD Player. When put into PLAY mode - there is an ERR message displayed and CD is not played.
This evening my daughter revealed she had the same problem. I wiped the eye with a tissue - now it works!
Some times the obvious is the answer.
Oct 23, 2008 | Audio Players & Recorders
Need instruction booklet for HITACHI AX-M138 USB DAB CD DVD MP3 HIFI SYSTEM. Bought on Ebay and didn't come with instructions
I have found out that the Hitachi AX-M138 was only ever distributed in the UK by DSG (Dixons / Currys) so you could try their spare page at www.mastercare.co.uk to see if they can supply you with a manual. I've had a look & they no longer list it but it's worth an email to them. Otherwise I have a copy if your interested.
Jan 23, 2008 | Audio Players & Recorders
55 people viewed this question
 Grubhead
Grubhead
