Dvd rom not working
, my laptops optical drive dvd rom is nt working properly ,,, i mean whenevre i insert a disc green light on the drive blinks for a min or two but it doent read it,,, i have checked in decive manager and bios it shows drive working properly,, so is it a hardware or software problem,, please reply
  • Anonymous Sep 19, 2008
    I have somewhat the same problems with my DVD drive. Some disc will read like DVD movies and CD's I have burnt. I have an installation disk that will not be read by the drive. I have tried the disk in another computer and it works fine, any ideas what the problem is?
  • mannycar59 Jan 12, 2009
    my DVD rom is not working
    Sergeant:
    Champion:
  • 214 Answers
Try cleaning with lens cleaner or else you have to replace with a new one
Posted on Jul 29, 2008
CD/DVD rom in laptop not working
The drive could be defective.
Dec 28, 2013 | Computers & Internet
Cds not playing but Dvd does?
Your optical drive is not working. you need to replace it.
Dec 06, 2017 | Dell Inspiron 9400 Notebook
Why isnt my laptop reading discs?
Try removing the drive and insert it again so it connects properly. If this doesn't fix your problem then most likely the drive is faulty and needs replacing.
Apr 15, 2012 | E-Machines eMachines M5305DP Notebook
Cannot read any DVD/CD
hi welcome to fixya
here is my solution for that problem, first lets verify to narrow down where the main cause it could be. lets use first a dvd cleaner, dust can cause the optic lens not to read. then insert a dvd observe the light indicator ( yellow ) if blinking which mean the optic lens is starting to read the disc, if not it doesn't read. so at this time you are going to remove the cover with your dvd drive just to know and access the mechanism as will as the optic lens. now turn the power on and insert the dvd look for the optic lens if emits red light then moved going up to read the disc which mean the optic lens has supply. then check the spindle motor if rotates normally if not check the motor replace if defective. one way on how will you check the motor if defective through using a analog tester, check the resistance on the positive and negative terminal of the motor if the resistance is almost 0 ohm or shorted which mean it was worn out need to replace. hope this will help thanks for consulting through fixya.
Sep 11, 2011 | Computers & Internet
MY , CD/DVD LAPTOP DRIVER DOESN'T WORK. IT CAN
goto run and type "compmgmt.msc"(without quotes) and select disc management if the dvd drive is showing below the hard disks means your dvd drive is working fine only thing you have to do is to right click on the CD-Rom 0 and change drive letter and paths to it
.if the CD ROM option is not seen in disk management then you have to go to the device manager option under computer management and expand cd/dvd -rom drives and you will find your dvd drive model if not that means that your dvd drive has got hardware problem
Aug 06, 2011 | Dell Computers & Internet
JLMS DVD-ROM XJ-HD166 DVD/CD ROM Drive does not acknowledge disc in drive after having the computer set back to factory
Does it not acknowledge dvd disc only or cd or dvd both. If it doesn't read the dvd disc, or able to play dvd disc, but able to exlpore regular cd's, then you have a codec error, and you need to download a dvd codec like powerdvd for it for your system to play dvd disc. Check to see if your dvd-rom drive appears in the "my computer" window, if it is there, but wouldn't be able to play anything, then it could be a driver issue. so make sure in the hardware , the drivers is installed and working properly. If it is working properly and driver is installed, then you got a bad drive, the optical laser lenses isnt reading or the spindle ain't working anymore if you don't hear disc being loaded when inserting the disc.
Jan 30, 2011 | Lite On XJ-HD166S Internal DVD Drive
DVD-ROM drive not working
Hi there.
It sounds like the lens on F drive has gone as i cannot read disks, there is nothing you can do about this once the lens has give up.
The best thing you can do now is remove it from the desktop and just carry on using the DVD/RW as this is the only optical drive you need because it reads and writes DVD's and CD's.
Good luck and thanks for using Fixya!!!
Feb 23, 2009 | Sony VAIO RS402 (PCV-RS402) PC Desktop
My toshiba sd m1612 doesn't play about hapf my DVD's
Nitzan,
OK... sounds like dirty Laser Optics to me...
There are CD CLEANER disks that look like a regular CD, BUT on the bottom there is a tiny (real) "brushes" that cleans the dust and dirt away from many/most CD/DVD devices!
I don't recommend that you use it too often because you do not want to SCRATCH your Laser Optics with dust or dirt... you just want to clean the laser face...
About $2.60 (free shipping) on EBAY
Here is a quote:
Description:
  • 100% brand new and high quality
  • Designed to efficiently clean the laser of your valuable VCD/DVD/Computer/ Laptop/CD-Rom/DVD-Rom
  • Improves sound quality, and optimize performance of your players
  • Perfect to keep your Disc drives clean and operating well
  • Safely clean and remove dirt and dust from your players
  • Easy to use, simply insert the provided optical Disc/CD into your player
Dec 06, 2008 | Toshiba SD M1612 Internal DVD Drive
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
