Question about Cell Phones
When trying to connect to my wlan at home with my nokia95 it comes up saying no gateway reply, what does that mean?
  • mjschijn Dec 11, 2008
    hen trying to connect to my wlan at home with my nokia E71 it comes up saying no gateway reply, what does that mean?
That means that your phone is a refurbished or that index mits card in the rear compartment is lanished or being smersh. pls. call me on my mobile 9949388873. laxman
Posted on Jul 29, 2008
I can connect to some wireless network but not in our home WLAN, it always says web: No gateway reply. Pls help me. Thanks.
Try verifying your WEP key- by default, most gateways from an ISP setup WEP on their combination wireless/router/modems. If there are multiple wifi networks, you may considering shifting the channel- that is done by accessing the wireless router (I recommend via ethernet cable!) and shifting the channel to something other than 2, 4, or 11 (I usually use 3)
The usual IP's for routers are 192.168.0.1, 1.1, and 2.1
Depending on the manufacturer, it may require an user name and password- sometimes your ISP can help with that.
Oct 03, 2010 | Computers & Internet
Everything seems connected and says connected yet I cannot get on the Internet.
Hi
STEP 1:Check for the IP address in the computer
STEP 2:Ping the router's default gateway and check whether u r getting replies without loss
STEP 3:If means "ping 4.2.2.2" in command prompt.It is global DNS and check whether u r getting replies without loss
STEP 4:If means "ping yahoo.com" check whether u r getting replies without loss
STEP 5:If means reset IE by going to Internet options------>advanced------>reset
STEP 6:If u din't get replies means assign a static DNS
THANKS....
With Regards......
Vaishu
Sep 26, 2010 | Airlink AR430W Wireless Router
Nokia e51 wlan problems
Try updating the phone software. Nokia's website has more info on it.
Mar 26, 2010 | Nokia E51 Cellular Phone
Nokia n95 8gb connection problem
To connect to your home network via a modem you need to configure the Connection settings.
First off, go to Menu > Tools > WLAN Wiz.
Now open up WLAN Wiz. and it will automatically scan for nearby wireless networks available. Find which one you want to connect to.
If there are passwords and configurations required for it just highlight it and press Options and go to Define/Edit Access Point.
If there is no password then simply just connect.
Now you should be able to successfully connect to your home network.
Hope I have been of assistance to you,
Cheers :)
Feb 14, 2010 | Nokia N95 Cellular Phone
Forget my nulock code [nokia95]
Dear please reinstall its software. Problem will be quickly solved. Thanks
Feb 10, 2010 | Nokia N95 Cellular Phone
Nokia n81 wlan...
whoov! which school is providing wifi...
anyways ur wifi of the school may be on but the internet modem may be off.
but if ur friends are able to use it,,try and join the exact connection they are login on to.
Aug 05, 2009 | Nokia N81
Nokia E61 Wifi connection
setup Internet access point for WLAN menu>tool>settings>connections>access points select options>new access points Enter Connection name Data bearer: select Wireless LAN WLAN network name: select search wlan to select wlan in range. network status: select "public" if you can see wlan in range WLAN network mode: select infrs or adhoc WLAN security mode: select same settings used by WLAN access point WLAN security settings: Homepage: select the homepage you want
now you can connect & browse the internet. hope this helps
Jul 08, 2009 | Nokia E61 Smartphone
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Trying to connect to my home wi-fi using laptop with installed linksys wpc54g wireless adapter but the problem is when i use linksys utility it starts, but can't find wifi lans i see frozen word searching...
limited or no connectivity means your wlan not communicating with the router, check if you turn on the wlan switch on your laptop or try to install updated driver for you wlan
if thats a external wireless lan card try to unplug and plug it back.
Nov 17, 2008 | Computers & Internet
Cell Phones Logo
89 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
