New washing machine servis M6725,dispenser drawer will not open.only got it yesterday
I have just used my servis washing machine 1300 aa and just went to put a new load in and there is no power to the machine at all i have checked the fuse and the plug wiring what else can i dp please advise???????
Posted on Sep 20, 2009
Kenmore front load washing machine leaking water from under the the detergent dispenser
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub. Pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer and remove it. Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening. Reach down into this opening to see if an item is inside the hose. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again. If the dispenser still leaks, then I recommend calling a service technician to diagnose and fix this problem.
May 01, 2012 | Kenmore Washing Machines
I have a Bosch Nexxt washer, model number WFMC 32000C/01. Yesterday I noticed the fabric softener was still in the dispenser after the cycle was completed. I cleaned out the dispenser and ran another...
Could be the fine holes in upper dispenser are blocked. Remove soap dispenser drawer and use a washing up brush to clean upper dispenser, replace drawer & test. If not could be upper dispenser or inlet valve.
Jan 10, 2011 | Bosch Washing Machines
Water leaking from the dispenser on front load washing machine
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question
Oct 12, 2010 | Kenmore HE2 Plus Front Load Washer
Servis M6755W w/m - fabric conditioner drawer not emptying
I would take the top off and locate the operating lever for the fabric valve as it sometimes gets stuck with soap goo
eric
Dec 25, 2017 | Washing Machines
My Servis M6725 washing machine gradually fills with water even when it is switched off. We have tried changing the inlet valve but it still happens.
this is very comon review
decided to buy a Service M6725 machine. I bought one from Argos 'express delivery'. Installed it in a matter of minutes and did a cleaning wash. From then on the machine refused to work. Argos kindly replaced the machine (with the same model) and all seemed fine for a couple of weeks and then for no apparent reason the spin cycle would not perform. Yesterday a Service engineer arrived to 'sort' out the problem. He told me that the no spin was because of an unbalanced load and the machine was working correctly and left me to try more washing. Same result. House full of dripping washing and an angry wife. I am replacing the machine with another brand. ...
Apr 28, 2010 | Washing Machines
My servis washing machine wont take in softner
Try a "good quality" name brand liquid softener. Some softeners out there are real thick and settle out to be paste. This problem was encountered by me and since I changed to a real liquid, it went away.
Oct 24, 2009 | Washing Machines
Whirlpool Duet leaks soap from dispenser and side of machine at start of wash cycle
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
I have a kleenmaid top loader washing machine. There is a leak coming from the bottom of the machine - I have taken the fabric softener cup out - but there is no bolt to remove the agitator. any ideas?
Sep 10, 2009 | Washing Machines
Fabric condition not emptying
Jun 29, 2009 | Washing Machines
Detergent dispenser drawer stuck
You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
Oct 11, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
462 people viewed this question
Top Washing Machines Experts
