Question about Canon BubbleJet i9950 InkJet Photo Printer
Black-Red-Green-Photocyan-Photomagenta not printing
I've just replaced my print head after the green went haywire and no amount of head cleaning could not get it to work. Now with the new genuine (out of the foil) printhead, 5 colours are not printing.
The Status monitor is ok, the geniune ink levels are all ok in the carts.
Any ideas? as it worked fine up until messing with the print head. Is there a printhead reset?
  • De-Cypher Jul 29, 2008
    Thanks Votit
    All the genuine inks were working fine, i've just put them in the new print head. I've swapped back to the old printhead and its the same 5 cartridges that are playing up.
    I can only put it down to a printer hardware problem not reading the print head. Is there a print head reset (hardware) or some way of resetting the printer back to factory settings?
    I've also swapped pc to check route from them incase its a driver problem.
    If it is a pump problem, can i fix it myself?
  • 4 Answers
I had the same problem. If a whole group of colours isn't printing it is probably because a pipe has come off the pump on the inside.
1. To get at it you need to turn the printer on and as the printhead moves away from its parking spot pull out the power cord. This frees the printhead so it can be moved away from the pump.
2. Now you need to take off the printer casing. To do this remove the paper feeder tray and the flap you lift up to get to change inks. These just pull off when in the up position (or did for me).
3. Undo 2 screws that are on the bottom of the printer. Now with a flat head screwdriver remove the grey side panels. There are little arrows pointing you. From what I remember there are 2 on each side. Now do the same all around the printer. You will see little arrows pointing to slots, follow these all around the printer and also on the front are a few. Be firm but don't force anything and you may want a few screwdrivers handy to wedge under it as you free parts to stop it clicking back down on it's self. (scared I was, but it was broken anyway)
5. Now you should see the print parking pump. It has two pipes on the back of it and two larger ones on the front. Look for which one is off and with a pair of tweezers push it back on. If you can't see the ones at the front you need to get to the bottom of the printer. This bit was fun!!
6. At the back there are 2 screws you need to undo, one on each side. They are the ones furthest from you. You will know which ones because as soon as you undo one it frees the bottom and you can partly lift the inside off of the base. Now it might feel like its not freeing but that is because of a cog on the left hand side. Take note of where this cog is and how it sits. I freed mine by turning it upside down and it came free. It is the cog that is holding it in place.
7. Now you can get to the pipes at the front of the printing pump and attach those with tweezers.
Things to watch out for: The pump pad rests on 4 little springs and these may/will fall off. Fiddly to get back on but not hard.
Also ontop of the pump heads is a little plastic cover. I unscrewed that but not sure if it was necessary.
Service manual can be found here:
http://www.megaupload.com/?d=BLC9L7OU
Posted on Mar 26, 2009
  • 2,071 Answers
Are you using compatible cartridges? If so have you removed any tape that covers the vent hole if required. Many compatibles need to have a piece of tape removed. If you forget the ink cant get out as the air can't get in.
If it not a piece of tape and there are no flashing lights it could be that the nozzles are blocked or the wick has dried out.
You can do a manual cleaning using some kitchen paper and a little solvent and a small plastic bag.
The first thing we need to do is get the head away from its parking position. Switch on the machine and when the head has moved away from its park position, remove the power lead.
With the top of the machine open, you should be able to move the print head carriage by hand.
Look to the right where the head carriage is normally parked and you should see the pump cap area. It will be a black looking spongy pad covered in ink.
Now take a piece of kitchen paper and fold it over a couple times to make a pad approx 3"x1". Now lay this pad over the top of the pump cap and fold the left edge down toward the base of the machine as in image one (the tissue is the yellow bit in the image)
Now take a syringe or similar and put some solvent into it. The solvent I use is JR Ink Jet Cartridge flush as seen on ebay and the like. If you have any ammoniated window cleaner like Windex you can use this. Put the solvent onto the tissue making it quite damp, but not totally soaked.
Manually move the print head GENTLY back to its park position. The pump cap will try to raise up to meet the bottom of the print head as you move it back. Be careful no to force it or you may break something.
What we are trying to do is bring the solvent dampened pad into contact with the print head. Once located, leave the pad for 5 or 10 minutes whilst the solvent does its trick.
Now move the head away from park - again being gentle. You should now see the pad is a horrible black lump of mush. Pick it out and put it in the plastic bag ? where a glove or use tweezers or pliers.
Repeat the process again but this time let it to soak for just about 1 minute. You should now see the individual ink colours soaking into the pad. If the pad is still black, repeat the process a couple more times.
Once you have some evidence of the individual colours you can run a head clean via the driver or printer control panel.
Then print a nozzle check sheet and if all has gone according to plan you should have a full complement of lines.
This method is applicable ONLY for loss of a few lines on the nozzle check sheet. If you have loss of all the lines in a single or multiple colours, you need to investigate further. It is possible that the pump has failed, the pipes are clogged or something else is causing the problem.
If that does not sort it out, tru using a syringe to put a couple of drops of solvent onto the wick. Its the black plastic spike that stick up and goes into the bottom of the ink cart when it is installed. Put a cupole of drops in, put the cart back in and leave it fpr about 10 minutes. The re-try a head clean using the driver/status monitor.
There is another possibilty after this which relates to a hardware problem but this generaly causes a loss of all ink.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Jul 29, 2008
My Officejet 6000 E609n printer doesn't print the correct colors. The red is printing yellow and the blue and green are a lighter version of what is on the screen. I have cleaned the printer head
This is not a cartridge issue. IT is Printhead issue. Since you have done the manual cleaning, it is now time to replace the Printhead.
Regards,
Suhail
May 14, 2012 | HP Officejet 6000 All-In-One InkJet...
Poor print outs of black ink - color is fine - I change the cart. and it stills gves me poor quality prints- I've tried the cleaning process from the menu - now what?
Kodak EasyShare 5000 series
Clean the print head then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Print head Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the print head:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Apr 15, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
Black ink is not dispensing right
Nov 15, 2010 | Kodak ESP 5 Printer
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Ink not mixing properly, Magenta is taking over
return p/head and get a new one.it may b contacts in machine
Jan 02, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
My canon i960 is printing only green
I had this problem. If I tried to print a black& white photo on to glossy paper, it would only print green. When I tried on to plain paper using the 'fast' option, it printed in black. The reason for this is, on plain paper it uses the black cartridge, but output to glossy photo paper using the 'high' option, uses the mix of colours in your colour cartridge. If one or more of your colours has run out, you will get a print with the ink left in the cartridge. Replace the cartridge or refill it & your problem is solved.
Dec 19, 2007 | Cannon Canon i960 Photo Printer
Too much green
It is unlikely that the sudden appearance of a green hue is due to the printhead or drivers going belly up. If the images on photo paper are OK when using the plain paper setting but have a severe green/blue hue when using the higher photo settings it is likely that the photocyan cartridge has been contaminated with cyan ink. Throw the contaminated PCyan cartridge away and fit a guaranteed photocyan cartridge (OEM or compat). Carry out a deep clean and run several plain papers through on a high photo setting. The green hue will gradually disappear.
Dec 06, 2007 | Canon PIXMA iP8500 InkJet Photo Printer
Canon BubbleJet i9950 InkJet Photo Printer Logo
429 people viewed this question
old marine
old marine
