You have several options. However, I'm unsure if you have lost the username/password to access your D-Link router's setup/configuration page or if you have lost your wireless access code (used to access your wireless internet).
If you have lost your username/password to your routers setup/configuration page first try the factory default combination.
The default username is: admin
The default password leave blank
If you have customized the username and password during the original install you will have to reset the router to its factory default settings. To do this:
PLEASE NOT THAT BY DOING THIS YOUR ROUTER WILL BE RESET TO FACTORY DEFAULT AND WILL HAVE TO BE RECONFIGURED
Locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a
paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process.
Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is: admin and leave the password box empty.
Please let me know if I can assist you further.
Regards,
KYTechnology
Try resetting the router. This will reset the password.
Unplug the router, hold the reset button (located on the rear of the device), plug in the router and wait about 60 seconds. Then release the reset button. Now plug directly into the router with an ethernet cable and navigate to 192.168.0.1 or 192.168.1.1 [depends on exact router model] and login. Password is "admin" [no quotes]. Reconfigure the router to your heart's desire. Make sure to change the administration password from the default.
Hope that helps.
1. open a browser such as firefox or internet explorer
2. type in 192.168.0.1 into the address bar and hit enter
3. The username is admin and leave the password blank
Should be a reset button somewhere on it. This will reset everything and you will have to reconfigure it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Wireless Router
It is usually easiest to run the install wizard, but be sure to be ready to set the items listed below.
Things to set:
Note: Routers are intended to be set by geeks. You have to SAVE EVERY page, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes.
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping to bottom of the router. Physical access is not the security issue.
4. Check that your router is set to broadcast its' presence.
