Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
I have a bosch Exxcel slimline, nearly three years old. Last night it ran all night on a 119 minute programm. It was stuck on 1 minute. Now I acnt get it to start on any programme. It starts up ok nut the timer doesn't advance at all! I checked the pump, that's ok and cleaned out the food filters, reloaded salt and rinse aid.
I have a bosch exxcell about 3 yaers old the program gets stuck on 120 all night whats wrong
Posted on Jan 19, 2009
SOURCE:
Bosch exxcel multi programme ....programme gets to 1 min and then stays there. on the quick cycle on the auto cycle it gets to 60 min then returnsto 140min on the timer... thankyou
this is caused by incorrect water levels the appliance takes in too little water at final rinse and generates erro code 1 this is what you are getting it isnt 1 minute to go it will need the dishwasher equivalent of colonic irrigation several tubes will be full of fatty deposits,using the quick wash a lot will make this happen more often you will need an engineer to sort but shouldnt need any parts.
Aug 06, 2009 | Bosch Dishwashers
Bosch SHU4312 won't finish cycle, won't drain.
The control board on these units is prone to a cold solder joint cracking. I have read that Bosch recommends replacement and will supply the board, not covering labor. I repaired mine prior and have done one for a friend as well. Has lasted several years and counting
The symptom is constant cycling without ticking down the last few minutes
Jun 04, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Digital display stuck- machine wont work even after reset
Disconnect power from unit. Disconnect ground. Reconnect ground and make sure it is a good ground check hot and nutural to ground and should be line (110 to 120 V) on line (Black to bare) and 0-4 (with a electronic Volt Ohm Meter) White to bare. And again 110 to 120V from Black to White. Reconnect and if ground is stripped make new ground point with new screw. Modern electronics is required to have a good ground and without one readings like yours can freeze. If this dosnt work the board going to the display is most likely broken.
When replacing the board always ground your self before removing the board from the box and plastic bag. This will drain off and static buildup and prevent discharge across the board. (not as much a problem in humid or warm weather).
Apr 23, 2009 | Dishwashers
I have a Bosch Exxcel Dishwasher, stuck at 1 minute to go
Make sure the drain pump is clear of any blockages and obstructions and that the drain hose wasn't kinked when you re-installed it.
Sep 04, 2017 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch exxcel programme runs until 1 min left and won't finish
This is a fault code which indicates it has not heated through the programme
Dec 13, 2008 | Bosch 24 in. SGS43C12 Classixx...
Bosch Exxcel Washer F21 error code
got a bosch washing manchine it keeps coming up f21 error and i have no book 2 see wot it is can you help me by tellin me wot it is thanks
Apr 11, 2008 | Bosch Washing Machines
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
1,169 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
