Wireless connection disconnects when charging
  • 44 Answers
Some more details ple.
Posted on Jul 29, 2008
How to fix H350 Bluetooth headset? why wont it charge?
You should charge it via wall charger so it charges faster.
Jun 26, 2014 | Motorola Mobility Bluetooth Hands Free...
X box controller keeps turning itself off - I have put new batteries in
Connection problems might be caused by one or more of the following factors:
  • Weak batteries or a weak Xbox 360 Rechargeable Battery Pack
  • Interference from another wireless device, such as a microwave oven, a cordless phone, or a wireless router
  • Metallic objects positioned between the console and the wireless controller, such as a chrome faceplate or metal dividers, shelves, or doors on an entertainment center cabinet
    Note All licensed Xbox 360 console faceplates are tested for interference, and do not interfere with licensed wireless devices.
  • There are already four controllers connected to the console.
uparrow.gifBack to the top THINGS TO TRY Solution 1: Restart your console Turn your console off, wait a minute, and then... Solution 1: Restart your consoleTurn your console off, wait a minute, and then turn it on again.
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 2: Replace the batteries or the Rechargeable Battery PackInsert fresh AA batteries, or attach a fully charged Xbox 360 Rechargeable Battery Pack to your controller. If you have an Xbox 360 Rechargeable Battery Pack
  • Remove the battery pack and reattach it to your controller, making sure that it is attached correctly.
  • Press and hold the Xbox Guide button. In the upper-left area of the Xbox Guide button, the battery meter indicates your current level of battery strength. You might need to recharge the battery pack, if the level is low.
If you have an Xbox 360 Play & Charge kit
  • Make sure that the Xbox 360 Rechargeable Battery Pack is correctly connected to your controller and plugged into one of your console's USB ports. If you check both of those things but are still having the problem, try the suggestion below.
  • Plug the charge cable into each USB port on your console, one by one. There are two USB ports on the front of the console and one on the back. If the controller works in one USB port but not another, try another accessory in the USB port that did not work with the controller. If the USB port does not work with any accessory, your Xbox 360 console might need to be repaired.
  • Turn off vibration feedback (rumbling) on the controller. If you play games with feedback while charging, it takes longer for the controller to charge and might drain the battery pack faster than it can recharge. Here's how to turn vibration off.
    1. Press the Xbox Guide button on the controller.
    2. Go to the Settings area, and then select Preferences.
    3. Select Vibration.
    4. Select Enable Vibration to clear the checkbox.
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 3: Remove objects between the controller and the consoleThe controller works within 33 feet (10 meters) of your console. However, objects placed between the controller and the console might reduce this range. In addition, objects that use wireless technology (for example, a cordless phone) can interfere with your wireless controller. Remove or relocate objects or wireless devices that might interfere with the wireless controller or console. Here are some things that can cause problems:
  • Microwave ovens
  • Cordless phones
  • Wireless routers
  • Chrome faceplates
  • Metal dividers
  • Shelves
  • Doors on an entertainment center cabinet
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 4: Disconnect all controllers and headsetsIf all four rings surrounding the power button on the console are green but the controller has four flashing green lights, four controllers might already be connected to the console. Disconnect all of the controllers, and then try to connect the controller with the problem.
  • To disconnect a wireless controller, press and hold the Xbox Guide button for three seconds, and then turn the controller off.
  • To disconnect a wireless headset, turn the headset off.
  • To disconnect a wired controller or headset, unplug its cable from the console.
To learn more about connecting your wireless controller, please read the following Knowledge Base article: 906947 (http://support.microsoft.com/kb/906947/ ) How to connect an Xbox 360 Wireless Controller to an Xbox 360 console or computer If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 5: Replace your controllerIf your controller still does not work correctly, it might need to be replaced. Please contact Xbox support at the following address: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) uparrow.gifBack to the top Additional supportPlease visit the following Web site for information about how to contact Xbox support: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact)
Dec 05, 2010 | Microsoft Xbox 360 Controller
Can't get y wireless device to work on TPR51. The wireless light is on, but the wireless radio may actually be turned off.
It is not you, it is the router. Are you in a public wireless hot spot or using your own? If the first, contact the person who is in charge to make sure it is not filtering MAC address and not password needed. Then disconnect it and reconnect, sometimes the connection is cached for some previous connected ones and shows automatically connected but actually not working.
Sep 24, 2010 | IBM ThinkPad R51 Notebook
Router was disconnected and I cannot locate the port it must be connected to on my modem.
Hi Tawhelan....
Please watch the following 2 videos very carefully......
(I HAVE PROVIDED YOU A FREE OF CHARGE SOLUTION TO YOUR PROBLEM, PLEASE RATE ME ACCORDINGLY)
Good Luck ;-)
May 11, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Wireless won't connect anymore
Geek squad is expensive. Have you called linksys techsupport? Here is another option, try http://technicalsupport.blog.friendster.com
Jan 20, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
XBox 360 wireless controller won't connect or charge
Guys, you really need to calm down... I have the same problem like you.
I'll tell you step by step why the Xbox 360 Wireless Controller won't work.
1. The controller will automatically disconnect during the gameplay, and the charging kit won't charge.
Solution: This is true what I'm saying now... Where you guys brought your wireless controllers in the stores, there was a Frequently Asked Questions book inside the kit. It told you about the importance of the charging of your wireless controller, because Microsoft informed that it's VERY important to empty your battery before charging it, because the charging kit will no longer charge your battery, and the same thing happened to me. So, if you have any questions of your wireless controller, then contact me at my gamertag, NussKarte. I'll give you new information how to fix your wireless controller.
Jun 30, 2008 | Microsoft Xbox 360 Wireless Controller
Internet connection
Amber,
My guess is, as you also have guessed, the internal wireless card. Since it is under warranty, there should not be charge for it but I don't know the details of your extended warranty.
Jun 18, 2008 | Toshiba Satellite A135-S4527 Notebook
Wireless connection shows it is "Disconnected"
Could be:
- Driver issues with the wireless card - uninstall & reinstall
- The wireless card has gone out - replace
- Wireless configuration - reconfigure
Try these.
May 06, 2008 | IBM ThinkPad T43 Notebook
Computers & Internet Logo
David Payne
David Payne
