Question about Epson AcuLaser C900 Printer
Transfer belt unit is out of service life
The transfer unit on my Epson C-900 is out of service life. A newer one is very expensive and I´m searching for an idea to reset the unit´s counter now. I think, this unit has enough ressources for any additional jobs. You see that differently?
best regards
ITSE12
  • di45 Sep 20, 2008
    Can't put transfer unit back
Epson C-900. There is a fuse in the photoconductor unit and the transfer unit. The photoconductor has a shorter life, so it can be a few years before the transfer unit goes end of life. I suspect the fuses are blown by the machine when the counters get to end of life limit set by the manufacturer. On both components, if the fuse is reinstated/by-passed, the machine will think it has a new part. Spare fuses are available for the photoconductor unit.
The fuse on the transfer unit is a green resistor on a small board behind a black plastic dust cover on the front edge of the transfer unit (remove 3 screws to access). Ask a friend who understands basic electric circuits if you are stumped at this point.
Of course this mechanism is there to ensure you enjoy high quality output from your printer and keep it in top condition. By over-riding the mechanism quality will deteriorate and risk of failure increases.
KAF2008
Posted on Nov 18, 2008
  • Thomas Mickler
    Thomas Mickler May 21, 2014
    Wonderful hint, but it didn't work at all. The EEPROM-Button appeared what pleased me but with OK happened just nothing, unfortunately... Thanks anyway
  • Thomas Mickler
    Wrong comment of mine, changed it with another solution, where unter optional settings one should reset the EEPROM. With CTRL + ALT+ SHIFT + W and a click in the empty field of the window of optional settings. This didn't work. I will try your solution, thanks
Reset transfer unit epson c3800
You can't - at least not without some specialised kit and knowledge.
The transfer belt also has a waste toner collector, so even if you just reset the chip, the waste toner collector would soon overflow, resulting in waste toner all over the inside of the printer (because there would be nowhere for it to go.
Refurbished transfer belts (and fusers) are available via THAT well known internet auction site.
Jan 07, 2014 | Epson Aculaser C3800 Transfer Unit
Oki c5800 belt life reset
It may require a complete service kit, you should check with Okidata to see if there is a kit available or what steps you should take to reset the life counter.
Jan 29, 2013 | Oki Electric Industry Okidata C5500, C5800...
Dell 3110 laserjet printer, belt unit close to life
This message is displayed when the pagecount of the transfer belt is 80,000 (ish)+.
The rated life of the transfer belt in the Dell 3110/3115 is 100,000 pages.
After that pagecount the transfer belt 'expires' and no further printing is possible until the transfer belt is replaced.
Feb 03, 2011 | Dell 3110cn Laser Printer
Dell 3110cn "belt unit" -- what is that?!
hello
here is some information that can help ..
general link to access everything about 3110 laser printer
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&cs=cadhs1&l=en&s=dhs&os=WLH&osl=en&SystemID=PRN_LSR_3110CN&catid=-1&impid=-1
you have to replace TRANSFER BELT, part number you need to order is "HG432 TRANSFER BELT," and you may want to consider "UG190 DAO Service kit: Fuser, SepRollers, TransferBelt, 110, 311XCN" The latter is a kit that contains the XFR belt, a fuser, feed and sep rollers, etc. as well.
this may be expensive ..
Nov 09, 2010 | Dell Office Equipment & Supplies
My phaser 6180 transfer life repalce soon what is
If your Xerox Phaser 6180, 6180mfp, 6280, or 6280mfp is displaying "Replace Transfer Unit" or "Ready transfer Unit Life" you most likely need to replace the transfer unit.
For the 6180 and 6180mfp the part number is 675K47088. For the 6280 and 6280mfp the part number is 675K70583.Here is a video that shows you how to replace this part. It is very easy and requires no tools.
Mar 30, 2010 | Xerox Phaser 6180N Laser Printer
I HAVE E511 PROBLEM ON THE C1100
The "Service Req E511" error message means that part of the photoconductor unit called the transfer belt is not being detected. Please see the following Epson article which may help. http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Aculaser-C1100/Drivers-Support?target=article&extn=.html&articleId=1319
Jan 29, 2010 | Epson Aculaser C1100 Printer
Epson Aculaser C2600 Service code E144
This is a Transfer Belt Error - "Worn Out".
This is not a consumable item. Have had to contact Epson direct who have arranged for a service engineer to replace the offending item.
Nov 12, 2009 | Epson AcuLaser C2600N Printer
Konica minolta magicolor 2200 transfer belt
no this not possible if you are tecnic is possible if you are not I can Help you
Jan 25, 2009 | Office Equipment & Supplies
Epson AcuLaser C900 Printer Logo
546 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
