Question about Lands Phones
Hi, Can you tell me if i can i get more than the last number re-dialed on my panasonic kx-t-7730 if so how? Regards Denis
    Problem Solver:
  • 26 Answers
U can look up the phone manual on.
http://www.ssbg.com.cn/Support/Download/KXT7730.pdf
Posted on Jul 29, 2008
How to turn on caller id on Panasonic KX-T7730. How to set outside line on Panasonic KX-T7730 so that a Panasonic cordless phone can call out
CID is part of the phone system and requires a -93 card and system programming. Panasonic makes different systems that the 7730 phone works on, but it was first delivered with the TA-824 or equivalent system. It also needs to be programmed to tell it how may lines are equipped. Then, when you dial "9" to get an outside line, it will grab the highest WORKING line, instead of just the highest line.
FInd the model number on the system cabinet and do an internet search for the installation manual of the system.
Carl
Sep 01, 2011 | Panasonic KX-T7730 Corded Phone
Our office pabx is a Panasonic KX-TA616. I am trying to program personal speed dial on a Panasonic KX-T7730 (which has 12 CO buttons on the right but no Personal Feature buttons). Neither of the...
Look carefully at the part number on the phone and where you posted. A Panasonic 7730 set has 24 buttons, 12 left side C.O. buttons and 12 right side PF buttons. A TA30830 (new style) has 12 buttons with LED's. In our country, the TA30830 needed 824 version 2 or greater software to work.
In your country the other mate to that is the KXT-7667.
If your phone is one of those and actually works, as in any Panasonic set, the LED buttoon requires a "2" in front of the digit sequence to tell the system it's a PF button.. So, PROG button 2+access code+number STORE saves a speed dial. The access code is what you dial to get an outside line.
Carl
Jul 06, 2011 | Panasonic KX-T7730 Corded Phone
Hi I have a panasonic KX-T433 phone system which I am trying to put in speed dial numbers, we have to dial 9 to dial out does any one know how to do this using a 9 in front?
You have neither a 7730 (the category you asked in) or a 7433 phone sytem. If your phone is really a 7433, you have a TD phone system. Which "speed dial numbers" are you trying to program? System speed dials, are stored in system program 001 and consist of a 3 digit number (may be 2) with a "9" in front and the number as you would dial it from the keypad. Personal speed dial numbers depend on the button you're programming it onto. If it's a button with a light, you dial "2" in front of it. If not, you don't. So, Program 99, button, and either 29 + number STORE or 9+number STORE programs a personal speed dial.
There are other programs to store under the tone pad keys. Those features are covered in your User's manual for the TD system.
Carl
Where is the re-dial?
Hi, Hope this helps.
Making a call using the redial list
The last 5 phone numbers dialed are stored in the redial list.
  1. 1 {REDIAL}
  2. 2 Press {^} or {V} to select the desired number.
  3. 3 phone icon.
I have also inserted a link to the manual below: http://service.us.panasonic.com/OPERMANPDF/KXTG5631S.PDF
Hope i have helped, ALAN
Jun 28, 2011 | Panasonic KX-TG5632 Phone
I have use llinksys PAP2T togather with Panasonic KX-T7730c. does it possible?
Gather what? A PAP2T is a 2-port FXS box. A 7730 is a phone that works on a Panasonic Key Service Unit. You can plug the CO lines of a KSU into the PAP box and the 7730 into the KSU and get dial tone on whatever line you used on the PAP if that's what you're asking.
Carl
Mar 24, 2011 | Panasonic KX-T7730 Corded Phone
How to lock Panasonic kx-7730 telephone set
If it's connected to a TA series box, on the intercom dial 77 xxxx xxxx #, where xxxx is the same 4 digit number. That will lock the phone. It's unlocked with 77 xxxx, the 4 digit code you used to lock it.
You can review the procedure and conditions in the Operations Manual (OM).
Carl
Jan 24, 2011 | Panasonic KX-T7730 Corded Phone
How can i lock my hhone model KX-T7730
The 7730 works on up to 18 different Panasonic key system cabinets. The innocent answer, believing that you have a TA model is dial 77 xxxx xxxx # Where xxxx is a 4-digit code of numbers. It's unlocked by 77 xxxx #.
Please don't post back that you lost the lock code :-)
Carl
Nov 11, 2010 | Panasonic KX-T7730 Corded Phone
Hi i bought my new panasonic KX-T7730 but when i bring it home and try to make a call its not working there is no dial tone can u plz help me
Did you just buy the 7730 or do you have other ones in your house? Since a 7730 is designed to plug into a Panasonic SYSTEM, you'll be waiting a long time to make it work if you're plugging it into a regular phone line :-)
Carl
Sep 28, 2010 | Panasonic KX-T7730 Corded Phone
How can i see dialed call in panasonic phone 7730
Except for the last number dialed on a TA series Panasonic sytsem, the only way you can see all your dialed calls is to capture them on the system's serial port. There are a couple of web based programs that will actually let you capture the data to a PC on the network and view them from anywhere by logging in to the web based interface.
Phonelogger is one of those and it's free, but it requires an XP or lower sytem.
Carl
Sep 26, 2010 | Panasonic KX-T7730 Corded Phone
Is it possible to have the kx-t7730 work on DTMF? My operator says thats the only way I can access some added services
It will, but you may have it programmed to not send DTMF in SYSTEM programming. Since the 7730 is backward compatible to every KX-T system Panasonic made, you need to post a model number of they phone system to get instructions.
Are you in a rotary dial phone system area? There are 3 ways to program dialing, rotary, tone, and suppressed. The 3rd one will ONLY send pulse dial and inhibits the audio. It may be that you can press # and force DTMF. In the last 20 years or so, we have never had to worry about that as our phone companies no longer charge for "touch tone".
Carl
Dec 10, 2009 | Panasonic KX-T7730 Corded Phone
Lands Phones Logo
77 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
