Go to start - run, and type in "CMD". In the black command window that opens, type in: "Ipconfig". Now, open your web-browser, type inn the gateway in the adress field. Example: 10.0.0.1, 192.168.1.1
Now you should be able to log on to you router. Remember that the Haier R800 wifi router is for Windows Operating System only.
Here's a litle guide: http://www.homeauto.com/Downloads/Products/Snap-Link/SnapLinkUserGuide.pdf
The Haier R800 wifi router is for Windows Operating System only. There is nothing you can do except get another Wifi router with can work with your MAC.
if after doing 6 head cleanings and its still the same issue, that only means that the printer is already having a hardware issue, the printer is totally broken
I found this answer on Apple.com support discussions. Worked for me. There is more information available on the discussion, but this was enough to fix my problem.
Try Page Setup. Select to format for your printer. The choices for different all media should now be available under the Paper Size. This is a change from previous practice of creating a separate printer for each type of media.
The latest R800 driver for Windows
epson12379.exe
(which is probably required for Vista as well as XP) has a hardware interface problem.
When you try to print on a CD, the power button should blink slowly and the paper feed button should turn red until the media (CD) is readied by holding the paper feed button down for a second. However, with the driver above, the paper feed button instead blinks very fast (the printer is being "probed" by the PC in a tight loop I would guess) and so the CD cannot be readied.
The previous version of the driver,
epson11222.exe
does not have this problem. But I doubt it will work under Vista.
If you would like this driver e-mailed to you, send me an e-mail to my "junkmail" account asking for it (include this documentation so I know what you want) and I will send it.
My junkmail account is jim3 underline porter6 at fastmail dot fm
(underline, at and dot are not words but single characters)
