Question about Zenith B25A10Z 25" TV
Zenith B25A10Z connected to a DVD player via modulator. We use verzon STB. Dvd will not display on TV when turned on. Remote a/v does nothing. Any help?
  • 5 more comments
  • AlicedeO Jul 29, 2008
    TV was set to 3 as was the modulator. Switching to 4 with the modulator did not bring up the DVD picture. Total loss as to what to do. Alice
    I bought a new modulator from radio shack and new video and audio cables. It is the only TV in the house that requires that set up to view a DVD. thanks for your help, Alice
    No. Will see if I can get a verizon tech to come to the house to puzzle this out. They are no help via phone conversation. thanks, Alice
  • AlicedeO Jul 30, 2008
    Hi Dan, I ended up hooking up the DVD to a second TV I had and placed it next to the Zenith. That way my daughter can do her excercise videos and/or watch TV. I will try hooking every up again with your last advice in mind. That might have been my problem all allong. thanks so much, Alice
  • ktealindi Jul 30, 2008
    same poblem as Alice, except we have Buckeye Cable. Do not have the remote to the TV, ony use cable remote. Toshiba (video recorder) not helpful. Need to change auxiallary button???
  • AlicedeO Jul 31, 2008
    Way to go Dan! You reasoned out my error in the connection sequence and now everything works as it is supposed to do! The key is (for everyone out there) the last connection should be from the DVD player to the TV. Thanks a million! And to think I spoke to three different Verizon Tech support people who did not surmise maybe I did not connect things properly... Again, thanks. Alice Cardamone
  • PHILLYAPRIL Apr 11, 2009
    HOW TO HOOK UP ZENITH B25A10Z TV TO DVD PLAYER?
    DO I HOOK UP DVD TO DISH RECEIVER OR TV?
    TV ONLY HAS ONE CABLE HOOKUP.....
    HELP!!!!!!!!!!
    THANKS
    PHILLYAPRIL
  • 4,234 Answers
If you are using a modulator, usually that sends a signal to channel 3 or 4. Select either 3 or 4 and you should get the signal. The modulator should have a switch to enable you to select one of those channels. Selecting the Video input is when the DVD is connected using the audio and video cables (Red/White/Yellow)
Dan
Posted on Jul 29, 2008
  • 1 more comment
  • ABRsvcs Jul 29, 2008
    Ok. Lets work through this. Do you get a startup screen picture from the DVD or nothing at all? If nothing, I would look for a fault in the modulator. Is there any way to try the modulator on another set? It is still unclear whether the problem is with the modulator or the TV. Can you receive other channels? If so, I would suspect the modulator.
    keep me posted.
    Dan
    Did the new modulator resolve the problem?
    Dan
  • ABRsvcs Jul 30, 2008
    Thanks for the update. Lets try something else. With teh Verizon STB, are you connected to the RF connector or another input to the TV? The DVD must be the last thing inline to the set. In other words, you can not connect the DVD output to the settop box and then to the set. The DVD output contains a guard band that will prevent the passthru from working.
    Let me know what happens.
    Dan
Set top box connection via VCR
CABLE FROM THE WALL TO VCR THEN TO TV. IS ALL YOU NEED
Nov 21, 2009 | Samsung DVD-V5500 DVD Player/VCR
Does the phillips flat screen tv have to be on a particular channel to operate the dvd player
Yes it has to be on the right av/ext
If you have connect the DVD player via a Scart lead all you have to do when your TV is on is then turn the DVD player power on and this should auto change your channel for you..... The scart lead send a voltage upto the tv so this changes the channel for you.
If this for any reason does not work. Then you will have to use your remote for the TV to flick through the AV/source button until you get to the DVD
Hope this helps you out.
Cheers Little Dish Fitter
Oct 06, 2009 | Zenith ZDA311 DVD Player
How to connect a 1999 zenith TV to a cable box and
Connet the output of the cable box to the DVD player and the TV out output of the DVD player to the TV (TV must be tuned to Channel 0, Chanel 3 or 4). You should be able to use the remote to switch between the DVD signal and the cable signal.
Hope it helps.
Sep 08, 2009 | Zenith A25A23W 25" TV
Problems with B25A10Z Zenith 25" tv
that model has had a few different problems that cause this. bad micro,bad regulator,bad caps and tuner shorts. suggest you take to the shop for an estimate
Sep 07, 2009 | Zenith B25A10Z 25" TV
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Can't find dvd channel on my tv...
hi does your dvd player have scart lead connection if yes select av1 or ext1 thanks
shaun
Mar 06, 2017 | Zenith SY2569X TV
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
What is the best set up with an LG flatron TV, DVD REcorder, STB and amplifier
Thanks have solved the problem. I connected the antenna to the STB then to the DVD which connected to the TV via the component jacks then the TV to the amplifier.
Ciao
May 24, 2008 | LG Televison & Video
Bought 2 DTT-9900 converter boxes and hooked them to 2 TV's, get signals after playing around with antenna. but after using both TV's to play a dvd (dvd player hook to TV) The sound went down to almost...
Try turning off the converter box when using the DVD player. The zenith have a second sound control on the converter box remote thus you may have to adjust the sound on the tv remote because you are using the dvr. I set the zenith sound level at the highest level and use on the tv remote only to adjust sound. This eliminated a hiss that the sound control on the converter box was causing.
Apr 28, 2008 | Zenith ZN110 Remote Control
Zenith B25A10Z 25" TV Logo
124 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
