Question about HP Compaq Business d530 Ultra-Slim PC Desktop
D530 I have the same problem as you discribed in your post but it is already out of warranty is it possible to simply replace the capacitor or do you have to change your hole motherboard? Thanks
I have experienced this problem recently. It is a simple and inexpensive (~$50 shipped to your door...) solution to replace the motherboard. I don't repair motherboards so I cannot give advice on replacing capacitors.
Posted on Sep 17, 2008
Capacitors for mitsubishi wd-60737
your question is posted here two times---see answer I already posted.
Apr 02, 2012 | Televison & Video
14 month old samsung 32in 530 series lcd tv will turn on fine, then after a few minutes start turning on and off repeatedly for ever...until i pull the power. What do i do, call samsung?
its possibly dry joints on the power supply-the heat generated causes the solder to crack,and when warm creates a "crater" on the affected joint and expands with heat,and loses contact until cool.(retraction).should be easy if you are handy with a soldering iron!.failing that,take it to a repair shop as its out of warranty,and samsung will not want to know! (unless you got extended warranty,of course!)
good luck,steve
Sep 12, 2011 | Samsung LN32C530 32 in. TV
My latitude D530 laptop doesnt recognize the ac adapter anymore a screen tells me to reset the adapter, how do you do that. I been using this adapter and battery for awhile now it doesnt recognize it
The AC adapter has a small wire in the center of the connector to the system. This sensing wire, if bent or broken will cause the error you mention.
If it's still under warranty contact Dell Support. If not, you'd better buy one replacement.
Try this link: http://www.chargerbuy.com/replacement-dell-latitude-d530-ac-adapter-65watt-19-5v-3-34a.html
Mar 09, 2011 | Dell Latitude D530 Laptop AC Power Adapter...
My hp d530 is suddenly swithing off
Could be an overheating issue. You can open the case and see if the cooling fan over the CPU is spinning when the PC is operating. If not, you should replace it.
If there is a lot of dust inside, you may want to blow it off with an air compressor, but power off and disconnect the computer first. Also remember to stop the cooling fan from spinning when struck by air from the compressor (you can use a wooden pencil to stop it) to avoid damaging it.
Let me know if this helps, best luck
Feb 28, 2011 | HP Compaq d530 SFF PC Desktop
Hi , I Have A Huge problem in My Hp compaq d530 sff
These computer are know to have bad capacitors. Check and ensure that you dont have swollen capacitor on the motherboard. The HP Compaq desktops are notorious for this. I am almost certain you have bad capacitors.
Enjoy the power of a PC.
Mar 15, 2010 | HP Computers & Internet
Memorex dvd player randomly turns off
There is a progressive scan switch on the back of your player. Flip the switch to the opposite position you find it in. If the unit still turns itself off, or won't play a DVD, the unit needs to be replaced. Memorex doesn't repair their players under warranty anymore. They simply replace them. If you're outside of the 90 day warranty, please call 800-919-3647 to speak with Memorex customer service for other options.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 13, 2009 | Memorex MVD2040 DVD Player
My subwoofer for my Logeitech Z-5300e THX 5.1 Surround Speakers omits a loud hum whenever the system is activated. How can I get rid of this?
The sound you are discribing is indicative of a short in the audio cable coming from your amp to the woofer. it doesn't mean that you have to replace a cable, but it could mean that one is loose. I would first try to turn on the unit and then start unpluging each speaker from the back one at a time. If the sound stops then you know that the hum is caused by the last speaker cable you pulled out. It is possible that you could make a temporary fix by twisting the cable back and forth where it connects into the back of each speaker. (Though this would only be a temp fix.) Because these cables are hard soldierd into the the actual speaker, there is no way for a person to simply replace the problem cable.
The other possible problem could be with the cables coming from the computer. You might simply have the cables in the wrong inputs. They should be color coordinated. Yellow in yellow, etc. Or with the system on, unplug these cables one at a time to find the problem cable.
If non of these work, I would bring it back to the store for a replacement system if still under warranty.
Dec 10, 2008 | Logitech Z-5300 Computer Speakers
Toshiba 50h13 picture shakes/ horizontal issue but OSD is good
check out any other capacitor blown or bulged up near to the ic chip .
Nov 26, 2008 | Toshiba 50H81 50" Rear Projection...
Cpu, hd, mem from this d530 slim...
*check the model number of the motherboard and replace the same so that it support your system
Jun 25, 2008 | HP Compaq Business d530 Ultra-Slim PC...
HP D530 Will not start:
It can't be the RAM, it would be beeping if the RAM was not installed properly. If it was and they were bad, it would fail in Windows.
We've had numerous similar problems to yours with our D530's. Check the motherboard to see if any of the capacitors (round barrel shaped components) are swollen (round on top) or leaking. It is a known manufacturers defect and they were replacing those motherboards for free, unfortunately that program just ended.
If the capacitors are all flat on top, its probably the power supply. We've had four go bad in the past month. They sometimes smell like something is burning before they go bad. The D-530 model is unfortunately our most unreliable model ever, they are junk. Good luck.
Nov 26, 2007 | HP Compaq Business d530 Ultra-Slim PC...
HP Compaq Business d530 Ultra-Slim PC Desktop Logo
123 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
