Sanyo dta 150 audio system does not switch on. have checked mains fuse ok.
  • 2,071 Answers
Need to clean and re soldering works.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If i have helped,please click to rate.It is the only way i get paid for my work...
Hope this may help;
Posted on Jul 29, 2008
F150 wont start don't even get lights or anything battery good but nothing else works
What year F-150 ? Do you know how to test automotive electrical circuits ? Find a electrical distribution diagram at Enter vehicle info. year , make , model and engine size . Under system click electrical distribution , then under subsystem click power distribution . Click the search button ,then the blue links one at a time . Start at the battery , with a volt meter ,what's the voltage . Then check main power feeds to power distribution (fuse /relay) boxes . Under the hood , inside the vehicle etc... The first diagram shows two main 30 amp fuse in the ( BJB ) one supply's B+ to the starter relay an if you look down about 5 or 6 diagrams you will A goes to the ignition switch. The other 30 amp fuse powers the PCM power relay . Both of those if open could cause your problem . If these are ok keep looking at main power feeds etc....
Jun 13, 2017 | Cars & Trucks
Check the fuse F01. If the fuse is open change the fuse after confirming there is no other faulty component.
If fuse is OK the check C10 voltage is normal or not. If its not normal then change BD01.
If the voltage on C10 is normal the check the SMPS switching ICs IC01 and IC02. If found faulty change IC01 and IC02.
Check the current digital audio stetting is its in PCM or Bitstream . IF it's in PCM then change it to Bitstream.
If ther is no diagital audio out even after it to bitstream, check the AV receiver settings. If everything is ok there too then check the AUDIO DATA at AIC Pin 4 (for BD)or AIC3pin 13 (forDVD) using CRO. If there is no audio data the change the main PCB.
If the AUDIO DATA id ok then check DIGITAL AUDIO DATA at pin7 of AIC3 if there is no audio data then change AIC3. If its OK, Check 5V at AIC2 pin 14. If the 5V is missing check the power supply. If 5v is ok the change the main PCB.
ANALOG AUDIO MISSING........................
Electronics Equipment Repair Center
on Feb 14, 2015 | Samsung Televison & Video
Sanyo DP42647 tv won't turn on.
sanyo LCD tvs recieve the on command from the main board so chances are the main board was also damaged
Jul 06, 2012 | Televison & Video
My Bose radio stopped working, no sound no lights AWRCC1
Check its power cord first. If it is OK, check its power supply section inside. There will be a fuse at the power supply rectifer board. Check it. If it is found opened [damaged] never put an other fuse, without proper check to the power supply and main audio amplifier section. There must be some reason for the blow up of this fuse. Without rectifying the fault, replacing an other fuse, may make more components to get damaged, and the repair work may cost more. OK.
Feb 26, 2012 | Bose Wave radio/CD remote control -...
How do i switch to aux with out remote on sanyo dc-mm5000
You can select the aux by pressing the video button one the frond panel of your system.
Jun 09, 2011 | Sanyo DC-MM5000 CD Shelf System
The outside unit does not operate. All i can hear when i turn it on is is ticks for a minute then turns off. I have reviewed the inside of the unit and no error light comes on except for a led light...
D25 code : Check power supply voltage to the outdoor unit is correct (1ph ?220 Vac ±10% or 3ph ?380 Vac ±10%). If OK, check fuses, if fuses are OK replace outdoor main PCB
compressor seized. Check compressor windings all equal resistance 1 to 4 Ohms, check to earth 50 MOhm minimum, check run current and Inverter outputs
Hope helpful?
Jan 04, 2011 | Sanyo Split System Air Conditioner
I have a Sanyo CE32WP5B television and nothing happens when I switch on the set, would this just mean the fuse near the on/off switch has blown?
That sounds like you have a power supply fault.
If the mains fuse has blown on the chassis, check the Switch Mode Chopper Transistor and dry joints around the transformers.
Be careful replacing the chassis in the case as the join gives problems!
Hope this helps.
Oct 23, 2010 | Sanyo Televison & Video
Well my t.v. sanyo dp32647 will not turn on
Chek the fuses and if OK check the main power source board.
Aug 13, 2009 | Sanyo Televison & Video
Yamaha RX-V461 receiver audio
Disconnect the unit from the mains at the wall socket. Leave powered down for 5 mins to ensure a good reset and turn unit on again and see what happens. If there is still no life. Check for failed fuses inside amp. ALWAYS RELACE FUSES WITH THE SAME RATING AND TYPE.
Dec 15, 2007 | Audio Players & Recorders
