Yamah HI-Fi amp - speakers stopped working - Audio Players & Recorders
    Problem Solver:
  • 4 Answers
It could also be that you've selected the tape monitor which will have this effect.
Posted on May 13, 2009
  • 2,071 Answers
Check the resistance of the speakers, if no resistance, then it already busted,or maybe the connection of speaker wire to the cone is loose or crack try to check it out.Then if you check already and it tight no crack ,then the problem is in coil winding of the speaker,it needs to rewind...
Hope this may help,
Regards,
VOTIT
Don't forget to rate;
Posted on Jul 29, 2008
REAR SPEAKERS ON PIONEER VSX-401
@Michae Yokeum
"Rear Speakers on Pioneer VSX-401".
Hi Michae.
Wow, nice Hi-Fi!! :) :)
IF [manual_required] THEN
GOTO
https://www.pioneerelectronics.com/StaticFiles/Manuals/Home/VSX-01TXH_OperatingInstructions0523.pdf
ELSE
Check your SBch* setting which should be set to ON or AUTO.
*Speaker Back channels
More info on pg. 83 of manual.
PS - as this is a home hi-fi and not a car-radio, I've moved it from 'Cars & Trucks' to a new home 'Audio Players../Pioneer', where experts in that field can offer more help.
Oct 15, 2017 | Pioneer Audio Players & Recorders
How to hook speakers up to a realistic mpa-40
The MPA-40 is a mono public address amp. So it has one speaker output. You select the appropriate socket to suite the speaker type. The 4/8/16 Ohm outs are for various tpyes of Hi-Fi speaker. The 70 Volt is used for muzak in shopping centres, restaurants, and waiting rooms.
If you have a pair of 8 ohm Hi-Fi speakers, you can diasy chain the connections and then use the Com and the 16 Ohm connection.
Daisy chain means you take the wires from a pair of speakers. Connect together the wires going to red on one speaker and black on the other. This now leaves you with two wires going to the other red and black terminals on the speakers, but the ends in your hand are not connected to anything yet. Plug the black in to COM. Plug the red in to 16 Ohm.
The sound from the speakers won't be stereo. It will be mono because that's all the amp outputs. But both speakers will work so long as they're functioning units.
If you have two 4 Ohm home theater speakers then you can do the same trick. 4 + 4 makes an 8 Ohm load. Connect the red to the 8 Ohm output.
Don't be tempted to try to connect to multiple terminals. The amp isn't powerful enough to to run more that one speaker chain.
Hope this helps
Sep 15, 2014 | Audio Players & Recorders
How do I hook up klh 2503 speaker system
You need a stereo receiver or Hi-Fi amplifier to drive these speakers.
The amp or receiver will have red and black speaker terminals to match up with the speakers. Use some speaker wire to make the connections.
Once the amp and speakers are connected, you can add a source. The source could be your PC, TV, games console, MP3 player.
Aug 09, 2014 | Audio Players & Recorders
Does this unit come with speakers
If it has no volume control or terminals for speakers then it is a hi-fi seperate and needs to be connected to an hi-fi amp to work.
Dec 31, 2010 | Pyle PT649D Single Cassette Deck
CAN i purchase speakers for sanyo da 1000
Unless you want the same speakers for cosmetic reasons, you can get a pair of speakers from any Hi-Fi outlet. All you need to know is the max power output of the amp in watts for each channel, and the ohms it puts out. For instance if it says 8ohm 15 watts. You can get a speaker of 8ohms or higher, but not lower. And any speaker above 15 watts.
Actually you can get better quality sound from the speakers as the speakers they often put with these systems are rubbish in terms of hi-fi quality!
PS
Just had a look around the net and the output power in watts is just 8. Couldn't find the ohm rating but most are 8ohm. So any speaker higher than 8 watts will do the job.
Feb 10, 2010 | Sanyo Audio Players & Recorders
How to incrise the bass of sony MHC-RV777d
Is it possible that the speakers are out of phase, where one speaker is moving out, the other is moving in, resulting in zero bass?
Other than checking wires, making sure + on amp is linked to + on speaker, try changing the eq settings, or sit them next to a wall - walls help bass a lot.
Jan 08, 2010 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
New amp is whining
Try switching power amp output's to the speaker's and see if it still does it if it still does it the it's the speaker ,disconnect every thing from the input's of the power amp if it stop's start pluging thing's in one at a time ,process of elimination best of luck
Dec 27, 2008 | Audio Players & Recorders
Speakers stopped working
Try to reload your drivers for your sound card.
Make sure there are no conflicts with any new software and or hardware that you recently installed.
If you are using XP try to restore your computer to a date when your sound was working.
Hope this helps.
Good luck.
Mac
Feb 09, 2008 | Audio Players & Recorders
Speaker act more like tweeter only, not mid range + tweeter
They are mid Hi speakers.1st Open them and check if the mid speakers are ok maybe they are defected or the protection is open. Good Luck Toufic Malek
Sep 22, 2007 | Yamaha NS-A327 Speaker
118 people viewed this question
 Grubhead
Grubhead
