Question about Tally Serial Matrix T2155 Printer
Tally t2155 - Showing "Hardware alarm wrong board"
When we start the printer up Tally T2155 - it shows initialiazing and then the message "hardware alarm wrong board"
  • Anonymous Mar 13, 2014
    this error cod is changed every time of start printer
  • Anonymous Mar 20, 2014
    alarm code +1046 029 444
    Alarm comes on while printing
    New Friend:
  • 114 Answers
Change the logic board. your problem will solve.
Posted on Jan 31, 2009
    Problem Solver:
  • 17 Answers
Specifically IC5 on the logic board is bad. Either replace the logic board or IC5.
Posted on Apr 02, 2012
This error is due to bad Head cable. Changed the both head cable will resolve the problem.
Posted on Mar 28, 2009
What is the problem when a Tally T2265+ printer show the error message? How to clear this error message?
it sounds as if this will be a problem with a board and you will need to have it replaced
Jun 20, 2014 | Tally Office Equipment & Supplies
Hardware Alarm Wrong Board tally 2280
Hi Denis,you are having wrong board tally because you fixed the wrong part.pls check the part number and get a new one and fix it back.
Apr 11, 2014 | Tally Matrix T2280 Printer
My printer is showing error as "hardware alarm +1308 +131 --- 000004+0381+1317" wat could be the problem
The hardware error indicated on your printer is indicating that the printer is encountering problems when moving the print head.
This error can be indicated if there is any thing which may be preventing print head movement, things you can check include;
The printer ribbon is not jammed and is located correctly in the printer,
You can also check to ensure there is no paper jam of loose paper which may prevent print head movement,
You can also check the carriage shaft to ensure it is free from paper dust or any other obstructions.
With the printer powered off, the print head should slide freely across the width of the printer, you can then see if there is any obstruction to the printhead
Nov 18, 2011 | Tally Matrix T2280 Printer
Printer TALLY T2155 error +0257 113----- 000032+0375+0268
This is a motor function select error.
It means the printer can not select the paper input, or does not detect it has selected it.
usualy the problem is caused by the dirt on the sensor located beneath the function select gear or on the function select gear itself (the gear assembly directly driving the paper feed tractor).
if you power off and on again it may work again, but the problem will come back again if the sensor and disc are not cleaned.
Dec 25, 2010 | Tally Serial Matrix T2155 Printer
BOOT displayed on LCD display
The 'Boot' message indicates the printer has switched to the firmware download mode as it has not been able to load the firmware.
This can happen because the firmware has become corrupt, in this case you can reload the firmware and the printer will be back working.
This problem can also be seen if flash memory has become damaged, this will not be recovered by reloading the firmware, the logic board will need to be replaced i you are unable to rectify the problem by reloading the firmware.
The firmware for the T2155 can be found on the Dascom website at;
Oct 08, 2009 | Tally Serial Matrix T2155 Printer
The print speed of the T2155 when printing at 10CPI is 550 Charaters Per Second.
The direct repalcement for the T2155 would be the 2265Plus available from Dascom, for details see;
Jul 23, 2009 | Tally Serial Matrix T2155 Printer
Tally T2250 showing an error..
when power on the printer the printer coming leftside and showing hardware alarm
check ribbon
+0306ne -007 000
000000128 +0304
error in display. how to rectifie the problem
Jan 29, 2009 | Tally T2250 Matrix Printer
Please help
I am already faced this problem, This Problem is due to Bad Head cable. Repaced that cable, your Problem will be resolved
Aug 20, 2008 | Tally Dot Matrix T2265C Printer
T 2250
tally t 2250 give hardware alam
code +03211 ne -007000 000000 128+0304
Jan 19, 2008 | Tally T2250 Matrix Printer
Tally Serial Matrix T2155 Printer Logo
801 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
