Question about LG 24 in. LDS 5811 Built-in Dishwasher
Dish washer planning for a dish washer in kitchen ,please tell me the arrangements i have to done for this.
  • ECHUCAELECT May 11, 2010
    I'm not sure what your question is. Are you planning to buy one ? You will need power,water and drainage within the hose length of the machine. Drain needs to be at least 1 foot off the floor and do not seal the drain pipe to the drain. You need air entry to the hose to prervent syphoning. In my experience LG make an excellent diswasher,parts are cheap and easy to fix.
Don't get an LG! It doesn't wash (even after 2 hours and 15 minutes of trying); it doesn't dry; it uses a lot of water and wattage; and it's tough to get repaired by an "authorized" serviceman. I bought it because it was quiet and capacious, and it is these things. But a Whirlpool at HALF the price does TWICE the cleaning job! I had a Bosch, too, which did a great job, and was quiet, and used no water, but which broke down all the time. Good luck!
Posted on May 21, 2009
I cant get any help from Samsung to repair my washing machine been a month now with zero results!! I've been calling every week because they give appointments to fix but do not show up. PLEASE HELP
oh bummer.....please tell me what is exactly going on with the washer it may seem like the control board/diagnostic board in the washer is having issues and may need replacing im sorry how samsung is treating you...
Dec 26, 2016 | Samsung Washing Machines
What is the average cost for a arrange a birthday party program? I want to invite 50 people.Please give your ideas!!!
Actually its totally depend on your plan,because if you want to arrange any free host then the average cost will reduce.I think you can done within $500 if you arrange the party in your home garden.for more cost ideas try http://birthdayplanet.net/
Oct 28, 2013 | Celebrate Express Lil Cupcake 1st Birthday...
How do I test a used dishwasher before I install it?
Hi knowone has ever asked me that before but it can be done if you spend a little time You need to be near a power 120 volts plus water and a drain , if you look under your sink in your kitchen on the hot water valve you should be able to connect into the hot water , if you plan on hooking it up at this sink then go ahead and splice in a tap for water for the dish washer on the hot water you should buy a shut off type valve most times they use 3/8 , run the hose from the new water valve to the water valve on the dish washer then you need a drain that is the easy part run the drain hose from the dish washer right into your sink ,next you need power , down where the wires connect you will see a black wire and a white wire , if you have a old extention cord around that you can cut leave the end on that plugs into the outlet on the wall but cut the other end off , next open up the end of the cord to see the wires , if it has a green you dont need to use this for a quick test only if you want to , but hook up the black and the white then you should be all set to try it If i can help any more get back to me Frank
Dec 12, 2011 | Hotpoint Dishwashers
Pump running continuously, Yes there was a drain pack, have emptied water, float switch clicks when moved with screw driver. Only one red light shows ( last cycle - pots ) what else can I do... James
What type of dishwasher do you have? Has your kitchen floor flooded? If it has. The tray under dish washer isn't water tight. Moisture creates some unusual problems. Some of newer dish washer the there control panel under the top of door this also create problem especially if the switches are on the top of the door. Another moisture problem. I have repaired a new Electrolux dish was three times in less than 6 months. The floor would flood from the Maytag side load washing machine. The Madam of the house didn't tell me that the washing machine flooded the kitchen floor. No window in the door and sometime fill water solenoid would stick and fill the tube. When they open washing machine door, 12 gallons of water would spill. So I fix both of them. GB...stewbison
Aug 21, 2011 | Asko Dishwashers
Lots of mold around rubber gasket; unable to clean off; odor from mold; water in detergent trays; maybe some water leaking from washer; washer bought in 2008
Use a s.o.s pad to remove mold there will still be staining but it will gey the bulk of.Now to get rid of the smell ( this has been a mixture I have used for about ten yers works every time) put the washer on hot heavy wash start when done filling drain what you want to do is make sure the water is the hottest it can be. now start washer again on hot wash when you see water in bottom of tub stop machine to open door ADD two cups of dish washing power( brand does not matter I tell most people to buy cheap stuff at walmart) start machine let it run till you see powder disolve then stop washer and add 1 cup bleach. let unit go through complete cycle..If your washer has a clean cycle use that instead of the heavy or normal cycle. The most I ever had to do this treatment was 2 cycles and it worked every time.Note all front load washers the door must be left open to pervent odor/bellows should be wiped clean after each use/and a good cleaning at least once a month. anyhow if this helped please vote if you need more help please ask
NOTE the dish soap is the stuff for a dish washer
Feb 09, 2011 | Frigidaire GLTF2940ES Front Load Washer
How do i connect my dish network to the emerson renee_hywd@yahoo.com
It would be our please to help with that. How we are going to connect your receiver to your TV depends on which receiver you have and which cable we plan on using. Please visit our website for information on how this is done: http://www.dishnetwork.com/SupportSection/setup-receiver-totv. Thank you for being a valued DISH Network customer!
Phillip Chang DISH Network Customer Service Representative
Nov 26, 2010 | Emerson LC320EM8 32 in. LCD TV
Dishes not getting clean
the problem is hard water. there is a new product out at www.dishwasherfilter.com that filters the water going into your dishwasher leaving your dishes crystal clean with every load. it is very affordable and works amazing. it even has a money back guarantee. you will love this product.
Mar 23, 2009 | Dishwashers
Can a dish washer be installed in a corner of my kitchen cabinets
It depends on you kitchen layout. If it is small and you need a place to install the dishwasher, the corner is fine. It is no different than placing a sink, wall oven, or refridgerator there. I have done all of the above, and they were not in small kitchens.
Dec 09, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Appliences - dish washer
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Wait!!!!!!!!!!!
it's new and under warranty and you did not cal Frigidaire???????????????????Mistake ! Frigidaire has the authority to send any retail dealer to swap it out!
It's called a "push pull"
Get on the phone Thursday and ask for a supervisor!
tell them you have been fighting with best buy from day one!
with no satisfaction! tell them you redid your whole kitchen with their alliances! Do not say 3 appliances !!
Your whole kitchen!!!!!!!!! They do this push pull every day some where! And if your out of warranty it's okay too because it was damaged from day one and Best buy held you up!!!!!!!
You will be okay!
Just be calm and speak quietly and nice and sweet!
Let me hear your good ending later!!!!!!!!!!!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Jul 16, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Help 3
you need to remove the lower panel on washer the pump pluged up the hose going to the pump from bottom washer can be removed but be aware all the water in washer will go on floor remove what ever in the pump put hose on put in to the spin cycle when done should open
Feb 28, 2008 | Washing Machines
LG 24 in. LDS 5811 Built-in Dishwasher Logo
74 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
