Question about XFX GeForce FX 5200 Graphic Card
Hang when my pc running,its automatically hang.but i dont know whats the sound card,agp is i want to sollution this problem.please help me.
  • 144 Answers
RAM can be the problem, but also changed BIOS settings can be the cause. Go into BIOS and select to load default settings, than save and close to see if the problem persists.
Other solution is to perform a checkdisk, perhaps a damaged part of your HD is causing the hang.
Posted on Aug 08, 2008
    Problem Solver:
  • 8 Answers
Hello Sir
Your problem is your PC hangs in between.
See, the problem may be due to RAM. Some times it happens that RAM does not synchronize and causes problem.This problem can be solved by changing your RAM. Avoid using two RAMs.Use a single RAM.Contact your Computer vendor.
Fixya Member abgog
Posted on Aug 03, 2008
Problem with my geforce4 mx
Sounds to me like either the card is bad or you have a corrupt driver. If you remove the card will it start? then it is a bad card. If you uninstall driver either through safe mode (hold F8 at powerup before windows starts) or restore to last known working config (also F8). I suggest you go to nvidia website to download your drivers. let me know if you are still stuck, we'll work it out.
Jun 27, 2009 | Nvidia GeForce4 MX440SE 128 MB AGP Graphic...
Video Card
Okay this model is rather hard to find the specs for lol. I need to know what type of slots you have on the inside. You should have some PCI slots which look like this. I need to know if next to them you have an AGP slot which looks like this. (Note, the AGP is usually brown and above the PCI slots).
Based on this information, then you can purchase either a PCI video card or an AGP video card which will work in your system.
PCI Video
AGP Video.
Thanks and please rate as fixya.
Jan 27, 2009 | Gateway 500XL PC Desktop
GeForce 6600 AGP 8x 256 MB in Asrock 7s41gx
get another hard disk and do a fresh install of xp then the drivers and the game see if its all ok
if it is then its your drivers get them out and replace them
with the latest from nvidia. or format and go again
hope this helps
Dec 30, 2008 | Nvidia GeForce 6600 256MB 8X AGP Video...
Trouble building a pc
I have installed a nvidia cd installer to my unit and I found out that the latest cd (nvidia installer) the lots of driver installed in it, means it has the old nvidia driver to the latest nvidia driver and automatically detect the kind of driver needed to your cp. Better if you have a cd installer for that.
Dec 06, 2008 | Computers & Internet
first try to use your video card to another PC which that video card suits the voltage requirement, and monitor requirement, if the result is still the same, try to return it to the store and buy a new one, and if the result is good, maybe it's time to upgrade your Power Supply, and your monitor.
Oct 17, 2008 | XFX GeForce 6200 Graphic Card
Pls help please!!!
Video setting in couter strike try Mode in open Gl the bit low resolution
This is makeing my angry! grr
that card is waaaay too old for games!!!
If you need more help just ask ;)
A fix problem when playing any games like EA Sports FIFA 2007
Problems with this kind of "PC Freeze" or Hang Up when oppening
games or 3D accelerated applications are you dont know what part
of your PC is failing... many of this problems are very hard to fix...
first of all it might be a power supply problem.. take note that it gives the proper current for your pc to work,therefore a failing PSU
will make your PC freeze... another one is your motherboard, if you have a faulty motherboard it might make your pc freeze... this might be a video card problem too... maybe your video card is overheating or it can also have conflict with your built in VGA
try disabling your Built in VGA... try cleaning your pc with dust and try to run it again... and last is your sound card... it might have conflicts on your onboard sound chip... try disabling it at your BIOS... as ive told you its complicated because you will never be sure what part of your pc is causing the problem...
and also check if your pc is overheating...
top 5 problems are
1. Power Supply is Failing
2. Video Card is overheating
3. Faulty Motherboard
4. Your PC is overheating
5. Hardware conflicts
i wish you good luck and i hope my reply helped... :)
Aug 25, 2008 | ATI RADEON 9200 Graphic Card
My pc hang >>> help
Feb 19, 2008 | XFX GeForce FX 5200 Graphic Card
you can't enable/disable the AGP slot in your bios unless you have integrated Graphic card inside your motherboard ..
does your previous graphic card work with the motherboard ?
Dec 25, 2007 | HP Vectra Xe320 PC Desktop
XFX GeForce FX 5200 Graphic Card Logo
91 people viewed this question
Top XFX Computers & Internet Experts
Alun Cox
KG John Justin
KG John Justin
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
