Question about Electronics - Others
My usb pendrive problems
There is a problem on my 8 gb pendrive. when i keep files in it after some time it does not open and keeps on repeating the files.what can i do to solve it.
  • 304 Answers
The best thing you can do is remove the software on the drive that came with it. Make sure you back up whatever you need on it first. Sometimes you need special software to remove the built in programs but don't worry I have them and will send them to you free. Once you have removed the software format the drive. It will now show up as a standard removable storage device. This will also solve compatability problems when switching between different computers. I hope you find this info helpful,
geokohler @gmail.com If you can't find the software you need tell me what make and model pendrive you have and you number in an E-mail and I will send you what you need by attaching it to my reply as a Zip file. If you ned more help feel free to ask,
George
Posted on Jul 29, 2008
How to convert 2gb sd card into 4gb
How to convert 1 or 2GB memory stick into 4GB?
Just follow the simple instructions:
Step1: Insert your memory stick in USB port
Step 2: Open the Drive increaser software folder (download the software)
Step 3: Rename the Pendrive or memorystickimage_thumb%25255b35%25255d.png?imgmax=800
image_thumb%25255b32%25255d.png?imgmax=800
Step 4: Open Drive Increaser 2 icon from the Downloaded folder.
image_thumb%25255b6%25255d.png?imgmax=800
Step 5: The opened file is asks USB drive Name. (Before enter the name first Rename the Memory stick or Pen drive). Just enter the renamed pen drive name. Ex: 2341
image_thumb%25255b16%25255d.png?imgmax=800
Step 6: After that, it will ask USB pendrive letter (Ex: H or I or J). Repeat this two times
image_thumb%25255b43%25255d.png?imgmax=800
Step 7: After Drive letter entry some process will be done with Red color like this image
image_thumb%25255b49%25255d.png?imgmax=800
Step 8: Finally it shows Done Please enter any key to done.
image_thumb%25255b56%25255d.png?imgmax=800
Now your Pen drive is 4GB
image_thumb%25255b63%25255d.png?imgmax=800
Jan 12, 2012 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I had a pendrive of 8 GB my friend tried to make a bootable pendrive so he changed some settings by command prompt. My pendrive storage capacity dropped from 8 GB to 3.44 GB I need a good solution please...
It seems that after your friend made it a bootable pendrive, he/she did not format it.The space has been used up by the installation files in the flashdrive,and these files may be hidden.This is likely to be the case with some command-line utilities for making bootable flashdrives.
To recover your space, simply format your USB pendrive.To do so on Windows XP,insert the flashdrive into your PC, go to My Computer, right-click the USB pendrive,and in the window that appears, click the tools tab and select the Format option.
That should solve your problem.
Jan 25, 2011 | Computers & Internet
Hello sir i have kingston 32gb Ccore ccm3110 pendrive it can copy any thing but after copying to my pc the first video file can play ony 14.2 min and others will not open at all solve my problem please
May be your pendrive has corrupted the files or may be your pendrive has some viruses.
I suggest u not to use so much memory on pendrives as sometime pendrive automatically corrupt your data.Use small memory of pendrive.If u want to use big memory it's better u use hard drives
Jan 08, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to rename kingston pendrive 8 gb datatraveler 101
I tried renaming it by right clicking but its not working.its 8 GB kingstone pendrive.can you help?
Oct 16, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I connecting my kingstone pendrive(32gb), after pasting some files (any video,audio,etc) that files are danaged in pendrivem plz solve problem
insert 32 or 2 GB USB go to control panel administrive tools computer management disk mangement you can defragment this USB drive or you can right click select properties tools check now?tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files
hope this helps
Oct 08, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My 4 GB V30 Transcend pendrive is not getting detected in any OS (linux and windows 7). In windows its saying that driver software installation failed. And in device manager its coming as unknown device....
try to open in another computer see if it opens there n get ur data first coming to the unknown device issue, firstly insert ur pendrive to usb slot firmly then refresh your comp for about 5 times wait till the drivers are installed open "my computer" n see if the pendrive icon is displayed if its displayed double click n start using . If the above procedure does not work first time do repeat it ur pendrive will work for sure
Sep 20, 2010 | Transcend (589307) Media
I have puchased 256 gb pendrive.but it is not formating in my laptop
Go through the device manager to see if the USB pendrive has been installed correct.y I recommend using USDDeview to monitor all you USB Hubs and ports.
I have created a script installer for this excellent software that will also update the USBID for you download link
http://rapidshare.com/files/301142652/USBDeview_USBIDS_Installer.zip
http://depositfiles.com/files/q242avlrb
PLS Download both keep my links alive.!!!
Jan 07, 2010 | Computers & Internet
I have a kingston 4gb pendrive, currently i have a problem with new folder in it. i never put any new folder in it and there it appears to have 'new folder' thr. when i try to open it, it wont open, and...
best thing to is plug your pendrive into ur computer
now make a new folder onto ur desktop
right click on desktop-options -new folder
now right click in new folder -scroll down to rename -and type a name u can remember
now open your pendrive
pick all your folders you want to keep
hilte all except (new folder)now right click and pick desktop then the folder you named now give it a name at the bottom now press ok
once done
take out pendrive
now check your files are in the folder you renamed
now plug pendrive in right click -options format
once formatted your pen drive is empty and ready to use again
hope this help
Aug 30, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Problem with transcend jetflash -8 gb " files in unknown format"
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
Mar 25, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
