Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca 61 projection not powering on
I read about this issue and it says something about a flyback what's that? And where can I get one
    Genius:
  • 1,030 Answers
What is the issue? The flyback is the transformer that generates the high voltage needed for the picture tubes. the itc222 rca chasis can have problems with flyback but they are notoruis to trouble shoot. if if it is you flyback then you will possible have other issue like the horizontal ouput transistor. I work with these alot here at the shop. what is set doing .. does the led flash .. give me some more information and lets see if we can fix this
Posted on Jul 29, 2008
I have an RCA P61937, and the picture is bowed and distorted....what can i do to fix this problem?? and how do i know what part i need
well look under power supply board around flyback. they have bad solder joints. it will then blow
the 400 ma fuse. just rtesolder the flyback and replace the 400 ma fuse beside flyback
Feb 15, 2011 | RCA P61927 61" Rear Projection Television
Wont turn on
If the power indicator flashes three times and then goes out. You will need the 270125 flyback repair kit which has the replacement Flyback transformer and the associated capacitors, plus the CD with detailed instructions. You can get the kit at www.tvrepairworld.com under the RCA repair kits catagory
Nov 28, 2009 | RCA HD61W66 61" Projection HDTV
RCA D61W20B WHEN YOU GO TO TURN ON GREEN LIGHT COMES ON FOR 3 SECONDS 3 TIMES, AND THERE ARE NO CLICKS OR OTHER NOISES, FOR AWHILE IT WAS HARD TO TURN ON. ANY HELP THANKS JIM
replace the flyback # 259296 and CP150 that should solve the issue. You can get replacement flyback and CP150 at the following link and they provide free instructions
http://servicemanuals.vstore.ca/
Apr 02, 2009 | RCA D61W20 61" Rear Projection Television
I have an rca hd61w66 and the autoconvergence is not working. Is there anything that I can do or is there something that maybe I'm not doing?
If the convergence is way out fl231 is probably open (its a .4 amp fuse) the fuse goes bad because of the bad solder connections on the flyback. solder flyback connections and replace the fuse. the convergence should be back to normal.
Feb 02, 2009 | RCA HD61W66 61" Projection HDTV
Focus leads for D61W20 Rca 61" Tv
Just enough to have wire sticking out reinstall in FBT.
Jan 18, 2009 | RCA D61W20 61" Rear Projection Television
The tv does not work
yes flyback and yoke and h.o.t all should be replaced.
repair shop was right.
Jan 09, 2009 | RCA D61W20 61" Rear Projection Television
RCA HDTV #D61W20, CHASSIS ITT222
you will need a new flyback number 259296 and also a new cp150 which is a 2200uf 25V radial capacitor. You can get replacements at the following link and they provide free installation instructions.
Sep 19, 2008 | RCA D61W20 61" Rear Projection Television
RCA DLP TV
That is either the flyback auto transformer or the relay getting energized. I reckon it is some issue with these, or a failing power board. Best get a technician to look at it, as some spot inspection and testing will be required to isolate the faulty components.
Jun 01, 2008 | RCA HD61LPW167 61" HDTV
My rca p60752eblg2
Yes it does sound like the flyback is bad, the only other thing that arc is a picture tube.
Dec 05, 2007 | RCA P61940 61" Rear Projection Television
RCA 61" Model P61960 stopped working
You have a flyback transformer and horz output transistor bad
Nov 04, 2007 | RCA P61960 61" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
47 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
