Question about Frigidaire FRS26R4A Side by Side Refrigerator
Ice forms in the section on top of the refrigerator
There are two openings in the plastic on the top part of the inside of the refrigerator, right behind the temperature selector. A solid block of ice formed in these holes, and I can't get it to melt. Because of that, the inside of the refrigerator isn't cold enough, even though I have it set on the coldest setting. I can feel ito these holes, it's a solid block of ice. I've tried defrosting it with the hair dryer, but it hasn't seemed to do any good in melting it. I can't find my user manual to see if there is a solution to it there. The refrigerator is cool, not cold. a few months ago water from running from the bottom floor of the fridge. i unblocked the drain hole and this has stopped the water, but now a large block of ice is forming at the top of the back wall of the fridge. the fridge is not not as cold as it should be even on the highest number.
    Master:
  • 518 Answers
See if this link helps you out.
Geno
Posted on Jul 29, 2008
Samsung RL38SCSW Fridge Freezer not Cooling
Sounds like an air leak around a door seal or the ice maker chute door is open causing frost buildup on evaporator and everything inside the freezer. You also may have a defrost drain line blockage
APPLIANCE 911
Jan 07, 2016 | Samsung RL38SCSW (113 cu ft
Lsc27914st/00 ice maker will not fill the tray, prior to that is the water leaked down the walls of the freezer
Hello KYMBERLY;
My name is Peter. I am a retired field service refrigeration technician.
There is a white plastic fill tube that runs from the back of your refrigerator into your freezer. This fill tube in the freezer section is open at the top. This tube goes into the ice maker fill cup on the right hand side of your ice maker. Opening and closing the freezer door - warm air gets in, forms condensate, and freezes. So, your fill tube and/or your fill tube is blocked with ice.
Remove the extra storage shelf in front of the ice maker. Using a hair dryer defrost the ice in the fill cup and fill tube. This is located on the right hand side of you icemaker.
Oct 27, 2014 | Refrigerators
Kenmore coldspot(side-by-side) Model:106.56612500,Type2555A;MFG date:Aug.2006. Freezer and Refrigerator Control both at factory preset position(center). Problem:Left frozen section seems colder than usual...
The defrost system is not working. Ours had a sensor go bad that clips on the coils inside the freezer and can tell when their is front. When it is not working the frost just keeps building up because it down not call for the defrost heating wire to ever come on. It could also be that the wire is bad or that the control panel is not responding the the sensor. It sounds liek the issue is no defrost cycle though.
Oct 06, 2010 | Kenmore Refrigerators
Refrigerator Freezer has ice forming in the bottom inside freezer section. It appears to be leaking down the back inside compartment. The top section has an ice maker and water dispenser but I haven't had...
I believe you just described a defrost condensate blockage that is causing the leaking. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a in the defrost pan, water leaking and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
Nov 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Mar 26, 2009 | Refrigerators
Water inside fridge
the water is coming from the top portion of the refrigerator section. the insulation between the freezer and the refrigerator is getting wet that is why the coldness of the freezer is transferring to the refrigerator trough the insulation foam. you can see droplets of water forming underneath the refrigerator section. sometimes you can see ice forming underneath also.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Refrigerators
Ice
it is getting moisture from the refrigerator side.
check closely the door gasket of the refrigerator side, look for cracks and openings and see if it is not sealing properly.
another place to look at is the plastic trimmings around the refrigerator side between teh inner wall and the outside edges.
sometimes they have cracks and openings and moisture could seeped in and makes ice at the lower part of the freezer section.
tnx 4 using fixya,
drcool
Sep 19, 2008 | Refrigerators
Judging by a similar problem I had with a dehumidifier, you may have a Freon leak or low freon pressure - (It's probably NOT really FREON - but something else).
This is a fair guess - from my dehumidifier problem. A dehumidifier functions the exactly the same way as a refridgerator - except it's not designed to "keep the cold in a BOX." Given the cost of a service man AND the cost of the Freon (it's expensive), you may want to pitch the Fridge and get a new one.
Mar 13, 2008 | Whirlpool ET8RHMXKQ Top Freezer...
Water always inside refrigerator sometimes ice forms
Sounds like you might have a condensation problem. Is the fan in your freezer working? If not it's not circulating the cold air. If it is you might have frost on the lower rear wall of your freezer meaning its not defrosting like it should and restricting your air flow. Last but not least you have a damper door in the upper left corner of your fridge that allows the cold air from your freezer into the fridge to cool it, that might not be opening up. Any one of these things would cause your water problem and a warm fridge section
Dec 05, 2007 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
132 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
