Hi Darryl
Usually won't spin until water is drained to a low level.
Wont drain possibly because of blockage or pump blocked or stuck. (A Common Problem in Washing Machines)
So... As for further Troubleshooting
Process of elimination.
Where is Time Wheel set and what does it require to advanced to next stage.
Think of it as a Rotating Timer Switch stopping at each stage to check conditions.
The stages are controlled by sensors like "High Water Level"
The Sensor could be a simple Float Switch... eg. "High Water"
If water is High... Dont allow door to open and don't allow spin.
But do allow Pump to run.
It's all Plain Logic like used in computers (If, Then, Else)
Also Known AsTruth Tables
Good Luck
Truth Table Examples
