Problem with the F/T setting.
Can I use my fax machine only as a fax and turn off the telephonefunction? although I have a distinct ring and a designated phone number it is still interferring with my phone line, and I cannot recieve phone calls without the fax picking up. I have lost the manuel When I get a phone call the fax interfears with the call, I have got it on fax/tel.
I have annother phone hooked up at another point, have a seprate number for the fax and phone but both on the same line. the other phone gives a fax noise when I try to answere it andy help would be appreciated
The fax machine is a Sharp FO- P610
  • 13 more comments
  • lenjh Jul 29, 2008
    I have tried this before
    Have got the instruction booklet found this know help
    they are on two different sockets but it is the same phone line with two different numbers. one for the fax one for the phone but when the phone rings it rings on both the phone and the fax machine, but if I answer the phone the all I get is the fax noise
    have tried this already
    have tried putting it on just fax this does not work either what was the other advice about dont understand
    that does not work
    tel mode works ok but I then dont get faxes when I am not home
    Dont know about this one how do you set it to auto
    I will try this and get back to you later thanks
    Votit This was already done
    worldvet cannot reset machine
    tc still cnnot get it to work
    maclean what is this connection for
    tasman 105 it is not hookedup to the computer
    ginko I am not worried about the fax calls when answering what i am trying to say is that when I get a normal phone call I answer only to hear the fas squeeling in the phone when a person is trying to talk
    Brigadier General:
  • 6,966 Answers
To my understanding, you have a single telephone line but with the use of some device, this single telephone line splits to two (2), one for voice phone, one for fax only. The voice phone has its own phone number and likewise the fax machine. Your concern is when an incoming voice call rings your voice phone, when you answer it, you also hear you fax machine answering the voice call.
What this means is the device splitting your single telephone line to two is the probable culprit. You may have to consult with your phone provider. There is nothing wrong with the fax nor for that matter the telephone.
Assuming that the single telephone line is equal to two (2) telephone numbers (because of the splitter), pls try calling the fax number using the voice phone and vice-versa. If either rings then problem is elsewhere. If the number is busy, it is your telephone provider's problem.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 30, 2008
    Master:
  • 623 Answers
Your best bet would be to separate the phone lines
Posted on Jul 29, 2008
  • 197 Answers
The only thing that i can think of is to shut it off when your not useing it . or there is something internaly wrong with the fax
question also is the fax hooked up to your computer or is it a stand alone.
    Genius:
  • 1,665 Answers
Better ask your local phone provider if is possible to provide you an ISDN telephone connection.
  • 2,071 Answers
Follow this LINK
http://www.retrevo.com/s/sharp+ux+b700+manual
Try this option;
Go in the menu/or options mode ,find receive and select auto mode
hope this may help
Regards,
VOTIT
  • LORETO LACARON
    LORETO LACARON Jul 29, 2008
    Only telephone provider company knows this well.try to ask them..
    Master:
  • 497 Answers
You could set the BT machine to manual, fax only (auto), fax/telephone or TAD/fax with one button switching between all the options.
  • 1 more comment
  • Yaz  S
    Yaz S Jul 29, 2008
    or Call your local phone provider and ask if they provide "call block" service. Most phone providers do carry "call block" service
  • Yaz  S
    Yaz S Jul 29, 2008
    All you have to do is activate your call block service and it will automatically ask you if you want to block the most recent number that called you (you might not have Caller ID or be able to *69 to get the number). This way you don't have to even know the number, you can just activate the call block immediately upon receiving one of these annoying calls. Of course, if you DO have caller ID you can just access your "call block" feature and type in the number you want to block.
    Thanks for using Fixya
  • Yaz  S
    Yaz S Jul 29, 2008
    take ur time..but plz do update us
    Tc
    Guru:
  • 859 Answers
This should be as simple as setting your fax to receive on Fax only and setting the fax pickup to 4 or more rings.
You could also use a line discriminator for your fax line so taht calls in with no fax Request to Send tone sequence would be picked up by a regular phone on this number. The line discriminator is a Radio Shack item
Hope that helps you decide.
Worldvet
  • Glenn Rogers
    Glenn Rogers Jul 29, 2008
    OK. The thing to do next is to reset your fax machine. There are two ways to do this.
    a. find in the menus the command, if any, to restore factory defaults.
    b. unplug your fax machine for 24 hours and then plug it in again.
    The first option is your best bet, frankly, as suggestion number two will not unnecessarily solve your problem.
    Otherwise, when you reply in this post, Tried That, please refer to the expert who offered the solution. This will help all of us to get you a solution more quickly.
    Should you find that that none of these answerers are helping you you can refuse them all, close this premium post out and place it it the free forum.It nay take longer to get you going again. But, you will get more varied answers as some of our best experts only work in the free forum only.
    Regards,
    Worldvet
    ps Once again, try the restore factory reset in you menus.
  • Glenn Rogers
    Tenjh,
    The fact in this matter is you are greatly confused by the fact that your disticntive ring is not working correctly.
    You will need to confirm with your phone carrier that you have a fax phone distinctive ring setup and not just a distinctive ring for a teen vs parents.
    Otherwise, you need to purchase a phone line discriminator that will route fax calls to your fax machine and regular phone calls to your handset.
    You must accept this fact, sorry. This is how these things work.I've never heard of a fax machine that had a built in phone line discriminator.
    Sorry about that. A small investment in this line discriminator will solve your problem.
    Regards,
    Worldvet
  • 10,594 Answers
If you increase Ring Counts in Fax machine, you will get more time to reply phone call before it answerd by fax itself.
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Jul 29, 2008
    Hello again,
    TEL mode:
    This mode is the most convenient for receiving phone calls. Faxes can also be
    received; however, all calls must first be answered by picking up the fax's
    handset or an extension phone connected to the same line.
    Hello again,
    If desired, you can change the duration of pseudo ringing in Tel/Fax mode up to 120 seconds. Your Fax will receive fax when you are not at home.
    Hi again,
    If desired, you can change the number of rings on which the fax machine
    answers incoming calls in FAX and TEL/FAX mode. Any number from 2 to 5
    can be selected.
  • 19,396 Answers
If you have a seprate number for the fax and phone, you will have two separate phone socket for the two numbers. Assuming that you connect fax machine to fax line socket and phone to phone one, Fax and Telephone they cannot interfeer with each other, as they are running on different cables and on separate sockets.
  • Ginko
    Ginko Jul 29, 2008
    Situation: "they are on two different sockets but it is the same phone line with
    answer the phone the all I get is the fax noise"
    The only way to fix this is to get a separate number and phone line for a fax.
    All you can do is making fax machine answering time shorter, but this won't fix completely the problem.
    This is the situation, if you have fax and phone on the same line you must cope with the fact that you can get some fax calls on the phone, as the fax and phone calls are being routed to both machines.
  • Ginko
    Ginko Jul 29, 2008
    Well that is the truth.
  • 813 Answers
  • sandip panchal
    sandip panchal Jul 29, 2008
    two socket of one is line other is phone u have plug in line socket come line from the telephone exchange & other is phone u have plug your phone there
    Guru:
  • 1,894 Answers
Leave these phones unused for one day and then use it and see.
leaving them unused will make everything get settled.
  • dewan nafees ahmed Aug 05, 2008
    please take ginkos solution. that speaks best
Hooking up fax to KX TG7871 Panasonic Phone
There is excellent support here on basic fax setups. You have what is known as "Distinctive Ringing Service". There are pros and cons to the various setups. I assume you recognize the rings and answer only when the ring for the landline talk comes on. The fax will pick up the faxes, and the answering machine will pick up the voice.
Need model number of your fax - google that!
Service manual for your phone.
http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
This link shows various configurations of setting up your phone/fax/answering machine or using an answering service.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00059780#Dist_ring
Distinctive Ringing Service setup While it is not available everywhere, a distinctive ringing service can be purchased from most telephone companies. With this service, more than one phone number is assigned to the same phone line. Each phone number will ring differently. The main number will ring with a normal single ring and the additional number will ring with a distinctive ring pattern assigned by the phone company.
When a distinctive ringing service is used, set the Rings to Answer to 2 and then follow the steps below to set the distinctive ringing pattern:
  1. Press Setup , press 4 , and then press 1 to enter the Answer Ring Pattern setup of the Advanced Fax settings.
  2. Use the Right Arrow to scroll through the available settings. When the ring pattern assigned by the phone company displays (double or triple rings), press OK .
Mar 06, 2014 | Lands Phones
Our HP 2140 fax under distinctive ring setting DRPD was answering under our Master ring (double Ring) until yesterday it switched inside somehow where it now answers regular phone ring instead of...
Was the fax plugged into another telephone line? Maybe a power surge?
My solution would be to reconfigure the fax from scratch to learn the ring pattern.
From the Manual:
Step 1-Teach the HP Fax the ring pattern
The HP Fax will learn the ring pattern when you call it from another telephone or fax
machine.
1. Be ready to call the fax machine.
2. Press Menu repeatedly until BASIC FAX displays and press OK.
3. Use LEFT ARROW - RIGHT ARROW BUTTONS to scroll through the options until DRPD Mode displays and press OK.
Call this fax from another fax machine... Waiting Ring...
will display.
4. Call the HP Fax.
DRPD OK will display when the pattern has been learned and the HP Fax will return
to Ready mode.
Step 2-Set up distinctive ring (DRPD) answer mode
Once you have activated distinctive ring, it becomes one of the answering modes you
can select by pressing the Mode/Contrast button.
Press Mode/Contrast repeatedly until DRPD Mode appears in the display.
• In Ready mode, DRPD appears in the right hand corner of the display.
• Now, the HP Fax will manage calls and faxes as if it were set to AUTO mode
(AUTO mode on page 28)
TIP: Distinctive ring must be set up again if you reassign your fax number
or connect the machine to another telephone line. Once set up again (that
is, the fax machine has learned the ring pattern and the answering mode is
correctly set), you should test the fax machine by calling the fax number
and another number on the same line. The machine should respond
appropriately to a call placed to the fax number with fax tones, and to a
normal telephone call with the expected ring pattern.
Mar 04, 2011 | HEWLETT-PACKARD HP 2140 Fax
How to set fax machine so it can accept after 2 rings?
Distinctive Ring basicsDistinctive Ring service is an optional service available from many telephone companies. The Distinctive Ring service permits you to assign more than one telephone number to the same telephone line. Distinctive Ring allows you to use a single phone line for both voice and fax calls. You can assign a unique phone number and ring pattern for incoming fax calls. When a fax comes in, each telephone number makes a distinctive ringing sound, such as a single ring, double ring, or triple ring.
NOTE: The Distinctive Ring Service is the name HP and others use to describe this feature. Distinctive Ring is also known as:
  • Call Sign
  • Custom Ring
  • Ident-a-Call
  • Ident-a-Ring
  • Ident-a-Ring
  • Multi Ring
  • Personalized Ringing
  • Ringmaster
  • Smart Ring
  • Teen-Ring
The Distinctive Ring Service allows the HP product to work similarly to a dedicated fax line. If you connect an HP fax product and a telephone to one telephone line, you can assign one telephone number for fax calls and another for voice calls.
NOTE: You cannot send or receive faxes when the phone line is in use. Even if the HP fax product has a separate telephone number, it is still sharing the same phone line. Set the Distinctive Ring Service Using the menus on the product control panel, follow these steps to set a distinctive ring pattern. Step one: Turn on Auto Answer Turn on Auto Answer by pressing the Auto Answer button on the control panel. The button light indicates when Auto Answer is on.If the button light is already on, you do not need to press the button. Step two: Set the distinctive ring patternFollow these steps to change the answer ring pattern.
  1. Press the Setup button (c01461502.gif ) on the product control panel.
  2. Press the Right Arrow button (c01185072.jpg ) to select Advanced Fax Setup , and then press the OK button.
  3. Press the Right Arrow button (c01185072.jpg ) to select Distinctive Ring , and then press the OK button.
  4. Press the Right Arrow button (c01185072.jpg ) to select one of the following options:
    • All Rings
    • Single Rings
    • Double Rings
    • Triple Rings
    • Double & Triple Rings
  5. Press the OK button to select the option.
  6. Press the Back button (c01490920.gif ) to return to the main menu.
Now if you have anymore problems copy the link from below and paste it in your address bar and it will help you further with a document. Follow all the settings in the document and your fax should be setup,keep in MIND THAT THE RINGS TO ANSWER SHOULD BE 2,SO YOU CAN RECEIVE FAXES AFTER TWO RINGS
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01647469&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3795406
Feb 01, 2010 | HP Officejet 6500 Wireless All-in-One...
How do I use use a distinctive ring to separate the incoming fax from the incoming normal calls I want to direct to the answering machine. I am from S. Africa. I am using an all in one Samsung SCX-4521F. I...
Firstly, you will need to get a 2nd ringtone from your phone provider. Most of them will provide a designated "fax ring" (not a new number) for little or no cost.
In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. “Distinctive Ring” is a telephone company service which enables a user to use a single telephone line to answer several different services.
Using the Distinctive Ring Pattern Detection feature, your fax machine can “learn” the ring pattern you designate to be answered by the fax machine. Unless you change it, this ringing pattern will continue to be recognized and answered as a fax call, and all other ringing patterns will be forwarded to the
extension telephone or answering machine plugged into the EXT. jack. You can easily suspend or change Distinctive Ring
Pattern Detection at any time.
Before using the Distinctive Ring Pattern Detection option, Distinctive Ring service must be installed on your telephone line by the telephone company. To set up Distinctive Ring Pattern Detection, you will need access to another telephone or someone available to dial your fax number from outside (a cell phone will do!).
To set up the DRPD mode:
1 Press Menu until “Fax Setup” appears on the top line of the display.
2 Press the scroll button ( or ) until you see “Receive Mode” on the bottom line and press Enter.
3 Press the scroll button ( or ) until you see “DRPD Mode” on the bottom line and press Enter.
4 When “Set” displays on the bottom line, press Enter.
“Waiting Ring” appears on the display.
5 Call your fax number from another telephone. It is not necessary to place the call from a fax machine.
6 When your machine begins to ring, do not answer the call.
The machine requires several rings to learn the pattern.
When the machine completes learning, the LCD displays “End DRPD Setup”.
If the DRPD setup fails, “DRPD Ring Error” appears. Press Enter when “DRPD Mode” displays and retry from step 3.
7 To return to Standby mode, press Stop/Clear.
When the DRPD feature is set up, the DRPD option is available in the Receive Mode menu.
To receive faxes in the DRPD mode,
you need to set the menu to DRPD;
NOTES:
• DRPD must be set up again if you re-assign your fax number, or connect the machine to another telephone line.
• After DRPD has been set up, call your fax number again to verify that the machine answers with a fax tone. Then have
a call placed to a different number assigned to that same line to be sure the call is forwarded to the extension telephone or answering machine plugged into the EXT. jack.
• In Tel mode, you can receive a fax by picking up the handset of the extension phone and then pressing the remote receive code Alternatively, you can press On Hook
Dial
(you can hear a fax tone from the remote machine) and then press Start on the control panel of your machine.
• In the Fax mode, the machine answers an
incoming call and immediately goes into fax
reception mode.
• In Ans/Fax mode, the answering machine answers an incoming call, and the caller can leave a message on the answering machine. If the fax machine senses a fax tone on the line, the call automatically switches to Fax mode.
• In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. This option is available only when you set up the DRPD Mode.
The full user manual for your machine is located here
Hope that is of help to you :)
Nov 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Fax receiving problem
press the set up button or the tool button the printer . then use the right arrow or left arrow button scroll to basic fax set up ,and advance fax set up. u will find the distinctive ring pattern under advance fax setup. also check if u are using any telephone answering machine if using check the rings to answer in ur printer should be 2 rings higher than the rings to answer in the telephone answering machine.also turn off the error correction mode.turn the auto answer on.try this steps
Sep 11, 2009 | Office Equipment & Supplies
Answer a distinctive ring?
No, distinctive ring is not available on this machine.
May 24, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Setting personalized ring
Its called distintive Ring. This is the instructions from the manual -
VERY IMPORTANT
If you have Voice Mail or a TAD (Telephone Answering Device) and want to keep
one of your phone numbers dedicated only to fax calls, you must leave the fax machine
in MANUAL mode at all times while using the distinctive ring feature. Here’s why:
Manual mode will never pick up a call by itself, since it is «Neutral ». When the fax
machine is in this « neutral » mode, the Distinctive Ring Feature can be activated. The
distinctive ring feature is actually an answering mode. So, do not activate FAX ONLY
mode or FAX /TEL mode while using distinctive ring; otherwise, the fax machine will
answer calls for all the numbers.
Registering the Distinctive Ring Pattern
Set the fax machine to MANUAL mode.
2 Press Menu/Set, 0, 1.
3 Press to select DISTINCTIVE:SET?, and then press Menu/Set.
4 Press to select the prestored ring pattern you want to assign, and then press
Menu/Set. (You will hear each pattern as you scroll through the four patterns.)
Be sure to choose the pattern assigned by the Telephone Company.
5 Press Stop/Exit.
and a link to the manual if you need it -
http://static.tigerdirect.com/pdf/brother-IntelliFax-775-Manual.pdf
Feb 21, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Audible ring has changed/machine won't answer when called
It is to do with "smart ring" feature or in your area called "distinctive ring" feature. The machine won't receive unless the ring pattern matches your distinctive ring pattern. If you are not using that feature, then you must turn the feature off. Then set your receive mode to "fax tel" mode if it is your only line.
Jan 16, 2008 | Brother IntelliFAX 2800 Laser Fax
Try this address for the manual download.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=17b84254e3dbb23957d540855b6268ee&q=Brother+FAX-1820C
Nov 13, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
172 people viewed this question
jasbo
jasbo
