High voltage out of aerial socket on my mitsubishi bd 33s tv
    Habit-Forming:
  • 163 Answers
If this is the case you need to get it checked out before it checks you out permanently you have an earthing problem or a breakdown in insulation and it is very dangerous
Posted on Jul 29, 2008
No dvb signal on Vierra Panasonic tv
If the tvs share the aerial but only one is working then the wiring of the non functioning socket has shorted. Perhaps the cable you used to connect the second set is damaged,try another. PERHAPS THE AERIAL SOCKET HAS BECOME DAMAGED,THIS ONLY COSTS A FEW PONDS/DOLLARS TO CHANGE. Alternatively it might be the wiring from the roof to the wall socket that is faulty.
First things first, check that the tv is working by connecting it in the other room. If it does work there you will know that theaerial socket in the second room is faulty and can begin testing.
Jun 03, 2015 | Panasonic Televison & Video
Will not connect to tv channel
  • Connect the existing Aerial/Cable TV
    signal (or from the Cable Box/Satellite
    Receiver {RF OUT or TO TV}) to the
    ANTENNA-IN socket on the
    recorder.
  • Use the supplied RF coaxial cable to
connect TV-OUT socket on the
recorder to the aerial input socket on
your TV (VHF/UHF RF IN).
Helpful Hint:
- Depending on how you have currently
connected your TV channel (directly from an
off-air aerial or Cable box or VCR), you will
have to disconnect some of the cables before
you make the above connection.
Feb 02, 2013 | Philips DVDR3380/05 DVD Recorder
Technika flat screen tv forgets digital channels found if switched to standby
Channel memory of stored channels is contained in a Eprom which may be part of the microprocessor------voltage when set is shut off is often from either the standby supply or even a filter cap that holds sufficient charge to maintain voltage for the memory.
Look in those areas first.
An alternate way would be to go to a box and input signal to rear audio and video jacks---the box would then retain channel memory etc and this would bypass your issue.
Apr 17, 2012 | Televison & Video
Horizontal hold does not seem to work. horizontal lines in pic
hi,
Is there is white horizontal thine line on all over the screen then the screen voltage of you TV is high. Can be caused by bad base socket in the picture tube neck, faulty focus/screen block. Check the two things. You can see the base socket at the picture tube neck replace all the three base sockets for the three CRTs. if problem remains then you have to replace the focus/screen block. focus/screen block is one through which you can adjust the screen voltage and focus voltage. If the potentiometer in side it have some problem then this problem can occur. Have added the image for two items for your reference.
ok
Jun 09, 2011 | Mitsubishi WS-55807 TV
How do I hook up a Sharp Bd-HP24Ua Aquos BD Player?
The only option you have is to connect it via Component cables (Red, Blue, Green) and analog audio cables (Red, White) to get an Analog HD 1080i at best picture and analog stereo sound. I have to tell you though, your BD player is better than your TV and by using it on this TV you are missing out on the unit's full potential of features. I would highly recommend you consider upgrading and if your're looking to save a few bucks and get an amazing picture, consider upgrading to a Mitsubishi DLP. They are as low as $799 for 60".
Apr 23, 2011 | Mitsubishi WS-65611 65" Rear Projection...
My tv auomatic off after 1 mi
1]...Please check that the sleep timer function is not set;
2]...Some tv's have a count-down timer & switch off if there is no signal input, either from the tv aerial, or av input;
Please check that the aerial is plugged in to the correct socket on the rear of the tv; test the aerial in another tv, to make sure it is working ok.
3]...It could be a problem with the remote/teletext panel?
for example, switching unexpectedly to standby, or changing channels unexpectedly?
4]...It could be a power supply fault;
for example, switched mode power supplies (SMPS) can cause problems; this could also cause the set to switch to standby mode.
PLEASE NOTE:
If the unit still switches off after 1 minute, even after checking the tv aerial is functioning properly, & is connected to the tv unit aerial socket ok, & the source is set to the tv aerial, then this could be indicative of an internal fault.
TV sets contain extremely high & very dangerous voltages, even after the tv has been unplugged from the ac power socket, on the wall, which could kill you!
FOR THIS REASON, & FOR YOUR SAFETY PLEASE DO NOT attempt to open or repair the tv unit yourself, unless qualified to do so - please take it to the tv repair shop;
only qualified tv engineers should attempt to carry out tv repairs.
I hope this information was helpful for you.
Thanks,
Steve.
Oct 01, 2010 | Symphonic SC313D 13 in. TV/VCR Combo
When the tv is first turned on, the tv will show fine then occasionaly go to a static screen and audio
SOUNDS LIKE A HIGH VOLTAGE ARC. THIS CREATES NOISE THAT PASSES TO ALL OTHER CIRCUITS. THERE CAN BE SEVERAL PLACES THIS CAN HAPPEN ALL AROUND THE TUBES. THERE SOCKETS AND THE HIGH VOLTAGE TRANSFORMER
Dec 27, 2009 | Mitsubishi WS-65857 65" Rear Projection...
Find channels
You say you`ve plugged the outside aerial lead directly into the DVD recorder aerial input socket, you connected an aerial link lead from the aerial output socket on the DVD recorder and you`ve got a Scart lead from the TV output socket on the rear of the DVD recorder into the AV1 socket on the TV. I`m saying all this because in the past, I`ve had customers say this to me only to find when I call round that they`ve plugged the aerial into phono sockets instead of the earial input socket. The aerial lead will fit physically but not electrically. Have you got a good picture on your TV with the DVD recorder switched to standby?? If yes, Does it play a DVD perfectly through the TV?? If yes, then everything is connected up correctly, When you press the virgin menu button to your DVD, it should show setup/install?? When you do get to the free-view or channel setup/install menu, and you tell it to search for new channels, does it scan?? Does a bar or do the numbers rise and the % number rise as it finds new channels?? If they do and everything is connected and working as I described earlier but still no channels are found, Try unplugging from the mains and reboot your DVD recorder, then repeat the whole menu install procedure sequence again. Other than that, there`s nothing else you can do, Basically, you`ve got a faulty machine where it requires an engineers eye I`m afraid. Ian
Jul 29, 2009 | Wharfedale Televison & Video
Aerial socket
Hi..
As I have seen the full specs of your LCD monitor I don't have seen any aerial port or a socket features with your monitor it only supported by a DVI-D, VGA signal input, that's means that it has no aerial socket.
Hope it helps...
Enjoy
Pls. rate & hope to hear more from you soon..
tnx
-micro
Feb 10, 2008 | LG MW-30LZ10 30 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
