Question about Smeg Kitchen Ranges
Need a replacement for one of the legs for SMEG Stove - gas stop & electric oven - Model No. FS60 WHNG (60 x 60). and name of a Brisbane, Australia Service person/firm.
    Master:
  • 623 Answers
Try this...
Address:Brisbane Appliance Service Center Pty Ltd, 55 Ipswich Road, Woolloongabba //'); } else { document.write('Javascript must be enabled in order to use Google Maps.'); } //]]> Javascript must be enabled in order to use Google Maps. Contact: Phone (07) 3391 0360
Posted on Jul 29, 2008
Smeg FU65-5 Oven temperature & timer & function knob lights not turning on and oven does not heat up but the fan comes on.
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Dec 02, 2012 | Smeg 24 in 60 cm Stainless Steel Electric...
SMEG OVEN BRAND NEW WON'T HEAT
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Sep 08, 2012 | Smeg Ovens
Smeg SE290x-5 oven stopped working
Replace igniter if gas .or if elect replace element
Nov 09, 2011 | Smeg Ovens
How do I know if my stove is three fase. I am in Brazil and the here power is 220v. Would you help please?
Your oven is 2 phase 220 volt not sure about foreign electrical service.The stove requires 2 phase electric service,each leg impute can be no more than 135 volts.It requires 2 pole 60 amp service with no less than a 8 gauge 3 wire service line with ground.The pigtail on the stove is as follows,black wire 120 volt leg red wire the other 120 volt leg the white wire is the neutral leg,(which is sometimes run to the ground block which incorrect but will work) the green wire is ground.
Jun 13, 2011 | Whirlpool Stove Oven Sensor 8053344
I want to change my smeg oven element please smeg
i hate my electric oven how can i change it to a gas stove
Feb 13, 2010 | Ovens
Gas stove with electric ignition (oven stopped working)
the electric ignition is bad and needs replaced in oven. I had the same problem a few months ago and it was the ignitor for the oven. if replacing it yourself, be very careful with ignitor, it is very fragil. do not touch ignitor itself, hold on to it by the base of it. they are not that hard to change.
Jan 31, 2010 | Kitchen Ranges
Smeg Oven blowing
If the stove is vented to the outside, it may be just drawing air from the room through the fan.
Oct 14, 2008 | Smeg A2.2 Gas Kitchen Range
Kitchen Ranges Logo
105 people viewed this question
Top Smeg Kitchen Ranges Experts
ashburton
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
