Slow Laptop Computer
I have a 40G NEO Laptop computer. I have a lot of pictures, music, and videos stored in it. It has started to run really slow lately. I can't even run two programs at the same time. What can I do? I tried those registry cleaner programs, I don't know if they help. Thanks!
  • jane0128 Aug 03, 2008
    Thanks, I already did suggestion #2 and #3. Still a little bit slow, but not as slow as before. Will download AdAware and see how it goes.
    Thanks again.
    Jane
    Brigadier General:
  • 6,966 Answers
There could be a variety of reason(s) why the laptop is slow. If initially the unit was fast enough for your applications, it maybe that there are a number of programs running simultaneously and/or harmful to your PC. Pls try:
  • run/scan with your antivirus and/or an online virus scanner/remover;
  • Download AdAware by Lavasoft, install, scan and delete unwanted entries;
  • Go to Start, Run, type "msconfig", goto Startup tab and uncheck all programs except those that you feel are necessary such as your antivirus;
  • In your System Properties Advanced tab, Performance Settings button, select "Adjust for best performance", and in the Advanced tab, change your Virtual Memory to double your onboard real memory.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 29, 2008
Slow upload of pics and videos on my pc
I would start by clearing out your cookies, then I would do a disk defragment to clear out old stuff your computer is loading. If you have desktop widgets or are running programs that take up a lot of memory.
Go to Start, Control panel, internet options, and click to delete temporary files and then after go into programs, accessories and disc defragment. Hope it helps!
Sep 09, 2012 | E-Machines eMachines Desktop PC
Tip
If your laptop is running slow and applications are taking a long time to load...
If your laptop is running slow and applications are taking a long time to load here are some tips that may help you solve your problem. Laptop computers are not much different than desktop PCs. They both require maintenance to keep them preforming the way they should.
First of all of if this is a recent problem that started after you’ve installed or uninstalled a program. Use your restore feature and go back to a previous state when you know your computer ran good. You will also want to update your antivirus software and run a full scan, the same with your spyware software.
Be sure to update the definitions on each program before you run your scans. You want to make sure your computer is free from any viruses or spyware as these will really slow your laptop down.
Unless you have a hardware problem like not enough memory or your hard drive is going bad.The biggest reason for laptops running slow is because of a corrupt registry. Especially if you are running Windows Vista. You may have found a lot of incompatible programs or software, and had to uninstall them. They leave behind invalid registry keys and orphaned entries.
You need to clean these out.
Your Windows registry is like a large database, all your software has to reference it when it loads to check for the correct settings. The same as when your computer starts up or shuts down. Your registry is a heart of your system. Any corrupt or damaged, registry entries will really slow down your operations.
Cleaning and maintaining your Windows registry is very important. It’s sort of like giving your computer a tuneup. Windows does not have a tool built in for you to do this with. So you’ll need to download a third-party software program for registry repair and cleaning.
You can edit and repair your registry manually, but it’s not recommended. Even experienced computer technicians have a hard time doing this. They all use software. Besides a few delete or alter the wrong file your computer may become unusable. Software that is made for registry repair is much safer and efficient. With a click of your mouse you can scan your entire computer in a couple of minutes. You can also make a backup and restore point before you make any changes just to be safe.
Depending on how much you use your laptop. You should preform weekly registry maintenance, of course, this applies to any other computer you own to. If you follow the tips above your laptop should not be running slow anymore.
The only other thing I can think of is if you upgraded your operating system to a newer version of Windows like Vista you may not have enough memory now. Memory upgrades have really come down in price lately, and are fairly easy to replace in a laptop.
on Jul 02, 2010 | Computers & Internet
My laptop slows down when opening
Laptop can slow for various reason like -virus infection,hard drive has a lot of programs and files stored on it, this can also slow your computer.
If your RAM is failing or you don't have enough to properly support your operating system,then your laptop can be slow.see:how to Increase laptop speed.
Aug 21, 2012 | Samsung N150 Netbook
Will having too many processing program will slow down my Mac?
Maybe, or probably. Well, there are a number of reasons that may causing a Mac computer running slow, but generally two factors: hardware part & system part. For hardware part: I guess it's OK if your Mac is not that old. For system part: there might be a lot of junk files, caches, registry errors... out there which largely slow down any Mac machines. about 80% slow Mac caused by this reason, if so, try cleaning the system. Learn more from: http://www.howtospeedupmac.com/
Regards!
Feb 17, 2012 | Computers & Internet
Video slow on laptop, music stuter's I have a
Sounds like you have too many programs running at once, try to shut down programs that you are not using, this will open up more memory because video and music takes a lot of your 3mg memory. If it still does not work you will have to upgrade to higher memory. You must have 3GB memory, 3MB memory sound too small.
Oct 23, 2010 | Dell Inspiron 1720 PC Notebook
MY COMPUTER IS SLOW
Greetings my friend, regarding on your problem try to see if you have installed and update an anti virus software in your computer/Laptop then if is it installed then run the anti virus and scan and clean all your drives in your computer otherwise install and update your anti virus software. Also try to check also the files that you have stored in your drives. Delete those files in the recycle bin. Also defrage your drives. If you are using Windows XP then follow this: To defrage your drives go to start button then all programs then accessories then system tools and then click Disk Defragment. then follow the steps given by the computer. Reasons why our computer/Laptop runs slow cause of some viruses/worms and overcrowded files particularly picture and music files. Also too much program installed in your computer/Laptop. Need to have a good management systems in your computer to maintain your desire accuracy and speed of your computer/Laptop.
Jun 16, 2009 | Acer Aspire One AOA110-1588 Notebook
Can't send videos/pics from kodak easy share software
The Kodak Easyshare software just index the pictures they do not store them at all
you can locate the pictures on the computer by
Click start
then look for search
type in in the search box *jpg
And it will display all the pictures that you have on your computer
To fix the problem regarding the easyshare software try uninstall it from your computer
Then download the clear utility www.kodak.com/go/clear
then download the latest version of the easyshare software www.kodak.com/go/easysharesw
Feb 19, 2009 | Kodak EasyShare C613 Digital Camera
Computer runs slow
it doesnt have to do ( AOL or McAFEE ) causing your computer to run slow . let me ask you a couple of question so I can pin point your problem .
1 do you downloads photos & music to your pc?
2 do you surf a lot thru the internet ?
3 do you perform the DISK CLEANUP ? if not , one of the main problem to have a PC to run slow is the MEMORY CAPACITY of your PC . let me know so I can show you some steps to improve your PC . thanks and hope it helps
Apr 19, 2008 | E-Machines eMachines Desktop PC
Computer running very slow
win xp required more then 256 mb ram
mcafee antivirus make system slow,
it take more ram
so u remove antivirus & also
go to run give msconfig
then remove start up items.
for more information call me +919985064600.
avast anti-virus is better it's do not make slower & also norton.
Mar 16, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
